[Dec 14 15:53:59 fritz kernel: imklog 3.18.6, log source = /proc/kmsg started.
Dec 14 15:53:59 fritz rsyslogd: [origin software="rsyslogd" swVersion="3.18.6" x-pid="6021" x-info="http://www.rsyslog.com"] restart
Dec 14 15:53:59 fritz kernel: Linux version 2.6.19.2 (2328) (gcc version 3.4.6) #1 Tue Jun 23 16:22:05 CEST 2009
Dec 14 15:53:59 fritz kernel: cpu-probe: Manufacturer MIPS
Dec 14 15:53:59 fritz kernel: mips-config1: JTAG pressent
Dec 14 15:53:59 fritz kernel: mips-config1: TLB size 16
Dec 14 15:53:59 fritz kernel: mips-config3: Vectored interrupts implmented
Dec 14 15:53:59 fritz kernel: CPU revision is: 00019068
Dec 14 15:53:59 fritz kernel: [mips_clock] default 360000000 MHz
Dec 14 15:53:59 fritz kernel: [ur8_clk_set_emif] SDRAM Refresh 0x3a8 Timing 0x2214717 Bank 0x21 Async 0xc42c301
Dec 14 15:53:59 fritz kernel: [ur8_pci_init]
Dec 14 15:53:59 fritz kernel: [pci] default: 33 MHz
Dec 14 15:53:59 fritz kernel: [setup_pci_master]
Dec 14 15:53:59 fritz kernel: [setup_pci_slave]
Dec 14 15:53:59 fritz kernel: Exposing 67108864 memory over PCI
Dec 14 15:53:59 fritz kernel: Setup Complete, Enabling PCI Interface
Dec 14 15:53:59 fritz kernel: PCI Interface Running
Dec 14 15:53:59 fritz kernel: PCI controller initialized
Dec 14 15:53:59 fritz kernel: [ur8_vbus_set_prio] instance vbus_nwss_dma level 2 escalator disabled (count 255, floor 7)
Dec 14 15:53:59 fritz kernel: [ur8_vbus_set_prio] instance vbus_sar_pdsp level 2 escalator disabled (count 255, floor 7)
Dec 14 15:53:59 fritz kernel: [ur8_vbus_set_prio] instance vbus_buffer_manager level 2 escalator disabled (count 255, floor 7)
Dec 14 15:53:59 fritz kernel: [ur8_vbus_set_prio] instance vbus_usb level 5 escalator disabled (count 255, floor 7)
Dec 14 15:53:59 fritz kernel: [ur8_vbus_set_prio] instance vbus_vlynq level 7 escalator disabled (count 255, floor 7)
Dec 14 15:53:59 fritz kernel: [ur8_vbus_set_prio] instance vbus_pci level 5 escalator disabled (count 255, floor 7)
Dec 14 15:53:59 fritz kernel: [ur8_vbus_set_prio] instance vbus_c55 level 3 escalator disabled (count 255, floor 7)
Dec 14 15:53:59 fritz kernel: [ur8_vbus_set_prio] instance vbus_tdm level 0 escalator disabled (count 255, floor 7)
Dec 14 15:53:59 fritz kernel: [ur8_vbus_set_prio] instance vbus_mips level 3 escalator disabled (count 255, floor 7)
Dec 14 15:53:59 fritz kernel: Determined physical RAM map:
Dec 14 15:53:59 fritz kernel: memory: 03fc0000 @ 14000000 (usable)
Dec 14 15:53:59 fritz kernel: memory: 00040000 @ 17fc0000 (reserved)
Dec 14 15:53:59 fritz kernel: [init_bootmem]
Dec 14 15:53:59 fritz kernel: [free_bootmem]
Dec 14 15:53:59 fritz kernel: [reserve_bootmem]
Dec 14 15:53:59 fritz kernel: On node 0 totalpages: 98240
Dec 14 15:53:59 fritz kernel: [mem_map-hack]: reduce size from 3145728 524288 Bytes
Dec 14 15:53:59 fritz kernel: [mem_map-hack]: move map base from 0x94328000 to 0x940a8000
Dec 14 15:53:59 fritz kernel: DMA zone: 767 pages used for memmap
Dec 14 15:53:59 fritz kernel: DMA zone: 0 pages reserved
Dec 14 15:53:59 fritz kernel: DMA zone: 97473 pages, LIFO batch:31
Dec 14 15:53:59 fritz kernel: Normal zone: 0 pages used for memmap
Dec 14 15:53:59 fritz kernel: [request_resource] Kernel code: start 0x14000000 < root->start 0x17fc0000
Dec 14 15:53:59 fritz kernel: [request_resource] Kernel data: start 0x14207790 < root->start 0x17fc0000
Dec 14 15:53:59 fritz kernel: Built 1 zonelists. Total pages: 97473
Dec 14 15:53:59 fritz kernel: Kernel command line: console=ttyS0,38400n8r
Dec 14 15:53:59 fritz kernel: Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Dec 14 15:53:59 fritz kernel: Primary data cache 16kB, 4-way, linesize 16 bytes.
