Fehler bei MAKE: STEP2 Modify: patching bar-style and cache-usage
C
colonia27
Guest
ich befürchte zwar fast, daß der Fehler irgendwo bei mir liegt, nur leider wüsste ich nicht wo. Deshalb dieser Thread.
Neu ausgecheckter freetz-trunk_r3265 mit angehängter .config.
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_7270_04_70=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
# FREETZ_TYPE_FON_WLAN_7240 is not set
FREETZ_TYPE_FON_WLAN_7270=y
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_SPEEDPORT_W701V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_FON_WLAN_7270_16MB=y
FREETZ_TYPE_LABOR=y
# FREETZ_TYPE_LABOR_AURA is not set
# FREETZ_TYPE_LABOR_DSL is not set
# FREETZ_TYPE_LABOR_IPV6 is not set
# FREETZ_TYPE_LABOR_MINI is not set
FREETZ_TYPE_LABOR_PHONE=y
# FREETZ_TYPE_LABOR_WLAN is not set
FREETZ_AVM_VERSION_STRING="7270_04.70"
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_A_CH is not set
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_LANG_STRING="de"
FREETZ_TYPE_STRING="7270_labor_phone"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
# Replace kernel (currently not available)
FREETZ_SHOW_ADVANCED=y
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_KERNEL_MTD_SIZE=246
FREETZ_HAS_PHONE=y
FREETZ_HAS_TAM=y
FREETZ_HAS_WLAN=y
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
FREETZ_HAS_AVM_INETD=y
# Mod ------------------------------------
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
# Patches
# Remove Brandings
FREETZ_REMOVE_BRANDING_1und1=y
# FREETZ_REMOVE_BRANDING_avm is not set
FREETZ_REMOVE_HELP=y
# FREETZ_REMOVE_ASSISTANT is not set
# FREETZ_REMOVE_TR069 is not set
# FREETZ_PATCH_DSL_EXPERT is not set
# FREETZ_PATCH_ENUM is not set
FREETZ_PATCH_SIGNED=y
FREETZ_PATCH_USBSTORAGE=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT2=y
FREETZ_AUTOMOUNT_EXT3=y
# FREETZ_AUTOMOUNT_NTFS is not set
# FREETZ_AUTOMOUNT_REISER_FS is not set
FREETZ_AUTORUN_AUTOEND=y
FREETZ_PATCH_MAXDEVCOUNT=y
# FREETZ_PATCH_GETCONS is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_USERMAN is not set
FREETZ_REMOVE_FTPD=y
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_AVM_VPN is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_DECT is not set
# FREETZ_REMOVE_DTRACE is not set
# FREETZ_REMOVE_VOIP_ISDN is not set
# FREETZ_REMOVE_WLAN is not set
# FREETZ_REMOVE_ANNEX_B_FIRMWARE is not set
# FREETZ_ADD_ANNEX_A_FIRMWARE is not set
# Package selection
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
FREETZ_PACKAGE_CIFSMOUNT=y
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNSMASQ is not set
FREETZ_PACKAGE_DROPBEAR=y
# FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY is not set
FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
# FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER is not set
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_OPENNTPD is not set
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_STATIC=y
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
# FREETZ_PACKAGE_OPENVPN_WITH_MGMNT is not set
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
FREETZ_PACKAGE_STUNNEL=y
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_VPNC is not set
FREETZ_PACKAGE_VSFTPD=y
FREETZ_PACKAGE_VSFTPD_WITH_SSL=y
FREETZ_PACKAGE_VSFTPD_STATIC=y
# Web interface
FREETZ_PACKAGE_AVM_FIREWALL=y
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
FREETZ_PACKAGE_ONLINECHANGED_CGI=y
# FREETZ_PACKAGE_RRDSTATS is not set
FREETZ_PACKAGE_SPINDOWN_CGI=y
FREETZ_PACKAGE_SG3UTILS=y
FREETZ_PACKAGE_SYSLOGD_CGI=y
FREETZ_PACKAGE_TRANSMISSION_CGI=y
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
FREETZ_PACKAGE_WOL_CGI=y
# Debug helpers
FREETZ_PACKAGE_LDD=y
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Testing
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
FREETZ_PACKAGE_DAVFS2=y
FREETZ_DAVFS2_WITH_SSL=y
FREETZ_DAVFS2_WITH_ZLIB=y
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
FREETZ_PACKAGE_LIGHTTPD=y
FREETZ_PACKAGE_LIGHTTPD_WITH_SSL=y
FREETZ_PACKAGE_LIGHTTPD_WITH_ZLIB=y
FREETZ_PACKAGE_LIGHTTPD_LDD=y
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_ACCESSLOG is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_ALIAS is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_AUTH is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_CGI is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_CML is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_COMPRESS is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_DIRLISTING is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_EVASIVE is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_EVHOST is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_EXPIRE is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_EXTFORWARD is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_FASTCGI