- Mitglied seit
- 20 Sep 2008
- Beiträge
- 42
- Punkte für Reaktionen
- 0
- Punkte
- 0
export AB_TEST='0'
export ANNEX='B'
export ANNEX_PTEST_FILE='ptest-results-0'
export ANNEX_PTEST_HOST='192.168.178.20'
export ANNEX_TEST='0'
export CAPISERV_TEST='0'
export CONFIG_AB_COUNT='3'
export CONFIG_ANNEX='B'
export CONFIG_ASSIST='y'
export CONFIG_ATA='y'
export CONFIG_ATA_FULL='n'
export CONFIG_AUDIO='n'
export CONFIG_AURA='n'
export CONFIG_BLUETOOTH='n'
export CONFIG_BLUETOOTH_CTP='n'
export CONFIG_BUTTON='n'
export CONFIG_CAPI='y'
export CONFIG_CAPI_MIPS='n'
export CONFIG_CAPI_NT='y'
export CONFIG_CAPI_POTS='y'
export CONFIG_CAPI_TE='y'
export CONFIG_CAPI_UBIK='y'
export CONFIG_CAPI_XILINX='n'
export CONFIG_CDROM='y'
export CONFIG_CDROM_FALLBACK='n'
export CONFIG_DECT='n'
export CONFIG_DSL='y'
export CONFIG_ENVIRONMENT_PATH='/proc/sys/dev
export CONFIG_ETH_COUNT='2'
export CONFIG_FIRMWARE_URL='http://www.avm.de
are=76&oem=avm&language=de&country='
export CONFIG_FON='y'
export CONFIG_HOMEI2C='n'
export CONFIG_HOSTNAME='fritz.fonwlan.box'
export CONFIG_I2C='n'
export CONFIG_INSTALL_TYPE='ar7_ubik2_4MB_2et
export CONFIG_JFFS2='n'
export CONFIG_KIDS='n'
export CONFIG_LED_NO_DSL_LED='n'
export CONFIG_MAILER='y'
export CONFIG_MEDIACLI='n'
export CONFIG_MEDIASRV='n'
export CONFIG_NAND='n'
export CONFIG_NFS='n'
export CONFIG_OEM_DEFAULT='avm'
export CONFIG_PRODUKT='Fritz_Box_7050'
export CONFIG_PRODUKT_NAME='FRITZ!Box Fon WLA
export CONFIG_RAMSIZE='32'
export CONFIG_RELEASE='1'
export CONFIG_ROMSIZE='4'
export CONFIG_SERVICEPORTAL_URL='http://www.a
ardware=76&oem=avm&language=de&country=&versi
export CONFIG_STOREUSRCFG='y'
export CONFIG_SUBVERSION=''
export CONFIG_SWAP='n'
export CONFIG_TAM='n'
export CONFIG_TAM_MODE='0'
export CONFIG_TR069='n'
export CONFIG_UBIK2='y'
export CONFIG_UPNP='y'
export CONFIG_USB='y'
export CONFIG_USB_HOST_AVM='n'
export CONFIG_USB_HOST_TI='n'
export CONFIG_USB_PRINT_SERV='n'
export CONFIG_USB_STORAGE='n'
export CONFIG_USB_WLAN_AUTH='n'
export CONFIG_VDSL='n'
export CONFIG_VERSION='04.23'
export CONFIG_VERSION_MAJOR='14'
export CONFIG_VLYNQ='y'
export CONFIG_VLYNQ0='1'
export CONFIG_VLYNQ1='0'
export CONFIG_VPN='n'
export CONFIG_WLAN='y'
export CONFIG_WLAN_1130TNET='y'
export CONFIG_WLAN_1350TNET='n'
export CONFIG_WLAN_GREEN='n'
export CONFIG_WLAN_WDS='y'
export CONFIG_XILINX='n'
export Country='049'
export DISABLE_WLAN='0'
export ETC_CONFIG_PATH='/etc/init.d/rc.init'
export HOME='/'
export HWRevision='76'
export HWRevision_ATA='1'
export HWRevision_BitFileCount=''
export Language='de'
export OEM='avm'
export OEM_DEFAULT_INDEX=''
export OLDPWD='/'
export PATH='/bin:/usr/bin:/sbin:/usr/sbin'
export PTEST_SERVER='192.168.178.20'
export PWD='/'
export SHELL='/bin/sh'
export TERM='vt102'
export TZ='CET-1CEST,M3.5.0,M10.5.0'
export USB_HOST_TEST='0'
export USER='root'
export WLAN_CAL='0'
export WLAN_TEST='0'
export enable_ata='1'
export prevlevel='N'
export reset_status='3'
export runlevel='S'
helpHWRevision='76'
HWRevision_ATA='1'
HWRevision_Reserved1='0'
ANNEX='B'
ANNEX_TEST='0'
OEM='avm'
OEM_tmp='avm'
Language='de'
Country='049'
CONFIG_AB_COUNT='3'
CONFIG_ANNEX='B'
CONFIG_ASSIST='y'
CONFIG_ATA='y'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_AURA='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='y'
CONFIG_CAPI_NT='y'
CONFIG_CAPI_TE='y'
CONFIG_CDROM='y'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_ENVIRONMENT='/var/env'
CONFIG_ENVIRONMENT_PATH='/proc/sys/dev/adam2'
CONFIG_FIRMWARE_URL='http://www.avm.de/fritzbox-firmware-update.
CONFIG_FON='y'
CONFIG_HOMEI2C='n'
CONFIG_I2C='n'
CONFIG_INSTALL_TYPE='ar7_ubik2_4MB_2eth_3ab_isdn_nt_te_pots_wlan
CONFIG_JFFS2='n'
CONFIG_KIDS='n'
CONFIG_MAILER='y'
CONFIG_MEDIACLI='n'
CONFIG_MEDIASRV='n'
CONFIG_NAND='n'
CONFIG_NFS='n'
CONFIG_PRODUKT_NAME='FRITZ!Box Fon WLAN 7050'
CONFIG_RAMSIZE='32'
CONFIG_RELEASE='1'
CONFIG_ROMSIZE='4'
CONFIG_SERVICEPORTAL_URL='http://www.avm.de/fritzbox-service-por
=76&oem=avm&language=de&country=&version=14.04.23&subversion='
CONFIG_SWAP='n'
CONFIG_TAM='n'
CONFIG_TAM_MODE='0'
CONFIG_TR069='n'
CONFIG_UBIK2='y'
CONFIG_UPNP='y'
CONFIG_USB='y'
CONFIG_VDSL='n'
CONFIG_VLYNQ='y'
CONFIG_VLYNQ0='1'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='y'
CONFIG_WLAN_WDS='y'
CONFIG_XILINX='n'
ermittle die aktuelle TTY
tty is "/dev/pts/0"
Console Ausgaben auf dieses Terminal umgelenkt
# help
Glaubst du, dass die Box jetzt auf AVM ist ?
Das sagt sie ja in der Telnet-Ausgabe.
Leider komme ich immer noch nicht auf das Interface. (
