Freetz support for the 5124
Mmm too bad.
AVM doesn't support IPv6 for that FritzBox.
If Freetz doesn't support the 5124 then IPv6 will be difficult... :sad:
Do you think i can ask the Freetz developers for 5124 support? Is it difficult to support the 5124?
I don't know if it will be difficult. This depends on the firmware. It will be around 30 minutes of work. Perhaps you can open a ticket on trac.freetz.org and when somebody has time he will look after it.
Regards
Oliver
The 5124 is an "international only" box, nerver sold in germany. For most of the developers are in germany, there will probably be no one owning this box. And for ipv6 will need a replaced kernel, it would be difficult to investigate w/o the box.
Looking to the "install" script, it looks like a box "between" 7170 and 5140.
5124: ar7_8MB_xilinx_4eth_2ab_isdn_te_pots_usb_host_29898
5140: ar7_4MB_xilinx_4eth_2ab_isdn_nt_te_pots_48514
7170: ar7_8MB_xilinx_4eth_3ab_isdn_nt_te_pots_wlan_usb_host_25762
So you might try to build a image for these boxes (e.g. 7170 with remove WLAN) and patch the start-scripts (namely /etc/init.d/rc.S) to reflect the HW of the 5124. Maybe you can even try a "real" 7170 image and only change the settings.
This should at least give a working firmware, but it might be instable (and the GUI will have entries not matching your HW like internal ISDN).
Jörg
I think MaxMusters idea is worth a try. Perhaps we can build a 7170 Alien image for the 5124...
I will post a patch in the ticket when I find some time to work on it.
Regards
Oliver
Maybe we can get some more information about the box in advance, especially memory and cpu?
I remember using a 7170 based image on a 5130 (an oem box very near to 5140) and it was very very slow and instable on this box, because of the lower spped cpu and the RAM (16MB) beeing only half of the 7170s 32MB.
Jöerg
A first try for a patch is attaches to the trac-ticket.
Jörg
Web interface
Jörg
Thanks for that! I built a firmware using that patch and uploaded the image to the box.
I see freetz interface at 192.168.178.1:81 but I dont see any place to modify dsl settings. How do I do that? did I miss something very obvious?
thanks
Karthik
freetz has nor possibilöity to modify your dsl-settings yet. Only for a few boxes there is an option in menuconfig to patch extended dsl settings into the AVM-webinterface.
Maybe we should check it in. Near feature freeze, you know? ;) I think about some other aliens, too
ummm... so how do I access the AVM webinterface? I tried 192.168.178.1 and I get "403 Forbidden". Is that my problem? or is it normal w/ freetz?
I tried starting httpd on 8081 with home to /usr/www/avme and now I see avm web interface @ 192.168.178.1:8081. so may be whatever listening on port 80 is not configured properly?
sorry for these questions here, I am new to freetz and my non-existent german is not very helpful.
thanks
Karthik
Please attach the .config of your image. See trac.freetz.org if you don't know what to do.
Please post the output of "ps" from the telnet console.
Regards
Oliver
here it is.
Thanks for any help.
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_04_67=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
FREETZ_TYPE_FON_5124=y
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7112 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
# FREETZ_TYPE_FON_WLAN_7240 is not set
# FREETZ_TYPE_FON_WLAN_7270 is not set
# FREETZ_TYPE_FON_WLAN_7270_V3 is not set
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_WLAN_3270_V3 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_AVM_VERSION_STRING="04.67"
# FREETZ_TYPE_LANG_DE is not set
# FREETZ_TYPE_LANG_A_CH is not set
FREETZ_TYPE_LANG_EN=y
FREETZ_TYPE_LANG_STRING="en"
FREETZ_TYPE_ANNEX_A=y
# FREETZ_TYPE_ANNEX_B is not set
FREETZ_TYPE_STRING="5124"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
# FREETZ_SHOW_ADVANCED is not set
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ohio"
FREETZ_KERNEL_MTD_SIZE=119
FREETZ_HAS_PHONE=y
# FREETZ_HAS_TAM is not set
# FREETZ_HAS_WLAN is not set
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
# FREETZ_HAS_AVM_INETD is not set
# FREETZ_HAS_LIBSSL is not set
# Mod ------------------------------------
# FREETZ_LANG_DE is not set
FREETZ_LANG_EN=y
FREETZ_LANG_STRING="en"
# Patches
# Web menu patches ------------------------
# FREETZ_PATCH_SIGNED is not set
# USB mounting ----------------------------
# FREETZ_PATCH_FREETZMOUNT is not set
# FREETZ_PATCH_RCFTPD is not set
FREETZ_PATCH_USBSTORAGE=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