is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_MAGNET is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_FLV_STREAMING is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_MYSQL_VHOST is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_PROXY is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_REDIRECT is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_REWRITE is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_RRDTOOL is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_SCGI is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_SECDOWNLOAD is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_SETENV is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_SIMPLE_VHOST is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_SSI is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_STATUS is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_TRIGGER_B4_DL is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_USERDIR is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_USERTRACK is not set
# FREETZ_PACKAGE_LIGHTTPD_NO_MOD_WEBDAV is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MDEV is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OWFS is not set
FREETZ_PACKAGE_PHP=y
FREETZ_PHP_STATIC=y
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TINYPROXY is not set
FREETZ_PACKAGE_TRANSMISSION=y
FREETZ_PACKAGE_TRANSMISSION_CLIENT=y
FREETZ_PACKAGE_TRANSMISSION_DAEMON=y
FREETZ_PACKAGE_TRANSMISSION_REMOTE=y
FREETZ_PACKAGE_TRANSMISSION_STATIC=y
FREETZ_PACKAGE_TRANSMISSION_WEBINTERFACE=y
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
FREETZ_SHOW_UNSTABLE_PACKAGES=y
# Unstable
# FREETZ_PACKAGE_COLLECTD is not set
FREETZ_PACKAGE_HPLIP=y
# FREETZ_PACKAGE_HPLIP_DESKJET is not set
FREETZ_PACKAGE_HPLIP_PHOTOSMART=y
# FREETZ_PACKAGE_HPLIP_OFFICEJET is not set
# FREETZ_PACKAGE_HPLIP_PSC is not set
# FREETZ_PACKAGE_HPLIP_LASERJET is not set
# FREETZ_PACKAGE_HPLIP_COLOR_LASERJET is not set
# FREETZ_PACKAGE_HPLIP_OTHER is not set
# FREETZ_HPLIP_PRINTER_TYPE_HP_PHOTOSMART is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_100 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_1115 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_1215 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_1218 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_130 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_1315 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_140_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_230 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_240_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_2570_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_2600_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_2700_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_3100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_3200_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_320_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_3300_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_330_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_370_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_380_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_420_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_470_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7150 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7200_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7345 is not set
FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7350=y
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7400_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7550 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7600_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7700_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7800_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_7900_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_8000_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_8100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_8200_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_8400_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_8700_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A310_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A320_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A430_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A440_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A510_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A520_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A530_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A610_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A620_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A630_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A