i have changed to "kernel_args annex=A" look my infos plz
but i cant change the firmware i have already same message
Searching FRITZ!Box Fon WLAN 7170 (Annex A) at: 192.168.178.1
One system found! - Detecting the current version.
Version successfully detected!
Hardware: FRITZ!Box Fon WLAN 7170
Bootstrap: 1136
Firmware: 29.04.57
FRITZ!Box Fon WLAN 7170 firmware is incompatible with the recovery firmware
You don't understand me!
It is not necessary to change the firmware to 58.04.57!
Even more: It is not possible to change the firmware to 58.04.57!
With "kernel_args annex=A" it is all done! Your Fritz!Box with firmware 29.04.57 is already annex A!
You don't need to change to firmware version 58.04.57!
Ahh ok sorry now i understand,
but i dont have DSL synchro with this FB WHY??
i have a simple modem router Philips no problem, but with the FB NO DSL SYNCHRO???
i am from BELGIUM and used PSTN line
Missing DSL synchro may have different reasons.
First you should check the ATM parameters: VCI, VPI and encapsulation.
They must have the values given by your provider. Do they?
If the problem continues, we will see further ...
The internal modem of the FritzBox ist not the best, even more if it is a originally AnnexB modem, forced to work in AnnexA mode - as it is in your case.
In case of weak DSL signal, the Fritz modem can't sync. Probably that's your situation.
Solution: Use the existing modem (the Philips modem) for Internet connection and use the FritzBox in mode "Internet access via LAN1".
The "how to" has been described many times here in the forum, also in english, e.g. [post=1171756] here[/post].
Study carefully the description and configure the Philips as "transparent" or "bridged", if it is a router. Then configure the Fritzbox as "Internet access via LAN1" and connect it to the Philips. Connect one of the LAN output of the Philips with the LAN1 of the FritzBox, using a standard LAN cable. That's all!
ok thankyou for your help El_valiente
but i dont like use 2 modem router for one and same jobs
i am continue to search a solution for fritzbox, and i dont find him no problem i continue to use my old PHILIPS
thanks again el_valiente for all
ps: and sorry for my BAD english
Don't worry, my english isn't much better than yours ...
I only know one more possibility to improve the DSL sync quality of the internal modem.
It is a little more sophisticated and consists in the transfer of a better working DSL AnnexA modul (from an AnnexA Firmware) to your AnnexB firmware.
You can study the method [post=1226880]here[/post] (in german). It refers to FB7270. But you can use the same method in FB7170, using the appropiate FB7170 firmware.
Perhaps, after this operation, your FB7170 is able to synchronize with AnnexA DSL ...
Hi, el_valiente
i have find him the solution for my FB finally
i have find him a Custom firmware on italian site you can choose your language and your Annex after the firmware update and all works perfectly
if you want the links i can give???