# FREETZ_AUTOMOUNT_EXT3 is not set
# FREETZ_AUTOMOUNT_NTFS is not set
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTORUN_AUTOEND is not set
# FREETZ_PATCH_MAXDEVCOUNT is not set
# Removings -------------------------------
# FREETZ_REMOVE_WEBSRV is not set
# Remove brandings
# FREETZ_REMOVE_BRANDING_avme is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_SUPPORT is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_USERMAN is not set
# Adds -----------------------------------
# Other stuff -----------------------------
# FREETZ_PATCH_GETCONS is not set
# Package selection
# *** not all packages support selected language ***
# FREETZ_SELECTED_LANG_ONLY is not set
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
FREETZ_PACKAGE_CIFSMOUNT=y
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_OPENNTPD is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# Web interfaces
# FREETZ_PACKAGE_AVM_FIREWALL is not set
# FREETZ_PACKAGE_CPMACCFG_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_AUTHORIZED_KEYS is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_NHIPT is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_PPP_CGI is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
# FREETZ_PACKAGE_SYSLOGD_CGI is not set
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Debug helpers
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Testing
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# OpenSSH
# FREETZ_PACKAGE_OPENSSH_SSHD is not set
# FREETZ_PACKAGE_OPENSSH_CLIENT is not set
# FREETZ_PACKAGE_OPENSSH_SCP is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_SFTPCLIENT is not set
# FREETZ_PACKAGE_OPENSSH_SFTP is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PPPD_CHAT is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_TMUX is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNRAR is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VTUN is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XMAIL is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE="@AVM/develper/opensrc"
FREETZ_DL_KERNEL_SOURCE="fritzbox-source-files.04.67.tar.gz"
FREETZ_DL_KERNEL_SOURCE_MD5="ec2c233bb836e822d9018fd41e123a91"
FREETZ_DL_SITE="@AVM/fritz.box/fritzbox.fon_5124/firmware/english/annex_a"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_5124.AnnexA.en.57.04.67.image"
FREETZ_DL_SOURCE_MD5="756e491fb2e2deb4fe4faa36fca3db15"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: http://freetz.3dfxatwork.de
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: http://freetz.wirsind.info
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: http://freetz.magenbrot.net
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_SECURITY_LEVEL=1
FREETZ_VERBOSITY_LEVEL=2
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
# FREETZ_BACKUP_CONFIG_CACHE is not set
FREETZ_CHECK_CHANGED=y
FREETZ_FAVICON_STRING="none"
FREETZ_SUBVERSION_STRING=y
FREETZ_DEVELOPER_VERSION_STRING=y
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
FREETZ_USER_DEFINED_COMMENT=""
# External
# EXTERNAL_ENABLED is not set
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_BZIP2 is not set
# FREETZ_BUSYBOX_CHGRP is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_DOS2UNIX is not set
# FREETZ_BUSYBOX_ETHER_WAKE is not set
# FREETZ_BUSYBOX_FANCY_KEYS is not set
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_IP is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
FREETZ_BUSYBOX_MD5SUM=y
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_PATCH is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_REALPATH=y
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SPLIT is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
# FREETZ_BUSYBOX_TAC is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UNIX2DOS is not set
# FREETZ_BUSYBOX_UNZIP is not set
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_WHOAMI is not set
# Kernel modules
# crypto
# FREETZ_MODULE_aes is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
FREETZ_MODULE_ppp_async=y
FREETZ_MODULE_ppp_deflate=y
FREETZ_MODULE_ppp_generic=y
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
FREETZ_MODULE_slhc=y
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
FREETZ_MODULE_usbserial=y
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
FREETZ_MODULE_option=y
# fs
FREETZ_MODULE_cifs=y
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext3 is not set
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