710_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_A820_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_B8500_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C3100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C4100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C4200_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C4340_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C4380_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C4400_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C4500_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C5100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C5200_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C5300_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C5500_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C6100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C6200_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C6300_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C7100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C7200_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_C8100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D5060_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D5100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D5300_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D5400_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D6100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D7100_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D7200_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D7300_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D7400_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_D7500_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_P1000 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_P1100 is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_PRO_B8300_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_PRO_B8800_SERIES is not set
# FREETZ_HPLIP_PRINTER_TYPE_PHOTOSMART_PRO_B9100_SERIES is not set
FREETZ_HPLIP_PRINTER_TYPE="photosmart_7350"
FREETZ_PACKAGE_HP_UTILS=y
# FREETZ_PACKAGE_IPTABLES is not set
# SANE
FREETZ_PACKAGE_SANE_BACKENDS=y
FREETZ_LIB_libsane=y
# FREETZ_SANE_sane_find_scanner is not set
# FREETZ_SANE_scanimage is not set
FREETZ_SANE_BACKEND_dll=y
# FREETZ_SANE_BACKEND_abaton is not set
# FREETZ_SANE_BACKEND_agfafocus is not set
# FREETZ_SANE_BACKEND_apple is not set
# FREETZ_SANE_BACKEND_artec is not set
# FREETZ_SANE_BACKEND_artec_eplus48u is not set
# FREETZ_SANE_BACKEND_as6e is not set
# FREETZ_SANE_BACKEND_avision is not set
# FREETZ_SANE_BACKEND_bh is not set
# FREETZ_SANE_BACKEND_canon is not set
# FREETZ_SANE_BACKEND_canon630u is not set
# FREETZ_SANE_BACKEND_cardscan is not set
# FREETZ_SANE_BACKEND_coolscan is not set
# FREETZ_SANE_BACKEND_coolscan2 is not set
# FREETZ_SANE_BACKEND_dc25 is not set
# FREETZ_SANE_BACKEND_dmc is not set
# FREETZ_SANE_BACKEND_epjitsu is not set
# FREETZ_SANE_BACKEND_epson is not set
# FREETZ_SANE_BACKEND_epson2 is not set
# FREETZ_SANE_BACKEND_fujitsu is not set
# FREETZ_SANE_BACKEND_genesys is not set
# FREETZ_SANE_BACKEND_gt68xx is not set
# FREETZ_SANE_BACKEND_hp is not set
# FREETZ_SANE_BACKEND_hp3500 is not set
# FREETZ_SANE_BACKEND_hp3900 is not set
# FREETZ_SANE_BACKEND_hp4200 is not set
# FREETZ_SANE_BACKEND_hp5400 is not set
# FREETZ_SANE_BACKEND_hp5590 is not set
# FREETZ_SANE_BACKEND_hpljm1005 is not set
# FREETZ_SANE_BACKEND_hs2p is not set
# FREETZ_SANE_BACKEND_ibm is not set
# FREETZ_SANE_BACKEND_leo is not set
# FREETZ_SANE_BACKEND_lexmark is not set
# FREETZ_SANE_BACKEND_ma1509 is not set
# FREETZ_SANE_BACKEND_matsushita is not set
# FREETZ_SANE_BACKEND_microtek is not set
# FREETZ_SANE_BACKEND_microtek2 is not set
# FREETZ_SANE_BACKEND_mustek is not set
# FREETZ_SANE_BACKEND_mustek_usb is not set
# FREETZ_SANE_BACKEND_nec is not set
# FREETZ_SANE_BACKEND_niash is not set
# FREETZ_SANE_BACKEND_pie is not set
# FREETZ_SANE_BACKEND_pixma is not set
# FREETZ_SANE_BACKEND_plustek is not set
# FREETZ_SANE_BACKEND_ricoh is not set
# FREETZ_SANE_BACKEND_s9036 is not set
# FREETZ_SANE_BACKEND_sceptre is not set
# FREETZ_SANE_BACKEND_sharp is not set
# FREETZ_SANE_BACKEND_sm3600 is not set
# FREETZ_SANE_BACKEND_sm3840 is not set
# FREETZ_SANE_BACKEND_snapscan is not set
# FREETZ_SANE_BACKEND_sp15c is not set
# FREETZ_SANE_BACKEND_st400 is not set
# FREETZ_SANE_BACKEND_stv680 is not set
# FREETZ_SANE_BACKEND_tamarack is not set
# FREETZ_SANE_BACKEND_teco1 is not set
# FREETZ_SANE_BACKEND_teco2 is not set
# FREETZ_SANE_BACKEND_teco3 is not set
# FREETZ_SANE_BACKEND_test is not set
# FREETZ_SANE_BACKEND_u12 is not set
# FREETZ_SANE_BACKEND_umax is not set
# FREETZ_SANE_BACKEND_umax_pp is not set
# FREETZ_SANE_BACKEND_umax1220u is not set
# FREETZ_SANE_BACKEND_plustek_pp is not set
# FREETZ_SANE_BACKEND_dc210 is not set
# FREETZ_SANE_BACKEND_dc240 is not set
# FREETZ_SANE_BACKEND_qcam is not set
# FREETZ_SANE_BACKEND_v4l is not set
# FREETZ_SANE_BACKEND_net is not set
# FREETZ_SANE_BACKEND_mustek_usb2 is not set
# FREETZ_PACKAGE_TINC is not set
# FREETZ_PACKAGE_USBIP is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
FREETZ_DL_OVERRIDE=y