Dec 14 15:53:59 fritz kernel: Synthesized TLB refill handler (20 instructions).
Dec 14 15:53:59 fritz kernel: Synthesized TLB load handler fastpath (32 instructions).
Dec 14 15:53:59 fritz kernel: Synthesized TLB store handler fastpath (32 instructions).
Dec 14 15:53:59 fritz kernel: Synthesized TLB modify handler fastpath (31 instructions).
Dec 14 15:53:59 fritz kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Dec 14 15:53:59 fritz kernel: CPU frequency 360.00 MHz
Dec 14 15:53:59 fritz kernel: Using 180.000 MHz high precision timer.
Dec 14 15:53:59 fritz kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 14 15:53:59 fritz kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 14 15:53:59 fritz kernel: [free_all_bootmem]
Dec 14 15:53:59 fritz kernel: Memory: 61056k/65280k available (2077k kernel code, 4136k reserved, 642k data, 140k init, 0k highmem)
Dec 14 15:53:59 fritz kernel: Calibrating delay loop... 359.62 BogoMIPS (lpj=1798144)
Dec 14 15:53:59 fritz kernel: Mount-cache hash table entries: 512
Dec 14 15:53:59 fritz kernel: Checking for 'wait' instruction... available.
Dec 14 15:53:59 fritz kernel: NET: Registered protocol family 16
Dec 14 15:53:59 fritz kernel: [ur8_mtd_init]
Dec 14 15:53:59 fritz kernel: [ur8_mtd_init] flashsize = 0x01000000 Byte 16 MBytes
Dec 14 15:53:59 fritz kernel: [ur8_mtd_init] mtd[0] = 0x90000000,0x90000000
Dec 14 15:53:59 fritz kernel: [ur8_mtd_init] mtd[1] = 0x90020000,0x90F80000
Dec 14 15:53:59 fritz kernel: [ur8_mtd_init] mtd[2] = 0x90000000,0x90020000
Dec 14 15:53:59 fritz kernel: [ur8_mtd_init] mtd[3] = 0x90F80000,0x90FC0000
Dec 14 15:53:59 fritz kernel: [ur8_mtd_init] mtd[4] = 0x90FC0000,0x91000000
Dec 14 15:53:59 fritz kernel: [ur8_mtd_init] mtd[5] = 0x90000000,0x90000000
Dec 14 15:53:59 fritz kernel: pcibios_read_config: accessing present PCI slot : 14, where 0, size 4
Dec 14 15:53:59 fritz kernel: Master and Slave Enabled
Dec 14 15:53:59 fritz kernel: pktsched: using high resolution timer
Dec 14 15:53:59 fritz kernel: NET: Registered protocol family 2
Dec 14 15:53:59 fritz kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Dec 14 15:53:59 fritz kernel: TCP established hash table entries: 16384 (order: 4, 65536 bytes)
Dec 14 15:53:59 fritz kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Dec 14 15:53:59 fritz kernel: TCP: Hash tables configured (established 16384 bind 8192)
Dec 14 15:53:59 fritz kernel: TCP reno registered
Dec 14 15:53:59 fritz kernel: squashfs: version 3.2 (2007/01/02) Phillip Lougher
Dec 14 15:53:59 fritz kernel: Installing knfsd (copyright (C) 1996 [email protected]).
Dec 14 15:53:59 fritz kernel: fuse init (API version 7.8)
Dec 14 15:53:59 fritz kernel: io scheduler noop registered (default)
Dec 14 15:53:59 fritz kernel: avm_net_trace: Up and running.
