execve("/sbin/smbd", ["smbd"], [/* 170 vars */]) = 0
old_mmap(NULL, 20, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaad000
open("/mod/lib/libcrypt.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libcrypt.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=11520, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaae000
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\260\4\0\0004\0\0\0\250"..., 4096) = 4096
old_mmap(NULL, 147456, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aabe000
old_mmap(0x2aabe000, 10212, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aabe000
old_mmap(0x2aad0000, 2100, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2000) = 0x2aad0000
old_mmap(0x2aad1000, 68896, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2aad1000
close(3) = 0
munmap(0x2aaae000, 4096) = 0
open("/mod/lib/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libdl.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=9372, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\220\7\0\0004\0\0\0\364"..., 4096) = 4096
old_mmap(NULL, 77824, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aae2000
old_mmap(0x2aae2000, 6208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aae2000
old_mmap(0x2aaf3000, 4200, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x2aaf3000
close(3) = 0
open("/mod/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libpthread.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=94510, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0 4\0\0004\0\0\0X"..., 4096) = 4096
old_mmap(NULL, 147456, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaf5000
old_mmap(0x2aaf5000, 51108, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aaf5000
old_mmap(0x2ab11000, 22440, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xc000) = 0x2ab11000
old_mmap(0x2ab17000, 6816, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2ab17000
close(3) = 0
open("/mod/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=55452, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\340\30\0\0004\0\0\0\334"..., 4096) = 4096
old_mmap(NULL, 122880, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab19000
old_mmap(0x2ab19000, 53908, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab19000
old_mmap(0x2ab36000, 1052, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd000) = 0x2ab36000
close(3) = 0
open("/mod/lib/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libc.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=427348, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\0\252\0\0004\0\0\0l"..., 4096) = 4096
old_mmap(NULL, 466944, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab37000
old_mmap(0x2ab37000, 375716, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab37000
old_mmap(0x2aba2000, 8076, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x5b000) = 0x2aba2000
old_mmap(0x2aba4000, 18896, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2aba4000
close(3) = 0
mprotect(0x2ab37000, 375716, PROT_READ|PROT_WRITE|PROT_EXEC) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
stat("/lib/ld-uClibc.so.0", {st_mode=S_IFREG|0755, st_size=22664, ...}) = 0
mprotect(0x2aaf3000, 4096, PROT_READ) = 0
mprotect(0x2ab11000, 4096, PROT_READ) = 0
mprotect(0x2aba2000, 4096, PROT_READ) = 0
mprotect(0x2aabc000, 4096, PROT_READ) = 0
mprotect(0x2ab37000, 375716, PROT_READ|PROT_EXEC) = 0
ioctl(0, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
ioctl(1, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
getpid() = 2300
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=0}) = 0
setrlimit(RLIMIT_STACK, {rlim_cur=2040*1024, rlim_max=0}) = 0
rt_sigaction(SIGRT_0, {SIG_DFL, [], SA_STACK|SA_INTERRUPT|0x2b00f44}, NULL, 16) = 0
rt_sigaction(SIGRT_1, {SIG_DFL, [], SA_STACK|SA_INTERRUPT|0x2b00e54}, NULL, 16) = 0
rt_sigaction(SIGRT_2, {SIG_DFL, [], SA_STACK|SA_INTERRUPT|0x2b00214}, NULL, 16) = 0
rt_sigprocmask(SIG_BLOCK, [RT_0], NULL, 16) = 0
rt_sigprocmask(SIG_UNBLOCK, [RT_1], NULL, 16) = 0
brk(0) = 0x53bef8
brk(0x53cef8) = 0x53cef8
brk(0x53d000) = 0x53d000
open("/mod/etc/upcase.dat", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
open("/mod/etc/lowcase.dat", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
brk(0x55d000) = 0x55d000
brk(0x57d000) = 0x57d000
setpriority(PRIO_PROCESS, 0, 19) = 0
geteuid() = 0
getegid() = 0
open("/dev/urandom", O_RDONLY|O_LARGEFILE) = 3
setresuid(0, 0, 0) = 0
setuid(0) = 0
geteuid() = 0
getuid() = 0
setresgid(0, 0, 0) = 0
setgid(0) = 0
getegid() = 0
getgid() = 0
