`configure' configures asterisk 1.6 to adapt to many kinds of systems.
Usage: ./configure [OPTION]... [VAR=VALUE]...
To assign environment variables (e.g., CC, CFLAGS...), specify them as
VAR=VALUE. See below for descriptions of some of the useful variables.
Defaults for the options are specified in brackets.
Configuration:
-h, --help display this help and exit
--help=short display options specific to this package
--help=recursive display the short help of all the included packages
-V, --version display version information and exit
-q, --quiet, --silent do not print `checking...' messages
--cache-file=FILE cache test results in FILE [disabled]
-C, --config-cache alias for `--cache-file=config.cache'
-n, --no-create do not create output files
--srcdir=DIR find the sources in DIR [configure dir or `..']
Installation directories:
--prefix=PREFIX install architecture-independent files in PREFIX
[/usr/local]
--exec-prefix=EPREFIX install architecture-dependent files in EPREFIX
[PREFIX]
By default, `make install' will install all the files in
`/usr/local/bin', `/usr/local/lib' etc. You can specify
an installation prefix other than `/usr/local' using `--prefix',
for instance `--prefix=$HOME'.
For better control, use the options below.
Fine tuning of the installation directories:
--bindir=DIR user executables [EPREFIX/bin]
--sbindir=DIR system admin executables [EPREFIX/sbin]
--libexecdir=DIR program executables [EPREFIX/libexec]
--sysconfdir=DIR read-only single-machine data [PREFIX/etc]
--sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
--localstatedir=DIR modifiable single-machine data [PREFIX/var]
--libdir=DIR object code libraries [EPREFIX/lib]
--includedir=DIR C header files [PREFIX/include]
--oldincludedir=DIR C header files for non-gcc [/usr/include]
--datarootdir=DIR read-only arch.-independent data root [PREFIX/share]
--datadir=DIR read-only architecture-independent data [DATAROOTDIR]
--infodir=DIR info documentation [DATAROOTDIR/info]
--localedir=DIR locale-dependent data [DATAROOTDIR/locale]
--mandir=DIR man documentation [DATAROOTDIR/man]
--docdir=DIR documentation root [DATAROOTDIR/doc/asterisk]
--htmldir=DIR html documentation [DOCDIR]
--dvidir=DIR dvi documentation [DOCDIR]
--pdfdir=DIR pdf documentation [DOCDIR]
--psdir=DIR ps documentation [DOCDIR]
System types:
--build=BUILD configure for building on BUILD [guessed]
--host=HOST cross-compile to build programs to run on HOST [BUILD]
Optional Features:
--disable-option-checking ignore unrecognized --enable/--with options
--disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
--enable-FEATURE[=ARG] include FEATURE [ARG=yes]
--enable-dev-mode Turn on developer mode
--disable-largefile omit support for large files
--enable-internal-poll Use Asterisk's poll implementation
--disable-xmldoc Explicity disable XML documentation
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
[U][B]--without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)[/B][/U]
--with-gnu-ld assume the C compiler uses GNU ld [default=no]
--with-asound=PATH use Advanced Linux Sound Architecture files in PATH
--with-execinfo=PATH use Stack Backtrace support files in PATH
--with-cap=PATH use POSIX 1.e capabilities files in PATH
--with-curl=PATH use cURL files in PATH
--with-curses=PATH use curses files in PATH
--with-crypto=PATH use OpenSSL Cryptography support files in PATH
--with-dahdi=PATH use DAHDI files in PATH
--with-avcodec=PATH use Ffmpeg and avcodec library files in PATH
--with-gsm=PATH use External GSM library files in PATH , use
'internal' GSM otherwise
--with-gtk=PATH use gtk libraries files in PATH
--with-gtk2=PATH use gtk2 libraries files in PATH
--with-gmime=PATH use GMime library files in PATH
--with-hoard=PATH use Hoard Memory Allocator files in PATH
--with-iconv=PATH use Iconv Library files in PATH
--with-iksemel=PATH use Iksemel Jabber Library files in PATH
--with-imap=PATH use UW IMAP Toolkit files in PATH
--with-inotify=PATH use inotify support files in PATH
--with-iodbc=PATH use iODBC files in PATH
--with-isdnnet=PATH use ISDN4Linux Library files in PATH
--with-jack=PATH use Jack Audio Connection Kit files in PATH
--with-ldap=PATH use OpenLDAP files in PATH
--with-libxml2=PATH use LibXML2 files in PATH
--with-ltdl=PATH use libtool files in PATH
--with-lua=PATH use Lua files in PATH
--with-misdn=PATH use mISDN User Library files in PATH
--with-nbs=PATH use Network Broadcast Sound files in PATH
[B][U]--with-ncurses=PATH use ncurses files in PATH[/U][/B]
--with-netsnmp=PATH use Net-SNMP files in PATH
--with-newt=PATH use newt files in PATH
--with-ogg=PATH use OGG files in PATH
--with-osptk=PATH use OSP Toolkit files in PATH
--with-oss=PATH use Open Sound System files in PATH
--with-postgres=PATH use PostgreSQL files in PATH
--with-popt=PATH use popt files in PATH
--with-portaudio=PATH use PortAudio files in PATH
--with-pri=PATH use ISDN PRI files in PATH
--with-resample=PATH use LIBRESAMPLE files in PATH
--with-spandsp=PATH use SPANDSP files in PATH
--with-ss7=PATH use ISDN SS7 files in PATH
--with-openr2=PATH use MFR2 files in PATH
--with-pwlib=PATH use PWlib files in PATH
--with-h323=PATH use OpenH323 files in PATH
--with-radius=PATH use Radius Client files in PATH
--with-sdl=PATH use Sdl files in PATH
--with-SDL_image=PATH use Sdl Image library files in PATH
--with-openais=PATH use OpenAIS files in PATH
--with-speex=PATH use Speex files in PATH
--with-speex=PATH use Speex preprocess routines files in PATH
--with-speexdsp=PATH use Speexdsp files in PATH
--with-sqlite=PATH use SQLite files in PATH
--with-sqlite3=PATH use SQLite files in PATH
--with-suppserv=PATH use mISDN Supplemental Services files in PATH
--with-ssl=PATH use OpenSSL Secure Sockets Layer support files in
PATH
--with-tds=PATH use FreeTDS files in PATH
[U][B]--with-termcap=PATH use Termcap files in PATH[/B][/U]
--with-tinfo=PATH use Term Info files in PATH
--with-tonezone=PATH use tonezone files in PATH
--with-unixodbc=PATH use unixODBC files in PATH
--with-usb=PATH use usb files in PATH
--with-vorbis=PATH use Vorbis files in PATH
--with-vpb=PATH use Voicetronix API files in PATH
--with-x11=PATH use X11 support files in PATH
--with-z=PATH use zlib files in PATH
--with-timerfd=PATH use timerfd files in PATH
--with-libcurl=DIR look for the curl library in DIR
Some influential environment variables:
CC C compiler command
CFLAGS C compiler flags
LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
nonstandard directory <lib dir>
LIBS libraries to pass to the linker, e.g. -l<library>
CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
you have headers in a nonstandard directory <include dir>
CPP C preprocessor
CXX C++ compiler command
CXXFLAGS C++ compiler flags
CXXCPP C++ preprocessor
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
Report bugs to <www.asterisk.org>.