Dec 14 15:53:59 fritz kernel: [avm] configured: watchdog event debug enable direct gpio
Dec 14 15:53:59 fritz kernel: AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Jun 23 2009 16:19:44)
Dec 14 15:53:59 fritz kernel: Serial: 8250/16550 driver $Revision: 1.3 $ 1 ports, IRQ sharing disabled
Dec 14 15:53:59 fritz kernel: serial8250: ttyS0 at MMIO 0x0 (irq = 15) is a UR8_UART
Dec 14 15:53:59 fritz kernel: [cpmac] Version: URL: svn://EmbeddedVM/home/SVN/drivers/cpmac/tags/1.110-r820-trunk-VLAN_Fix_ADM_und_Tantos - Revision 538:821 - Di 23. Jun 16:20:50 CEST 2009
Dec 14 15:53:59 fritz kernel: [cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
Dec 14 15:53:59 fritz kernel: tun: Universal TUN/TAP device driver, 1.6
Dec 14 15:53:59 fritz kernel: tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Dec 14 15:53:59 fritz kernel: physmap platform flash device: 01000001 at 10000000
Dec 14 15:53:59 fritz kernel: physmap-flash.1: Found 1 x16 devices at 0x0 in 16-bit bank
Dec 14 15:53:59 fritz kernel: Amd/Fujitsu Extended Query Table at 0x0040
Dec 14 15:53:59 fritz kernel: physmap-flash.1: CFI does not contain boot bank location. Assuming top.
Dec 14 15:53:59 fritz kernel: number of CFI chips: 1
Dec 14 15:53:59 fritz kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Dec 14 15:53:59 fritz kernel: RedBoot partition parsing not available
Dec 14 15:53:59 fritz kernel: [ur8_jffs2_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x97f6243c
Dec 14 15:53:59 fritz kernel: [ur8_jffs2_parser_function] try partition kernel (offset 0x20000 len 16121856)
Dec 14 15:53:59 fritz kernel: [ur8_jffs2_parser_function] magic 20031985 found @pos 0x860000, size 7471104
Dec 14 15:53:59 fritz kernel: [ur8_squashfs_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x97f6243c
Dec 14 15:53:59 fritz kernel: [ur8_squashfs_parser_function] *p_mtd_pat->name filesystem
Dec 14 15:53:59 fritz kernel: [ur8_squashfs_parser_function] try partition kernel (offset 0x20000 len 16121856 blocksize=20000)
Dec 14 15:53:59 fritz kernel: [ur8_squashfs_parser_function] magic found @pos 0x103200
Dec 14 15:53:59 fritz kernel: 6 find_squashfs partitions found on MTD device physmap-flash.1
Dec 14 15:53:59 fritz kernel: Creating 6 MTD partitions on "physmap-flash.1":
Dec 14 15:53:59 fritz kernel: 0x00103200-0x00f80000 : "rootfs"
Dec 14 15:53:59 fritz kernel: mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] name rootfs
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] use rootfs
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] root device: /dev/mtdblock0 (rootfs)
Dec 14 15:53:59 fritz kernel: 0x00020000-0x00103200 : "kernel"
Dec 14 15:53:59 fritz kernel: mtd: partition "kernel" doesn't end on an erase block -- force read-only
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] name kernel
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] skip kernel
Dec 14 15:53:59 fritz kernel: 0x00000000-0x00020000 : "urlader"
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] name urlader
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] skip urlader
Dec 14 15:53:59 fritz kernel: 0x00f80000-0x00fc0000 : "tffs (1)"
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] name tffs (1)
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] skip tffs (1)
Dec 14 15:53:59 fritz kernel: 0x00fc0000-0x01000000 : "tffs (2)"
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] name tffs (2)
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] skip tffs (2)
Dec 14 15:53:59 fritz kernel: 0x00860000-0x00f80000 : "jffs2"
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] name jffs2
Dec 14 15:53:59 fritz kernel: [ur8_mtd_add_notifier] skip jffs2
Dec 14 15:53:59 fritz kernel: Generic platform RAM MTD, (c) 2004 Simtec Electronics
Dec 14 15:53:59 fritz kernel: mtd-ram mtd-ram.2: no memory resource specified
Dec 14 15:53:59 fritz kernel: [ur8_ram_mtd_set_rw] PLATRAM_RO
Dec 14 15:53:59 fritz kernel: mtd-ram: probe of mtd-ram.2 failed with error -2
Dec 14 15:53:59 fritz kernel: CAPI Subsystem Rev 1.1.2.8
Dec 14 15:53:59 fritz kernel: TCP cubic registered
Dec 14 15:53:59 fritz kernel: mcfw: IGMPv3 fast forwarding
Dec 14 15:53:59 fritz kernel: NET: Registered protocol family 17
Dec 14 15:53:59 fritz kernel: NET: Registered protocol family 8
Dec 14 15:53:59 fritz kernel: NET: Registered protocol family 20
Dec 14 15:53:59 fritz kernel: MUSB UR8 pdev active!
