löwenfan60
- Mitglied seit
- 24 Jan 2010
- Beiträge
- 26
- Punkte für Reaktionen
- 0
- Punkte
- 0
Hallo Jörg, hab gestern noch eine Weile rumprobiert und dann hab ich das openvpn wieder starten können! Ich hab dir mal den debug.log angehängt. Kannst du mir sagen ob der log in Ordnung ist? Ich glaub das es klappt, vielleicht kannst du mir sagen welche ip adressen ich den Clienten hinter der Client Fritzbox geben muß. Oder muß ich denen meine dyndns geben?
Tue Apr 6 18:00:10 2010 OpenVPN 2.1.1 mipsel-linux [SSL] [LZO2] [EPOLL] [MH] built on Mar 17 2010
Tue Apr 6 18:00:10 2010 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Tue Apr 6 18:00:10 2010 Diffie-Hellman initialized with 1024 bit key
Tue Apr 6 18:00:10 2010 WARNING: file '/tmp/flash/box.key' is group or others accessible
Tue Apr 6 18:00:10 2010 TLS-Auth MTU parms [ L:1589 D:138 EF:38 EB:0 ET:0 EL:0 ]
Tue Apr 6 18:00:10 2010 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Tue Apr 6 18:00:10 2010 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.200.0
Tue Apr 6 18:00:10 2010 TUN/TAP device tap0 opened
Tue Apr 6 18:00:10 2010 TUN/TAP TX queue length set to 100
Tue Apr 6 18:00:10 2010 /sbin/ifconfig tap0 192.168.200.1 netmask 255.255.255.0 mtu 1500 broadcast 192.168.200.255
Tue Apr 6 18:00:10 2010 Data Channel MTU parms [ L:1589 D:1450 EF:57 EB:4 ET:32 EL:0 ]
Tue Apr 6 16:00:10 2010 chroot to '/tmp/openvpn' and cd to '/' succeeded
Tue Apr 6 16:00:10 2010 GID set to openvpn
Tue Apr 6 16:00:10 2010 UID set to openvpn
Tue Apr 6 16:00:10 2010 Socket Buffers: R=[108544->131072] S=[108544->131072]
Tue Apr 6 16:00:10 2010 UDPv4 link local (bound): [undef]
Tue Apr 6 16:00:10 2010 UDPv4 link remote: [undef]
Tue Apr 6 16:00:10 2010 MULTI: multi_init called, r=256 v=256
Tue Apr 6 16:00:10 2010 IFCONFIG POOL: base=192.168.200.100 size=51
Tue Apr 6 16:00:10 2010 Initialization Sequence Completed
Gruß Rainer
Gruß Rainer