rt_sigaction(SIGSEGV, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, {SIG_DFL, [], 0}, 16) = 0
rt_sigaction(SIGBUS, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, {SIG_DFL, [], 0}, 16) = 0
rt_sigaction(SIGIOT, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, {SIG_DFL, [], 0}, 16) = 0
mkdir("/var/samba/cores", 0700) = -1 EEXIST (File exists)
mkdir("/var/samba/cores/smbd", 0700) = -1 EEXIST (File exists)
getuid() = 0
getgid() = 0
chown("/var/samba/cores/smbd", 0, 0) = 0
chmod("/var/samba/cores/smbd", 0700) = 0
getrlimit(RLIMIT_CORE, {rlim_cur=0, rlim_max=0}) = 0
setrlimit(RLIMIT_CORE, {rlim_cur=16384*1024, rlim_max=4740616}) = -1 EINVAL (Invalid argument)
getrlimit(RLIMIT_CORE, {rlim_cur=0, rlim_max=2141230592}) = 0
prctl(0x4, 0x1, 0, 0, 0x4feab8) = 0
setuid(0) = 0
geteuid() = 0
getuid() = 0
setgid(0) = 0
getegid() = 0
getgid() = 0
rt_sigaction(SIGSEGV, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, 16) = 0
rt_sigaction(SIGBUS, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, 16) = 0
rt_sigaction(SIGIOT, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, 16) = 0
getuid() = 0
getgid() = 0
rt_sigaction(SIGTERM, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, {SIG_DFL, [], 0}, 16) = 0
rt_sigaction(SIGHUP, {0x10000000, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2aedad0}, {SIG_DFL, [], SA_NOCLDSTOP}, 16) = 0
rt_sigprocmask(SIG_BLOCK, [PIPE], NULL, 16) = 0
rt_sigprocmask(SIG_BLOCK, [FPE], NULL, 16) = 0
rt_sigprocmask(SIG_BLOCK, [USR2], NULL, 16) = 0
rt_sigprocmask(SIG_UNBLOCK, [HUP], NULL, 16) = 0
rt_sigprocmask(SIG_UNBLOCK, [USR1], NULL, 16) = 0
rt_sigprocmask(SIG_UNBLOCK, [TERM], NULL, 16) = 0
umask(0) = 022
geteuid() = 0
getegid() = 0
getgid() = 0
getegid() = 0
setresgid(-1, 0, -1) = 0
getegid() = 0
setgid(0) = 0
getgroups(0, 0x57c6a0) = 1
getgroups(1, [0]) = 1
setresgid(0, 0, -1) = 0
getegid() = 0
getgid() = 0
umask(022) = 0
open("", O_WRONLY|O_CREAT|O_APPEND|O_LARGEFILE, 0644) = -1 ENOENT (No such file or directory)
umask(0) = 022
umask(022) = 0
umask(0) = 022
stat64(0x7fa08db8, 0x7fa08c00) = 0
uname({sys="Linux", node="fritz.fonwlan.box", ...}) = 0
open("/mod/etc/smb.conf", O_RDONLY|O_LARGEFILE) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=546, ...}) = 0
old_mmap(NULL, 1229725696, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, 0, 0) = -1 ENOMEM (Cannot allocate memory)
brk(0x49a3e000) = 0x57d000
close(4) = 0
brk(0x57e000) = 0x57e000
brk(0x57f000) = 0x57f000
brk(0x581000) = 0x581000
open("/mod/etc/charset/CP850.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/CP850.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/CP850.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/CP850.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/X11R6/lib/CP850.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/etc/valid.dat", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
brk(0x591000) = 0x591000
stat64(0x7fa091d0, 0x7fa09048) = -1 ENOENT (No such file or directory)
umask(022) = 0
umask(0) = 022
stat64(0x7fa08d88, 0x7fa08c00) = 0
umask(022) = 0
umask(0) = 022
socket(PF_INET, SOCK_DGRAM, IPPROTO_IP) = 4
ioctl(4, 0x8912, {128, {{"lo", {AF_INET, inet_addr("127.0.0.1")}}, {"lan", {AF_INET, inet_addr("192.168.178.1")}}, {"lan:0", {AF_INET, inet_addr("169.254.1.1")}}, {"dsl", {AF_INET, inet_addr("169.254.2.1")}}}}) = 0
ioctl(4, 0x8915, {ifr_name="dsl", ifr_addr={AF_INET, inet_addr("169.254.2.1")}}) = 0
ioctl(4, 0x8913, {ifr_name="dsl", ifr_flags=IFF_UP|IFF_POINTOPOINT|IFF_RUNNING|IFF_NOARP|IFF_ALLMULTI|IFF_MULTICAST}) = 0
ioctl(4, 0x891b, {ifr_name="dsl", ifr_netmask={AF_INET, inet_addr("255.255.255.255")}}) = 0
ioctl(4, 0x8915, {ifr_name="lan:0", ifr_addr={AF_INET, inet_addr("169.254.1.1")}}) = 0
ioctl(4, 0x8913, {ifr_name="lan:0", ifr_flags=IFF_UP|IFF_BROADCAST|IFF_RUNNING|IFF_ALLMULTI|IFF_MULTICAST}) = 0
ioctl(4, 0x891b, {ifr_name="lan:0", ifr_netmask={AF_INET, inet_addr("255.255.0.0")}}) = 0
ioctl(4, 0x8915, {ifr_name="lan", ifr_addr={AF_INET, inet_addr("192.168.178.1")}}) = 0
ioctl(4, 0x8913, {ifr_name="lan", ifr_flags=IFF_UP|IFF_BROADCAST|IFF_RUNNING|IFF_ALLMULTI|IFF_MULTICAST}) = 0
ioctl(4, 0x891b, {ifr_name="lan", ifr_netmask={AF_INET, inet_addr("255.255.255.0")}}) = 0
ioctl(4, 0x8915, {ifr_name="lo", ifr_addr={AF_INET, inet_addr("127.0.0.1")}}) = 0
ioctl(4, 0x8913, {ifr_name="lo", ifr_flags=IFF_UP|IFF_LOOPBACK|IFF_RUNNING}) = 0
ioctl(4, 0x891b, {ifr_name="lo", ifr_netmask={AF_INET, inet_addr("255.0.0.0")}}) = 0
close(4) = 0
brk(0x595000) = 0x595000
brk(0x599000) = 0x599000
brk(0x59a000) = 0x59a000
exit(-1) = ?