Dec 14 15:53:59 fritz kernel: PCI_STATUS_SET: 40000
Dec 14 15:53:59 fritz kernel: PCI_STATUS_CLR: 40000
Dec 14 15:53:59 fritz kernel: PCI_HOST_INT_EN: 0
Dec 14 15:53:59 fritz kernel: PCI_HOST_INT_CLR: 0
Dec 14 15:53:59 fritz kernel: PCI_BE_INT_En: 0
Dec 14 15:53:59 fritz kernel: PCI_BE_INT_CLR: 0
Dec 14 15:53:59 fritz kernel: [pci_int_init] done
Dec 14 15:53:59 fritz kernel: TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
Dec 14 15:53:59 fritz kernel: Time: MIPS clocksource has been installed.
Dec 14 15:53:59 fritz kernel: mount on mtd3 and mtd4 (double buffering)
Dec 14 15:53:59 fritz kernel: Adam2 environment variables API installed.
Dec 14 15:53:59 fritz kernel: [avm_new] push_button_gpio=25 value=0 enabled
Dec 14 15:53:59 fritz kernel: VFS: Mounted root (squashfs filesystem) readonly.
Dec 14 15:53:59 fritz kernel: Freeing prom memory: 0kb freed
Dec 14 15:53:59 fritz kernel: Freeing unused kernel memory: 140k freed
Dec 14 15:53:59 fritz kernel: AVM_WATCHDOG: System Init UEberwachung 240 Sekunden
Dec 14 15:53:59 fritz kernel: TFFS Name Table F
Dec 14 15:53:59 fritz kernel: led_modul_Fritz_Box_7270: module license '
Dec 14 15:53:59 fritz kernel: (C) Copyright 2008 by AVM
Dec 14 15:53:59 fritz kernel: ' taintskernel.
Dec 14 15:53:59 fritz kernel: [led_gpio_bit_driver_init] gpio 1 name power
Dec 14 15:53:59 fritz kernel: [led_gpio_bit_driver_init] gpio 9 name internet
Dec 14 15:53:59 fritz kernel: [led_gpio_bit_driver_init] gpio 27 name festnetz
Dec 14 15:53:59 fritz kernel: [led_gpio_bit_driver_init] gpio 28 name wlan
Dec 14 15:53:59 fritz kernel: [led_gpio_bit_driver_init] gpio 17 name dual1
Dec 14 15:53:59 fritz kernel: [led_gpio_bit_driver_init] gpio 35 name dual2
Dec 14 15:53:59 fritz kernel: [BUTTON] no buttons defined - disable new button controls
Dec 14 15:53:59 fritz kernel: [LED] "wyatt_earp_turn_off_leds" (0x00000000) not loaded
Dec 14 15:53:59 fritz kernel: [avm_new]push_button_ctrl: gpio=23 value=1 enabled
Dec 14 15:53:59 fritz kernel: [avm_new]push_button_ctrl:'Taster_4': enable=2 gpio=23 regaddr=00000000 button_type=0
Dec 14 15:53:59 fritz kernel: patch_dectfw: patch_adress: 7094 max_len: 22 with Version 2 Len: 16
Dec 14 15:53:59 fritz kernel: patch_dectfw: c0068000, datalen = 32159,
Dec 14 15:53:59 fritz kernel: [avm_new]push_button 'Taster_4', released: GPIO=23 presses=0 key=button_key_10
Dec 14 15:53:59 fritz kernel: **************************************************************
Dec 14 15:53:59 fritz kernel: dect_file_process: upload of '/lib/modules/dectfw_secondlevel.hex' successfull
Dec 14 15:53:59 fritz kernel: [piglet]bitfile '/lib/modules/microvoip_isdn_top.bit'
Dec 14 15:53:59 fritz kernel: [piglet] Read 169291 bytes total from file
Dec 14 15:53:59 fritz kernel: [piglet]TDM: FS: 8000 Hz CLK:2048000 Hz
Dec 14 15:53:59 fritz kernel: JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Dec 14 15:53:59 fritz kernel: loop: loaded (max 8 devices)
Dec 14 15:53:59 fritz kernel: [avm_debug]redirect kernel-messages (/dev/debug)
Dec 14 15:57:34 fritz mysqld_safe[6200]: 091214 15:57:34 [ERROR] /usr/sbin/mysqld: Can't find file: './mysql/db.frm' (errno: 13)
Dec 14 15:57:34 fritz mysqld_safe[6200]: ERROR: 1017 Can't find file: './mysql/db.frm' (errno: 13)
Dec 14 15:57:34 fritz mysqld_safe[6200]: 091214 15:57:34 [ERROR] Aborting
Dec 14 15:57:34 fritz mysqld_safe[6200]: 091214 15:57:34 [Note] /usr/sbin/mysqld: Shutdown complete
Dec 14 15:57:34 fritz mysqld_safe[6200]: Installation of system tables failed!
