Fritzbox 7490 startet ständig neu
0:10:843: search on addr: 169.254.191.1
0:12:382: ---> read environment <---
0:12:485: open ftp 169.254.191.1 port 21
0:12:685: recv: 220 ADAM2 FTP Server ready
0:12:685: send: USER adam2
0:12:685: recv: 331 Password required for adam2
0:12:685: send: PASS adam2
0:12:685: recv: 230 User adam2 successfully logged in
0:12:685: send: SYST
0:12:685: recv: 215 AVM EVA Version 1.3179 0x0 0x740D
0:12:685: send: TYPE I
0:12:685: recv: 200 Type set to BINARY
0:12:685: send: MEDIA SDRAM
0:12:685: recv: 200 Media set to MEDIA_SDRAM
0:12:685: send: P@SW
0:12:685: recv: 227 Entering Passive Mode (169,254,191,1,12,12)
0:12:685: open ftp data 169.254.191.1 port 3084
0:12:685: send: RETR env
0:12:685: recv: 150 Opening BINARY data connection
0:12:696: recv: 226 Transfer complete
0:12:822: environment successfully read(1501 bytes)
0:12:822: send: USER adam2
0:12:822: recv: 331 Password required for adam2
0:12:822: send: PASS adam2
0:12:822: recv: 230 User adam2 successfully logged in
0:12:822: send: SYST
0:12:822: recv: 215 AVM EVA Version 1.3179 0x0 0x740D
0:12:822: send: TYPE I
0:12:822: recv: 200 Type set to BINARY
0:12:822: send: MEDIA SDRAM
0:12:822: recv: 200 Media set to MEDIA_SDRAM
0:12:822: send: P@SW
0:12:822: recv: 227 Entering Passive Mode (169,254,191,1,12,7)
0:12:822: open ftp data 169.254.191.1 port 3079
0:12:822: send: RETR count
0:12:822: recv: 150 Opening BINARY data connection
0:12:900: recv: 226 Transfer complete
0:13:010: environment successfully read(151 bytes)
0:13:010: send: BYE
0:13:010: recv: 221 Thank you for using the FTP service on ADAM2
0:13:010:     hardware-revision:    185
0:13:010:     firmware-version:    recovered=2
0:13:010:     urloader-version:    1.3179
0:13:010:     oem:    avm
0:13:010:     provider:
0:13:621: set defaultsettings mtd3 (size: 393216)
0:13:621: ---> write image (mtd3) <---
0:13:731: open ftp 169.254.191.1 port 21
0:13:731: recv: 220 ADAM2 FTP Server ready
0:13:746: send: USER adam2
0:13:746: recv: 331 Password required for adam2
0:13:746: send: PASS adam2
0:13:746: recv: 230 User adam2 successfully logged in
0:13:746: send: SYST
0:13:746: recv: 215 AVM EVA Version 1.3179 0x0 0x740D
0:13:746: send: TYPE I
0:13:746: recv: 200 Type set to BINARY
0:13:746: send: MEDIA FLSH
0:13:746: recv: 200 Media set to MEDIA_FLASH
0:13:746: send: P@SW
0:13:746: recv: 227 Entering Passive Mode (169,254,191,1,12,6)
0:13:746: open ftp data 169.254.191.1 port 3078
0:13:746: clear flash-partition (mtd3)
0:15:471: send: STOR mtd3
0:15:471: recv: 150 Opening BINARY data connection
0:15:471: flash clear (mtd3) ok : now send image
0:15:581: update flash-partition (mtd3)
0:15:597: send image (size=393216) for mtd3
0:19:140: recv: 226 Transfer complete
0:19:140: flash write (mtd3) ok
0:19:265: successfully update of mtd3
0:19:265: send: BYE
0:19:265: recv: 221 Thank you for using the FTP service on ADAM2
0:21:773: set defaultsettings mtd4 (size: 393216)
0:21:773: ---> write image (mtd4) <---
0:21:883: open ftp 169.254.191.1 port 21
0:21:883: recv: 220 ADAM2 FTP Server ready
0:21:899: send: USER adam2
0:21:899: recv: 331 Password required for adam2
0:21:900: send: PASS adam2
0:21:900: recv: 230 User adam2 successfully logged in
