/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 0
2015-01-19 12:38 NOTICE: TAM0 status change could have failed, should be 0 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 1
2015-01-19 12:39 NOTICE: TAM0 status change could have failed, should be 1 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # vi fritzbox_tam_on_off.php
/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 0 0
2015-01-19 12:41 NOTICE: TAM0 status change could have failed, should be 0 now, but I don't now if it actually is. Check your check section in the script
./var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 0 1
2015-01-19 12:41 NOTICE: TAM1 status change could have failed, should be 0 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 0 2
2015-01-19 12:41 NOTICE: TAM2 status change could have failed, should be 0 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 0 3
2015-01-19 12:41 NOTICE: TAM3 status change could have failed, should be 0 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 0 4
2015-01-19 12:41 NOTICE: TAM4 status change could have failed, should be 0 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 1 4
2015-01-19 12:41 NOTICE: TAM4 status change could have failed, should be 1 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 1 3
2015-01-19 12:41 NOTICE: TAM3 status change could have failed, should be 1 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 1 2
2015-01-19 12:42 NOTICE: TAM2 status change could have failed, should be 1 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 1 1
2015-01-19 12:42 NOTICE: TAM1 status change could have failed, should be 1 now, but I don't now if it actually is. Check your check section in the script.
/var/media/ftp/SanDi/var/media/ftp/SanDisk-Cruzer-01/7360SL # php-cgi -f fritzbox_tam_on_off.php 1 0
2015-01-19 12:42 NOTICE: TAM0 status change could have failed, should be 1 now, but I don't now if it actually is. Check your check section in the script.
