Fritz!Box firmware newer than 54.04.81 fails to update.
freemanen
25 Aug 2012
Hi!
I am using a Fritz!Box 7270 v2 in Sweden. Then I trying to update to newer firmware from settings -->system --> firmware update it starts to update and then it fails to reboot. Power lamp just blinks. First it some short blinks and the it is green lamp shining for some seconds and then all lamps blinks fast and unit reboots. I can go back with a old recovery called FRITZ.Box_Fon_WLAN_7270_16.AnnexB.en-de-es-it-fr.04.81.recover-image.exe after following the intructions the software says. I have tried to update to 54.05.23 firmware by both by file and automatically but no go. I also tried FRITZ.Box_Fon_WLAN_7270_16.en-de-es-it-fr.05.23.recover-image.exe. It says it succed then updating but the lamp blinks the samme as descriped above. I Have tried to download the recovery file several times and have also let the unit be on during the night, but it dosen't affect anything. What could Cause this issue?
lu386