0:21:900: send: SYST
0:21:900: recv: 215 AVM EVA Version 1.3179 0x0 0x740D
0:21:900: send: TYPE I
0:21:900: recv: 200 Type set to BINARY
0:21:900: send: MEDIA FLSH
0:21:900: recv: 200 Media set to MEDIA_FLASH
0:21:900: send: P@SW
0:21:900: recv: 227 Entering Passive Mode (169,254,191,1,12,10)
0:21:900: open ftp data 169.254.191.1 port 3082
0:21:900: clear flash-partition (mtd4)
0:23:639: send: STOR mtd4
0:23:639: recv: 150 Opening BINARY data connection
0:23:639: flash clear (mtd4) ok : now send image
0:23:749: update flash-partition (mtd4)
0:23:765: send image (size=393216) for mtd4
0:27:339: recv: 226 Transfer complete
0:27:339: flash write (mtd4) ok
0:27:465: successfully update of mtd4
0:27:465: send: BYE
0:27:465: recv: 221 Thank you for using the FTP service on ADAM2
0:29:565: nand: load filesystem and kernel image to RAM (size: 34331904)
0:29:565: ---> read environment <---
0:29:675: open ftp 169.254.191.1 port 21
0:29:675: recv: 220 ADAM2 FTP Server ready
0:29:675: send: USER adam2
0:29:675: recv: 331 Password required for adam2
0:29:675: send: PASS adam2
0:29:675: recv: 230 User adam2 successfully logged in
0:29:675: send: SYST
0:29:675: recv: 215 AVM EVA Version 1.3179 0x0 0x740D
0:29:675: send: TYPE I
0:29:675: recv: 200 Type set to BINARY
0:29:675: send: MEDIA SDRAM
0:29:675: recv: 200 Media set to MEDIA_SDRAM
0:29:675: send: P@SW
0:29:675: recv: 227 Entering Passive Mode (169,254,191,1,12,1)
0:29:675: open ftp data 169.254.191.1 port 3073
0:29:675: send: RETR env
0:29:675: recv: 150 Opening BINARY data connection
0:29:690: recv: 226 Transfer complete
0:29:816: environment successfully read(1476 bytes)
0:29:816: send: BYE
0:29:816: recv: 221 Thank you for using the FTP service on ADAM2
0:29:816: ramload: savekernel activ for NAND
0:29:816: ---> write image mtd1 mtd1-base/size(0/400000)ram-base/size(80000000/10000000) SquashFS(offset=0x290d00 - 30.175 MiB) <---
0:29:926: open ftp 169.254.191.1 port 21
0:29:926: recv: 220 ADAM2 FTP Server ready
0:29:941: send: USER adam2
0:29:941: recv: 331 Password required for adam2
0:29:941: send: PASS adam2
0:29:941: recv: 230 User adam2 successfully logged in
0:29:941: send: SYST
0:29:941: recv: 215 AVM EVA Version 1.3179 0x0 0x740D
0:29:941: send: SETENV memsize 0xdf3f300
0:29:941: recv: 200 SETENV command successful
0:29:941: send: SETENV kernel_args_tmp mtdram1=0x8df3f300,0x90000000
0:29:941: send: TYPE I
0:29:941: recv: 200 Type set to BINARY
0:29:941: send: MEDIA SDRAM
0:29:941: recv: 200 Media set to MEDIA_SDRAM
0:29:941: send: P@SW
0:29:941: recv: 227 Entering Passive Mode (169,254,191,1,12,9)
0:29:941: open ftp data 169.254.191.1 port 3081
0:29:941: RAM-Load Image to 8df3f300 Filesystem: 8e1d0000
0:29:941: send: STOR 0x8df3f300 0x90000000
0:29:941: recv: 150 Opening BINARY data connection
0:29:941: now send image mtd1 to ram
0:29:957: send image (size=34331904) for mtd1
1:08:916: recv: 226 Transfer complete
1:08:916: load to ram (mtd1) ok
1:44:518: ----EOF---
Und - hast Du brav gewartet, bis die Box von alleine neugestartet ist?
Startet diese denn jetzt?
Ich fragte nicht ob diese nun NEUstartet sondern ob sie startet - ok etwas genauer, startet diese nun komplett und "läuft"?