FREETZ_DL_SOURCE="fritz_box-labor-7270-14067.image"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: http://freetz.3dfxatwork.de
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: http://freetz.wirsind.info
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: http://freetz.magenbrot.net
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_VERBOSITY_LEVEL=2
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
# FREETZ_SUBVERSION_STRING is not set
[COLOR=Red][B]FREETZ_STATUS_STYLE=y[/B][/COLOR]
FREETZ_AVMPLUGINS_ENABLED=y
# Plugin selection
# Select plugin(s) for insertion
FREETZ_AVMPLUGINS_MEDIASRV=y
FREETZ_AVMPLUGINS_MINI=y
FREETZ_AVMPLUGINS_NTFS=y
FREETZ_AVMPLUGINS_SAMBA=y
FREETZ_AVMPLUGINS_TAM=y
# External
EXTERNAL_ENABLED=y
EXTERNAL_SUBDIRS=y
EXTERNAL_CREATEPAK=y
EXTERNAL_DIR1=y
# EXTERNAL_DIR2 is not set
# EXTERNAL_DIR3 is not set
# EXTERNAL_CUSTOM_DIR is not set
EXTERNAL_DIRECTORY="/var/media/ftp/uStor01/external/"
EXTERNAL_OWN_FILES=""
# packages
EXTERNAL_FREETZ_PACKAGE_LDD=y
EXTERNAL_FREETZ_PACKAGE_PHP=y
EXTERNAL_FREETZ_PACKAGE_STUNNEL=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_CLIENT=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_DAEMON=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_REMOTE=y
EXTERNAL_FREETZ_PACKAGE_TRANSMISSION_WEBINTERFACE=y
# services
EXTERNAL_FREETZ_PACKAGE_OPENVPN=y
# libraries
EXTERNAL_FREETZ_LIB_libcrypto=y
EXTERNAL_FREETZ_LIB_libiconv=y
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_DIFF is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_IP is not set
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
# FREETZ_BUSYBOX_FASTPROC is not set
# FREETZ_BUSYBOX_KEYS is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_TAC is not set
# FREETZ_BUSYBOX_MDEV_RENAME is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
# Kernel modules
# crypto
# FREETZ_MODULE_crypto_algapi is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_blkcipher is not set
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_cryptomgr is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_musb_hdrc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# fs
FREETZ_MODULE_cifs=y
FREETZ_MODULE_coda=y
FREETZ_MODULE_ext3=y
FREETZ_MODULE_ext2=y
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_fuse is not set
FREETZ_MODULE_jbd=y
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
FREETZ_MODULE_mbcache=y
# lib
# FREETZ_MODULE_crc_ccitt is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Shared libraries
# FREETZ_STRIP_LIBRARIES is not set
# Libraries -------------------------------
# FREETZ_LIB_libatm is not set
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
FREETZ_LIB_libssl=y
# FREETZ_LIB_libavmhmac is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
FREETZ_LIB_libz=y
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
# FREETZ_LIB_libresolv is not set
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# FREETZ_LIB_libuClibc__ is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libglib_1 is not set
# GLib2
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# FREETZ_LIB_libcapi20 is not set
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libevent is not set
FREETZ_LIB_libexpat=y
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_libmad is not set
FREETZ_LIB_libneon=y
FREETZ_LIB_libneon_WITH_SSL=y
FREETZ_LIB_libneon_WITH_ZLIB=y
# FREETZ_LIB_libpcap is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
FREETZ_LIB_libusb=y
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
FREETZ_LIB_libfreetz=y
FREETZ_LIB_libpcre=y
# Compiler options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
# FREETZ_KERNEL_VERSION_2_6_13_1 is not set
FREETZ_KERNEL_VERSION_2_6_19_2=y
FREETZ_KERNEL_VERSION="2.6.19.2"
# FREETZ_TARGET_UCLIBC_VERSION_0_9_28 is not set
FREETZ_TARGET_UCLIBC_VERSION_0_9_29=y
FREETZ_TARGET_GCC_VERSION="4.2.1"
FREETZ_TARGET_UCLIBC_VERSION="0.9.29"
FREETZ_TARGET_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
FREETZ_TARGET_CCACHE=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# FREETZ_TARGET_TOOLCHAIN is not set
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
und hier die Fehlermeldung beim einbinden der patche:
    applying patch file ./patches/cond/bar-style_n_cache-usage.patch
    patching file usr/mww/cgi-bin/status.cgi
    can't find file to patch at input line 79
    Perhaps you used the wrong -p or --strip option?