Dec 14 15:57:34 fritz mysqld_safe[6200]: Examine the logs in /var/lib/mysql for more information.
Dec 14 15:57:34 fritz mysqld_safe[6200]: You can try to start the mysqld daemon with:
Dec 14 15:57:34 fritz mysqld_safe[6200]: /usr/sbin/mysqld --skip-grant &
Dec 14 15:57:34 fritz mysqld_safe[6200]: and use the command line tool
Dec 14 15:57:34 fritz mysqld_safe[6200]: /usr/bin/mysql to connect to the mysql
Dec 14 15:57:34 fritz mysqld_safe[6200]: database and look at the grant tables:
Dec 14 15:57:34 fritz mysqld_safe[6200]: shell> /usr/bin/mysql -u root mysql
Dec 14 15:57:34 fritz mysqld_safe[6200]: mysql> show tables
Dec 14 15:57:34 fritz mysqld_safe[6200]: Try 'mysqld --help' if you have problems with paths. Using --log
Dec 14 15:57:34 fritz mysqld_safe[6200]: gives you a log in /var/lib/mysql that may be helpful.
Dec 14 15:57:34 fritz mysqld_safe[6200]: The latest information about MySQL is available on the web at
Dec 14 15:57:34 fritz mysqld_safe[6200]: http://www.mysql.com
Dec 14 15:57:34 fritz mysqld_safe[6200]: Please consult the MySQL manual section: 'Problems running mysql_install_db',
Dec 14 15:57:34 fritz mysqld_safe[6200]: and the manual section that describes problems on your OS.
Dec 14 15:57:34 fritz mysqld_safe[6200]: Another information source is the MySQL email archive.
Dec 14 15:57:34 fritz mysqld_safe[6200]: Please check all of the above before mailing us!
Dec 14 15:57:34 fritz mysqld_safe[6200]: And if you do mail us, you MUST use the /usr/bin/mysqlbug script!
Dec 14 15:57:38 fritz mysqld_safe[6236]: ERROR: 1146 Table 'mysql.user' doesn't exist
Dec 14 15:57:38 fritz mysqld_safe[6236]: 091214 15:57:38 [ERROR] Aborting
Dec 14 15:57:38 fritz mysqld_safe[6236]: 091214 15:57:38 [Note] /usr/sbin/mysqld: Shutdown complete
Dec 14 15:57:40 fritz mysqld_safe[6251]: ERROR: 1146 Table 'mysql.user' doesn't exist
Dec 14 15:57:40 fritz mysqld_safe[6251]: 091214 15:57:40 [ERROR] Aborting
Dec 14 15:57:40 fritz mysqld_safe[6251]: 091214 15:57:40 [Note] /usr/sbin/mysqld: Shutdown complete
Dec 14 15:57:41 fritz mysqld_safe[6258]: ERROR: 1146 Table 'mysql.user' doesn't exist
Dec 14 15:57:41 fritz mysqld_safe[6258]: 091214 15:57:41 [ERROR] Aborting
Dec 14 15:57:41 fritz mysqld_safe[6258]: 091214 15:57:41 [Note] /usr/sbin/mysqld: Shutdown complete
Dec 14 15:57:42 fritz mysqld_safe[6265]: ERROR: 1046 No database selected
Dec 14 15:57:42 fritz mysqld_safe[6265]: 091214 15:57:42 [ERROR] Aborting
Dec 14 15:57:42 fritz mysqld_safe[6265]: 091214 15:57:42 [Note] /usr/sbin/mysqld: Shutdown complete
Dec 14 15:57:51 fritz mysqld_safe[6371]: started
Dec 14 15:57:54 fritz mysqld[6375]: #007/usr/sbin/mysqld: Can't create/write to file '/tmp/ibs5NZN2' (Errcode: 13)
Dec 14 15:57:54 fritz mysqld[6375]: 091214 15:57:54 InnoDB: Error: unable to create temporary file; errno: 13
Dec 14 15:57:57 fritz mysqld[6375]: 091214 15:57:57 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.host' doesn't exist
Dec 14 15:57:57 fritz mysqld_safe[6400]: ended
Dec 14 15:58:27 fritz /etc/init.d/mysql[6511]: 0 processes alive and '/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf ping' resulted in
Dec 14 15:58:27 fritz /etc/init.d/mysql[6511]: #007/usr/bin/mysqladmin: connect to server at 'localhost' failed
Dec 14 15:58:27 fritz /etc/init.d/mysql[6511]: error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)'
Dec 14 15:58:27 fritz /etc/init.d/mysql[6511]: Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists!