Aber scheinbar nicht - dann wirst Du ohne serielle Console (oder evtl. ein Downgrade nicht weiter kommen - außer Du kannst die Platine "durchmessen")
Das zeigte ja schon der Log - aber hast Du die Box denn einfach in Ruhe gelassen oder durch stromlos machen neugestartet nachdem das Tool fertig war?
Nein, sie startet ständig neu aller 1 min so ungefähr
Nee habe sie machen lassen habe nix gemacht ..nicht von Strom genommen oder sonst was
Na, die Zeitangabe ist doch schon mal für die Spezialisten ein Anhaltspunkt - wenn Du jetzt noch das Blinkverhalten der LEDs zum Besten geben würdest - würde sich bestimmt mindestens ein User dazu äußern
Kann man Videos hochladen
zB bei YouTube und hier einbetten, jedoch glaube ich nicht, dass sich diejenigen das Video anschauen und für Dich die Zeit mitstoppen - das wäre wohl schon Deine Aufgabe, falls Du eine wirkliche (mögliche) Lösung bzw Diagnose für Deine Box haben möchtest.
Jetzt ist aber auch ein Punkt erreicht, dass Du endlich Deine Boardregelverstöße unterlässt und diesen letzten selbst "glatt ziehst"
Kann nur so sagen wie ich es sehe ...
Die Power LED blinkt 4 mal, bleibt dann stehen 10 Sekunden,dann blinkt sie 11 mal und beim 12 mal startet die Box dann gehen alle LEDs an ...und der spaß fängt wieder von vorne an..
Älteres FRITZ!OS installieren, wo Fehler bei der Hardware-Initialisierung noch nicht automatisch zur "kernel panic" führten und mit diesem System und den dort erstellten Support-Daten den Fehler erst mal weiter eingrenzen. Welches die letzte "passende" FRITZ!OS-Version wäre, weiß ich aus dem Kopf auch nicht mehr - aber man kann ja in größeren Schritten rückwärts gehen (07.1x, 07.0x, 06.8x, 06.5x) - irgendwo "unterwegs" sollte sich noch ein Kernel finden lassen, der nicht ganz so mäklig ist, wenn man eine Hardware-Komponente nicht zu initialisieren ist.
Wau was war viel ...ich werde mal schauen ob ich es hinbekomme..
Ich bedanke mich erst mal für die vielen Antworten und Ratschläge.....aber wenn ihr noch was habt ich nehme sie gerne an ..danke
@profi7870 auch Dir habe ich nun genug "hinterhergewischt" und Benachrichtigungen hinterlassen und jedes Mal gesendet
[Dein roter Counter beim Glockensymbol müsste auch schon "glühen" - bitte entferne nun selbst Dein Vollzitat von darüber - wir wissen alle selbst was wir ein paar Sekunden vorher gelesen haben bzw können problemlos ein paar "Klick-Scrolls" hochscrollen - aber auch ein @USERNAME um den User zu benachrichtigen bzw Dich darauf zu beziehen reicht vollkommen aus. Auch Doppelpost sind unnötig und hier sowie in vielen (ja ich weiß, es gibt genug Boards da wird es geduldet oder die Mods haben einfach "aufgegeben") anderen Foren nicht geduldet/gerne gesehen.]
Bitte korrigiere dies nun eigenständig - danke
Was willst Du denn noch von uns haben? Ein Angebot uns die Box "unfrei" zu schicken und diese funktionell und ebenfalls ohne Rücksendekosten zurück zu bekommen? o_O
Nix war bloß so war doch nicht böse gemeint...
Aber die geht immer noch nicht ..auch bei dieser Version 06.93...geht sie nicht ich gebe es auf ...
ähm... und schon wieder fabrizierst Du ein FQ (FullQuote = VollZitat) - korrigierst das von mir angesprochene nicht und leider kann ich Deine Antwort auf das Vollzitat überhaupt nicht verstehen..
Falles es mit der 6.93 nicht geht und Du Dich selbst nicht in der Lage fühlst, selbst nach früheren Versionen als hier in dem Thread extra für Dich gepostet, poste ich Dir noch eine mögliche Option hier im Board (sogar in diesen Subboard "sticky/angepinnt"
[Sammlung] Suche Firmware & Recover-Images
falls sich dort in #1 nichts finden liese, könntest Du dort nach den benötigten recovery.exe's anfragen und Du wirst diese bestimmt bekommen.....
Bandit24