    The text leading up to this was:
    |diff -Naur -x .svn usr/lib/cgi-bin/mod/mounted.cgi usr/lib/cgi-bin/mod/mounted.cgi
    |--- usr/lib/cgi-bin/mod/mounted.cgi    2008-04-06 09:22:26.000000000 +0200
    |+++ usr/lib/cgi-bin/mod/mounted.cgi    2008-04-07 15:50:25.000000000 +0200
    File to patch:
    Skip this patch? [y]
    Skipping patch.
    1 out of 1 hunk ignored
ERROR: modpatch: Error in patch-file ./patches/cond/bar-style_n_cache-usage.patch
make: *** [firmware-nocompile] Fehler 2
Kann mir jemand sagen wo der Fehler liegt, oder wie ich ihn selbst finden kann?
Hi.
Dein Fehler hat die gleiche Ursache wie hier. Den Patch kannst du auch als Fix nehmen.
Mach danach aber nochmal ein svn up.
MfG Oliver
@Oliver,
danke erstmal für die Info. Leider komme ich nicht so recht weiter.
Generell ist das Einspielen eines patches kein Problem, aber wie mache ich aus deinem "Eclipse Workspace Patch" von hier ein xyz.patch Datei?
Reicht das wenn ich einfach per
nano xyz.patch
die Datei anlege und deinen Code einfüge?
Anschliessend diese dann im frisch ausgecheckten freetz-Hauptordner ausführe ??
Wenn ich es so mache, kommt leider folgendes:
guido@Ubuntu-VM:~/7270/freetz-trunk_r3269$ patch -p0 < xyz.patch
patching file make/Makefile.in
Hunk #1 FAILED at 390.
1 out of 1 hunk FAILED -- saving rejects to file make/Makefile.in.rej
Daher gehe ich mal davon aus, daß ich irgendwo nen Fehler mache oder es einfach falsch verstehe.
Wär echt super, wenn du mir da nen Denkansoß verpassen könntest.
Werds auch niiiieeee wieder vergessen :rolleyes:
Ich häng das nochmal als Patch an.
MfG Oliver
Generell machst du das schon richtig mit dem Patch. Was da oben in den Kommentaren des Patches steht, ist relativ egal. Da könnte nun auch "Olivers persönliches Patchfile" stehen ;)
Ich tippe bei dir eigentlich auf DOS-Linefeeds oder so etwas, muss ich sagen, oder zu viele Leerzeichen oder Zeilenumbrüche, die beim Copy&Paste mit reingekommen sind.
Schau dir mal die Meldungen in "make/Makefile.in.rej" an, was da falsch läuft oder korrigier die beiden Zeilen im Makefile notfalls von Hand, ist in dem Falle ja nichts gravierendes.
Ganz im Notfall hängst du dein .patch-File hier an, und es schaut mal jemand drüber.
Ist natürlich auch ne Lösung, die ich gerne annehme. :groesste:
Dennoch interessiert mich der Weg wie ich aus deinem Code einen patch erstellen kann/könnte.
Ich befürchte nämlich, daß ich sowas nochmal brauchen werde ;)
[Edit] sorry Silent-Tears, dein post kam noch dazwischen. Ich prüf jetzt erstmal meinen patch und die .rej
Wenn ichs dann nicht hinbekomme, poste ich den mal hier.
