ÿýÿý!ÿûÿû
BusyBox v1.00-pre3 (2005.08.18-11:29+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
HWRevision='76'
ANNEX='B'
ANNEX_PTEST_FILE='ptest-results-0'
ANNEX_PTEST_HOST='192.168.178.20'
ANNEX_TEST='0'
OEM='avm'
Language='de'
Country='049'
TZ='CET-1CEST,M3.5.0,M10.5.0'
CONFIG_AB_COUNT='3'
CONFIG_ANNEX='B'
CONFIG_ASSIST='y'
CONFIG_ATA='y'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_BLUETOOTH='n'
CONFIG_BLUETOOTH_CTP='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='y'
CONFIG_CAPI_MIPS='n'
CONFIG_CAPI_UBIK='y'
CONFIG_CAPI_XILINX='n'
CONFIG_CDROM='y'
CONFIG_CDROM_FALLBACK='n'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_ETH_COUNT='2'
CONFIG_FIRMWARE_URL='http://www.avm.de/fritzbox-firmware-update.php?hardware=76&oem=avm&language=de&country='
CONFIG_FON='y'
CONFIG_HOMEI2C='n'
CONFIG_HOSTNAME='fritz.fonwlan.box'
CONFIG_I2C='n'
CONFIG_INSTALL_TYPE='ar7_ubik2_4MB_2eth_3ab_isdn_nt_te_pots_wlan_50494'
CONFIG_NFS='n'
CONFIG_OEM_DEFAULT='avm'
CONFIG_PRODUKT='Fritz_Box_7050'
CONFIG_PRODUKT_NAME='FRITZ!Box Fon WLAN 7050'
CONFIG_RAMSIZE='32'
CONFIG_ROMSIZE='4'
CONFIG_SERVICEPORTAL_URL='http://www.avm.de/fritzbox-service-portal.php?hardware=76&oem=avm&language=de&country='
CONFIG_STOREUSRCFG='y'
CONFIG_SUBVERSION=''
CONFIG_UBIK2='y'
CONFIG_USB='y'
CONFIG_USB_HOST_AVM='n'
CONFIG_USB_HOST_TI='n'
CONFIG_USB_PRINT_SERV='n'
CONFIG_USB_STORAGE='n'
CONFIG_USB_WLAN_AUTH='n'
CONFIG_VERSION='03.86'
CONFIG_VERSION_MAJOR='14'
CONFIG_VLYNQ0='1'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='y'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='n'
ermittle die aktuelle TTY
tty is "/dev/pts/0"
Console Ausgaben auf dieses Terminal umgelenkt
# Oct 29 17:40:12 voipd[388]: <<< Request: OPTIONS sip:XXX-ZENSIERT-XXX
Oct 29 17:40:12 voipd[388]: >>> Status: 200 OK
killall telefon
killall: telefon: no process killed
# telefon
telefon: use clock_gettime(CLOCK_MONOTONIC)!
telefon: set initial telefon time from linux time to 17:40 29.10 2005!
sizeof TA_DATA = 0x2da4!
telefon: Read TA_Charge ignorerd!
telefon: mount file '/var/flash/fx_def' id: 99!
mknod: /var/flash/fx_def: File exists
telefon: file '/var/flash/fx_def' id: 99 mounted!
telefon: ERROR No config file '/var/flash/fx_def' !
Setupdaten geslesen!
telefon: mount file '/var/flash/fx_cg' id: 132!
mknod: /var/flash/fx_cg: File exists
telefon: file '/var/flash/fx_cg' id: 132 mounted!
telefon: ERROR No CG file '/var/flash/fx_cg' !
telefon: found SIP Controller 5
telefon: found POTS Controller 4
telefon: found ISDN Controller 2
telefon: found ISDN_NT Controller 3
AB_LED: Power On
InitAnalog ExternalXSC: 10
# telefon: socket accept from: 127.0.0.1
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (0) returns 2
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (1) returns 2
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (2) returns 2
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (3) returns 2
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (4) returns 2
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (5) returns 2
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (6) returns 2
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (7) returns 2
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (8) returns 2
Oct 29 17:40:31 cltmgr[312]: sipX/connect - SipConnStatusGet (9) returns 2
Oct 29 17:40:38 voipd[388]: is_register_allowed - running (voip=0)
Oct 29 17:40:38 voipd[388]: 0: connected vcc 1/32/PPPoE/32 stay online 1
Oct 29 17:40:38 voipd[388]: 0: ip 80.146.38.214/217.0.116.129 mtu 1492 dns 217.237.151.225/217.237.150.225
Oct 29 17:40:38 voipd[388]: [email][email protected][/email]: REGISTER starting
Oct 29 17:40:38 voipd[388]: dns: _sip._udp.aolphonereg.aol.de: query
Oct 29 17:40:38 voipd[388]: dns; _sip._udp.aolphonereg.aol.de: not found
Oct 29 17:40:38 voipd[388]: >>> Request: REGISTER sip:aolphonereg.aol.de
Oct 29 17:40:38 voipd[388]: <<< Status: 200 Ok
Oct 29 17:40:38 voipd[388]: [email][email protected][/email]: REGISTER end
Oct 29 17:40:38 voipd[388]: [email][email protected][/email]: REGISTER (sip:[email protected]) complete (next in 140 seconds)
Das hier?
Irgendwie kommen immer andere Fehler... Jetzt habe ich vom Handy angerufen und als eingehender Anruf wurde nur "02922" angezeigt anstatt 49170xxxxxxx
Namensermittling über Das Örtliche demnach auch "unbekannter Teilnehmer"
Programm ist aber nicht abgeschmiert...