# FREETZ_MODULE_fuse is not set
# FREETZ_MODULE_jbd is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
FREETZ_MODULE_crc_ccitt=y
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Shared libraries
# Libraries -------------------------------
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libatm is not set
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdb is not set
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GMP ------------------------------------
# FREETZ_LIB_libgmp is not set
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl is not set
# FREETZ_LIB_libcrypto is not set
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
# FREETZ_LIB_libz is not set
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# FREETZ_LIB_libgd is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
# FREETZ_LIB_libresolv is not set
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# FREETZ_LIB_libuClibc__ is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libglib_1 is not set
# GLib2
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# FREETZ_LIB_libcapi20 is not set
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libnetpbm is not set
# Ogg/Vorbis
# FREETZ_LIB_libogg is not set
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libdnet is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# FREETZ_LIB_libsqlite3 is not set
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
FREETZ_LIB_libfreetz=y
# FREETZ_LIB_libpcre is not set
# FREETZ_LIB_libpcreposix is not set
# FREETZ_LIB_libxml2 is not set
# Compiler options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
FREETZ_TARGET_ARCH="mipsel"
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_KERNEL_VERSION_2_6_13_1=y
# FREETZ_KERNEL_VERSION_2_6_19_2 is not set
FREETZ_KERNEL_VERSION="2.6.13.1"
FREETZ_TARGET_UCLIBC_VERSION_0_9_28=y
# FREETZ_TARGET_UCLIBC_VERSION_0_9_29 is not set
# FREETZ_TARGET_UCLIBC_VERSION_0_9_30 is not set
# FREETZ_TARGET_COMPILER_GCC_4_1_2_UCLIBC_0_9_28 is not set
FREETZ_TARGET_COMPILER_GCC_4_2_4_UCLIBC_0_9_28=y
# FREETZ_TARGET_COMPILER_GCC_4_2_4_UCLIBC_0_9_29 is not set
# FREETZ_TARGET_COMPILER_GCC_4_3_3_UCLIBC_0_9_29 is not set
# FREETZ_TARGET_COMPILER_GCC_4_3_3_UCLIBC_0_9_30 is not set
FREETZ_TARGET_GCC_VERSION="4.2.4"
FREETZ_TARGET_UCLIBC_VERSION="0.9.28"
FREETZ_TARGET_BINUTILS_VERSION="2.18"
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
FREETZ_TARGET_CCACHE=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# FREETZ_TARGET_TOOLCHAIN is not set
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
PID USER       VSZ STAT COMMAND
    1 root      1144 S    init
    2 root         0 SWN  [ksoftirqd/0]
    3 root         0 SW<  [events/0]
    4 root         0 SW<  [khelper]
    5 root         0 SW<  [kthread]
    6 root         0 SW<  [kblockd/0]
   23 root         0 SW<  [pdflush]
   24 root         0 SW<  [pdflush]
   26 root         0 SW<  [aio/0]
   25 root         0 SW   [kswapd0]
   62 root         0 SW   [pm_info]
   66 root         0 SW<  [CPMAC]
   70 root         0 SW   [mtdblockd]
   96 root         0 SW   [tffsd_mtd_0]
  282 root         0 SW<  [capi_oslib]
  283 root         0 SW<  [capi_oslib]
  284 root         0 SW   [capitransp]
  290 root         0 SW   [glob_codecs]
  303 root         0 SW<  [khubd]
  342 root      6060 S N  ctlmgr
  347 root      2816 S    igdd
  372 root      2524 S    multid
  391 root      6060 S N  ctlmgr
  392 root      6060 S N  ctlmgr
  393 root      6060 S N  ctlmgr
  417 root      2084 S    telefon a127.0.0.1
  419 root      1328 S    telnetd -l /sbin/ar7login
  422 root      4332 S <  voipd
  429 root       832 S    /bin/run_clock -c /dev/tffs -d
  452 root      2340 S    /usr/bin/faxd -a
  498 root      1136 S    httpd -P /var/run/webcfg.pid -p 81 -c /mod/etc/httpd
  513 root      1144 S    init
  516 root      2344 S    usermand
 1866 root      2740 S    dsld -n
 2484 root      1164 S    -sh
 3870 root         0 RWN  [kdsld_token]
 4088 root      1136 S    httpd -P /var/webcfg2.pid -c /mod/etc/httpd.conf -h
  606 root      1136 R    ps
ctlmgr ist running. So there should be a webinterface on port 80. Perhaps you can investigate this with "netstat -rn". In your .config I can't see any selected packages which are known to cause problems.
Regards
Oliver
This one looks strange. If ctlmgr is running (and it should contain the webserver in this firmware) it should use port 80. So how can there be a running httpd w/o a port setting, which should run on port 80, too?!?
So if you could post
netstat -lpn
Jörg