Kleine Frage noch: In Olivers Code steht in Klammern was von (revision 3262) bzw. in seinem jetzt dort angehängtem patch (revision 3263). Muß ich dementsprechend dieses freetz-revision auschecken oder kann ich auch diesen einfach anpassen indem ich dort etwa (revision 3269) eintrage? Ist das überhaupt nötig??
Wie ich sagte, das war eigentlich der Patch. Es kommt nur oft zu copy&paste-Fehlern und anderen Problemen, wie ich schon anmerkte.
Wie schon geschrieben wurde, war das der Patch.
Mögliche Fehler insbesondere bei Makefiles sind, wenn man statt Tabulatoren, die in der Original-Datei sind, Leerzeichen in den Patch aufnimmt.
Oder wenn die Tabulatoren erst gar nicht richtig dargestellt werden. Das könnte hier durchaus der Grund sein, die Tabulatoren werden hier nur mit einem Leerzeichen dargestellt.
Eine andere Fehlerquelle, die bereits erwähnt wurde, sind die Zeilenumbrüche. Wenn man die Datei aber mit einem Linux-Editor erstellt, sollte das auch nicht passieren.
Das Patch-Programm betrachtet die Patch-Datei als Anweisung, um eine andere Datei zu ändern. Und wenn die Inhalte nicht übereinstimmen, dann wird die Änderung nicht durchgeführt.
Eine nützliche Option in diesem Zusammenhang ist --ignore-whitespace.
Die Sache mit dne Linefeeds ist wahrscheinlicher, denn Olivers Eclipse schmeisst da immer mal wieder DOS-Linefededs raus ;)
In diesem Fall nicht, denn zum einen werden die DOS-CRs nicht übernommen, wenn man den Text im Browser kopiert und in ein Putty-Fenster in einem Linux-Editor einfügt.
Und zum anderen habe ich mir die Dateien angeschaut:
Makefile.in ab Zeile 389 schrieb:
$($(PKG)_FREETZ_CONFIG_FILE): $(TOPDIR)/.config
        @($(foreach OPT,$($(PKG)_CONFIG_SUBOPTS),echo "$(OPT)=$(if $($(OPT)),y,n)";) : ) > $($(PKG)_FREETZ_CONFIG_TEMP)
        @if ! diff -q $($(PKG)_FREETZ_CONFIG_TEMP) $($(PKG)_FREETZ_CONFIG_FILE) 2> /dev/null; then \
                mv $($(PKG)_FREETZ_CONFIG_TEMP) $($(PKG)_FREETZ_CONFIG_FILE); \
                        $(RM) -r $($(PKG)_TARGET_DIR); \
                        $(RM) $(PACKAGES_DIR)/.$(pkg)-$($(PKG)_VERSION); \
        else \
                $(RM) $($(PKG)_FREETZ_CONFIG_TEMP); \
        fi
### Eclipse Workspace Patch 1.0
#P freetz-trunk
Index: make/Makefile.in
--- make/Makefile.in (revision 3262)
+++ make/Makefile.in (working copy)
@@ -390,8 +390,6 @@
-   $(RM) -r $($(PKG)_TARGET_DIR); \
-   $(RM) $(PACKAGES_DIR)/.$(pkg)-$($(PKG)_VERSION); \
  else \
  fi
Wobei im oberen Beispiel statt Tabulatoren 8 Leerzeichen stehen, und im Patch steht für einen Tabulator ein Leerzeichen.
Das Gute ist, daß --ignore-whitespace sowohl bei Tabulatoren/Leerzeichen als auch bei überflüssigen CRs hilft.
Soo, hab jetzt mal ein wenig rumexperimentiert bzw. gepatcht und bin zu folgendem Ergebnis gekommen:
Olivers gezippte Version des patches funktioniert einwandfrei.
Die Textversion zum selbsterstellen des patches hat wohl wirklich ein Tab/Space-Problem.
Aber über die --ignore-whitespace Option klappt es auch damit.
Demnach sind meine Probleme erstmal keine mehr und ich hab Dank euch wieder was gelernt. Die --ignore...-Geschichte kannte ich noch gar nicht.
