19006.1000.00.01.73.41_005.bin
DECIMAL HEXADECIMAL DESCRIPTION
28672 0x7000 XML document, version: "1.0"
198016 0x30580 MySQL MISAM index file Version 9
380928 0x5D000 ELF, 32-bit LSB executable, no machine, version 1 (SYSV)
389273 0x5F099 XML document, version: "1.0"
409600 0x64000 ELF, 32-bit LSB executable, no machine, version 1 (SYSV)
423210 0x6752A Certificate in DER format (x509 v3), header length: 4, sequence length: 617
424375 0x679B7 XML document, version: "1.0"
453015 0x6E997 XML document, version: "1.0"
466944 0x72000 ELF, 32-bit LSB executable, no machine, version 1 (SYSV)
501921 0x7A8A1 Zlib compressed data, default compression
508056 0x7C098 Zlib compressed data, default compression
524288 0x80000 Zlib compressed data, default compression
528384 0x81000 Zlib compressed data, default compression
532480 0x82000 Zlib compressed data, default compression
536576 0x83000 Zlib compressed data, default compression
544768 0x85000 Zlib compressed data, default compression
548864 0x86000 Zlib compressed data, default compression
552960 0x87000 Zlib compressed data, default compression
557056 0x88000 Zlib compressed data, default compression
561152 0x89000 Zlib compressed data, default compression
565248 0x8A000 Zlib compressed data, default compression
569344 0x8B000 Zlib compressed data, default compression
573440 0x8C000 Zlib compressed data, default compression
577536 0x8D000 Zlib compressed data, default compression
581632 0x8E000 Zlib compressed data, default compression
633096 0x9A908 XML document, version: "1.0"
643072 0x9D000 Zlib compressed data, default compression
667648 0xA3000 Zlib compressed data, default compression
671744 0xA4000 Zlib compressed data, default compression
675840 0xA5000 Zlib compressed data, default compression
684189 0xA709D Zlib compressed data, default compression
684286 0xA70FE Zlib compressed data, default compression
685662 0xA765E Zlib compressed data, default compression
758604 0xB934C Zlib compressed data, default compression
758827 0xB942B Zlib compressed data, default compression
758984 0xB94C8 Zlib compressed data, default compression
759375 0xB964F Zlib compressed data, default compression
761856 0xBA000 Zlib compressed data, default compression
765952 0xBB000 Zlib compressed data, default compression
770048 0xBC000 Zlib compressed data, default compression
774144 0xBD000 Zlib compressed data, default compression
778240 0xBE000 Zlib compressed data, default compression
782336 0xBF000 Zlib compressed data, default compression
786432 0xC0000 Zlib compressed data, default compression
790528 0xC1000 Zlib compressed data, default compression
794624 0xC2000 Zlib compressed data, default compression
811008 0xC6000 Zlib compressed data, default compression
815104 0xC7000 Zlib compressed data, default compression
819200 0xC8000 Zlib compressed data, default compression
827709 0xCA13D XML document, version: "1.0"
839680 0xCD000 ELF, 32-bit LSB executable, no machine, version 1 (SYSV)
880640 0xD7000 ELF, 32-bit LSB executable, no machine, version 1 (SYSV)
905216 0xDD000 ELF, 32-bit LSB executable, no machine, version 1 (SYSV)
942080 0xE6000 ELF, 32-bit LSB executable, no machine, version 1 (SYSV)
970752 0xED000 ELF, 32-bit LSB executable, no machine, version 1 (SYSV)
1024000 0xFA000 XML document, version: "1.0"
1134592 0x115000 Android bootimg, kernel size: 4354624 bytes, kernel addr: 0x80008000, ramdisk size: 0 bytes, ramdisk addr: 0x80008000, product name: ""
1138688 0x116000 Linux kernel ARM boot executable zImage (little-endian)
1155087 0x11A00F gzip compressed data, maximum compression, from Unix, last modified: 1970-01-01 00:00:00 (null date)
5496832 0x53E000 Qualcomm device tree container, version: 3, DTB entries: 25
5500928 0x53F000 device tree image (dtb)
5595136 0x556000 device tree image (dtb)
5689344 0x56D000 device tree image (dtb)
5783552 0x584000 device tree image (dtb)
5873664 0x59A000 device tree image (dtb)
5971968 0x5B2000 UBI erase count header, version: 1, EC: 0x0, VID header offset: 0x1000, data offset: 0x2000
