Silent-Tears
IPPF-Promi
- Mitglied seit
- 3 Aug 2007
- Beiträge
- 7,456
- Punkte für Reaktionen
- 1
- Punkte
- 0
1 out of 1 hunk FAILED -- saving rejects to file usr/www/all/html/de/js/basis.js.rej
patching file usr/www/all/html/de/menus/menu2_homehome.html
patching file usr/www/all/html/de/menus/menu2_konfig.html
Hunk #1 succeeded at 41 (offset -1 lines).
patching file usr/www/all/html/de/menus/menu2_usb.html
patching file usr/www/all/html/de/system/energy.html
Hunk #1 succeeded at 77 (offset 4 lines).
patching file usr/www/all/html/de/system/infoled.html
Hunk #1 succeeded at 14 (offset 2 lines).
patching file usr/www/all/html/de/system/netipadr.js
Hunk #1 succeeded at 55 (offset 1 line).
patching file usr/www/all/html/de/system/syslog.html
ERROR: modpatch: Error in patch-file ./patches/cond/de/sp2fritz-W701V_7170.patch
make: *** [firmware-nocompile] Fehler 2
Hunk #1 succeeded at 18 (offset 2 lines).
patching file usr/www/avm/html/de/system/update_OnClick_1.html
patching file usr/www/avm/html/de/system/update_OnClick_1.js
patching file usr/www/avm/html/tools/downgrade.html
patching file usr/www/avm/html/tools/flash2.html
patching file usr/www/avm/html/tools/flash.html
Hunk #1 FAILED at 66.
1 out of 1 hunk FAILED -- saving rejects to file usr/www/avm/html/tools/flash.html.rej
ERROR: modpatch: Error in patch-file ./patches/cond/de/sp2fritz-W900V_7170.patch
uname -a
Linux fritz.fonwlan.box 2.6.13.1-ohio #1 Fri Jan 22 13:18:48 CET 2010 mips GNU/Linux
dslinfodata
/snipp
ATM Driver version:[4.08.01.00]
DSL HAL version: [5.00.01.02]
DSP Datapump version: [1.36.20.01]
SAR HAL version: [01.07.2b]
PDSP Firmware version:[0.54]
dmesg
/snipp
option 1-1:1.0: Option 3G data card converter detected
usb 1-1: Option 3G data card converter now attached to ttyUSB0
/var/mod/root # uname -a
Linux fritz.fonwlan.box 2.6.13.1-ohio #1 Tue Jul 21 16:13:51 CEST 2009 mips GNU/Linux
Feb 3 00:25:41 fritz ftp.info vsftpd[2530]: [root] OK DOWNLOAD: Client "192.168.1.3", "/var/cache/sys.log", 43060 bytes, 13.56Kbyte/sec
Feb 3 00:22:59 fritz daemon.info dnsmasq[2050]: started, version 2.51 cachesize 150
Feb 3 00:22:59 fritz daemon.info dnsmasq[2050]: compile time options: no-IPv6 GNU-getopt no-DBus no-I18N DHCP TFTP
Feb 3 00:22:59 fritz daemon.info dnsmasq[2050]: asynchronous logging enabled, queue limit is 10 messages
Feb 3 00:22:59 fritz daemon.info dnsmasq-dhcp[2050]: DHCP, IP range 192.168.1.20 -- 192.168.1.25, lease time 1d
Feb 3 00:22:59 fritz daemon.info dnsmasq[2050]: using nameserver 208.67.220.220#53
Feb 3 00:22:59 fritz daemon.info dnsmasq[2050]: using nameserver 208.67.222.222#53
Feb 3 00:23:00 fritz daemon.info dnsmasq[2050]: read /etc/hosts - 3 addresses
Feb 3 00:25:51 fritz daemon.info dnsmasq[2050]: exiting on receipt of SIGTERM
Feb 2 23:25:52 fritz daemon.info dnsmasq[2733]: started, version 2.51 cachesize 150
Feb 2 23:25:52 fritz daemon.info dnsmasq[2733]: compile time options: no-IPv6 GNU-getopt no-DBus no-I18N DHCP TFTP
Feb 2 23:25:52 fritz daemon.info dnsmasq[2733]: asynchronous logging enabled, queue limit is 10 messages
Feb 2 23:25:52 fritz daemon.info dnsmasq-dhcp[2733]: DHCP, IP range 192.168.1.20 -- 192.168.1.25, lease time 1d
Feb 2 23:25:52 fritz daemon.info dnsmasq[2733]: using nameserver 208.67.220.220#53
Feb 2 23:25:52 fritz daemon.info dnsmasq[2733]: using nameserver 208.67.222.222#53
Feb 2 23:25:52 fritz daemon.info dnsmasq[2733]: read /etc/hosts - 3 addresses
Feb 3 00:25:53 fritz user.info kernel: device eth0 left promiscuous mode
Feb 3 00:25:53 fritz user.info kernel: lan: port 1(eth0) entering disabled state
