Flashing a Fritz!Box 7530 using tools/push_firmware
fb-help
22 Jun 2022
Hi everyone,
I am trying to flash a Fritz!Box 7530 with freetz-ng (from a Linux computer) using the push_firmware tool I found in the freetz-ng/tools directory.
The command always fails.
My closest attempt used the command:
tools/push_firmware images/7530_07.29.FREETZ-NG.image -cmd ftp -mr -ram 0 -ip 192.168.178.1
With this command I was able to detect the box, but the command fails like this:
* No reply from box, assuming switch-off or restart. Trying to re-detect box.
Waiting ............. found!
* Detected memsize: '0x10000000'
tools/push_firmware: line 92: 0 - ( 28547328 % 0 ) : division by 0 (error token is "0 ) ")
Does anyone know the correct options to pass to push_firmware to flash a 7530?
Thank you!
That's enough. Since the rest is already in the push tool.
I also thought this should work. Unfortunately, every time, it exits with:
"tools/push_firmware: line 92: 0 - ( 28547328 % 0 ) : division by 0 (error token is "0 ) ")"
Line 92 in the push_firmware script is: "ALIBYTES="$(( $ALIBYTES - ( $FILESIZE % $ALIBYTES ) ))""
It looks like ALIBYTES refers to the alignment, something that the script should use only in ram-boot or fit-boot modes. Because the alignment is set to zero this line produces division by zero. I have no idea what the alignment should be for a 7530 though ...
