capifax v0.7.3 (c) Marco Zissen
[libcapifax] 14.11.2011 03:15:37 - libcapifax v0.7.3 (c) 2008-2009 Marco Zissen
[libcapifax] 14.11.2011 03:15:37 - Found controller #1 with 2 B-channel(s)
[libcapifax] 14.11.2011 03:15:37 - Found controller #2 with 2 B-channel(s)
[libcapifax] 14.11.2011 03:15:37 - Found controller #3 with 2 B-channel(s)
[libcapifax] 14.11.2011 03:15:37 - Found controller #4 with 1 B-channel(s)
[libcapifax] 14.11.2011 03:15:37 - Found controller #5 with 5 B-channel(s)
[libcapifax] 14.11.2011 03:15:37 - Found 5 controllers!
[libcapifax] 14.11.2011 03:15:37 - Listen to controller #5 ...
[libcapifax] 14.11.2011 03:15:37 - capifax_init(ctrl: 5, loglevel: 3, ev_status: 1000d71c, ev_progress: 1000d720, ev_log: 1000d724)
[libcapifax] 14.11.2011 03:15:37 - libcapifax successfully initialized!
[libcapifax] 14.11.2011 03:15:37 - capifax_send(tiff: mytiff.tiff, modem: 2, ecm: on, controller: 5, src: ---, trg: ---, ident: +00 00 0000000, header: (null), anonymous: 0)
[libcapifax] 14.11.2011 03:15:37 - REQ: CONNECT (--- -> ---)
[libcapifax] 14.11.2011 03:15:37 - CNF: CAPI_LISTEN
[libcapifax] 14.11.2011 03:15:37 - CNF: CAPI_CONNECT - (PLCI: 1029)
OUTGOING FAX
Phase: 1
Connection: 0
Src-No: ---
Dst-No: ---
[libcapifax] 14.11.2011 03:15:38 - IND: CAPI_CONNECT - CON: -1, PLCI: 1285, NCCI: 0 - IGNORING (--- <- 1#0731---)
[libcapifax] 14.11.2011 03:15:56 - IND: CAPI_CONNECT_ACTIVE - CON: 0, PLCI: 1029, NCCI: 0
[libcapifax] 14.11.2011 03:15:56 - CNF: CAPI_CONNECT_B3
[libcapifax] 14.11.2011 03:15:56 - IND: CAPI_CONNECT_B3_ACTIVE - CON: 0, PLCI: 1029, NCCI: 132101
[libcapifax] 14.11.2011 03:15:56 - 1970/01/01 02:09:41.485 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 18
[libcapifax] 14.11.2011 03:15:56 - 1970/01/01 02:09:41.501 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 18
[libcapifax] 14.11.2011 03:15:58 - 1970/01/01 02:09:43.357 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 18
[libcapifax] 14.11.2011 03:16:02 - 1970/01/01 02:09:47.148 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 18
[libcapifax] 14.11.2011 03:16:02 - 1970/01/01 02:09:47.211 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 18
[libcapifax] 14.11.2011 03:16:02 - 1970/01/01 02:09:47.491 00:00:00.000 FLOW T.30 HDLC signal status is Framing OK (-6) in state 18
[libcapifax] 14.11.2011 03:16:02 - 1970/01/01 02:09:47.491 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_A_CNG to T30_PHASE_B_RX
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 Rx: DIS with final frame tag
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 Rx: ff 13 80 20 ee 9a c4 80 d7 83 80 80 20
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 In state 18
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 DIS:
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ..1. ....= V.8 capabilities: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .0.. ....= Preferred octets: 256 octets
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ...0= Ready to transmit a fax document (polling): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ..1.= Can receive fax: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ..10 11..= Supported data signalling rates: V.27 ter, V.29, and V.17
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 1... ....= 2-D coding: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ..10= Recording width: 215mm +- 1, 255mm +- 1 0x1.dc2c40p-1021nd 303mm +- 1
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .001 ....= Receiver's minimum scan line time: 5ms at 3.85 l/mm; T7.7 = T3.85
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ...0= "Field not valid" supported: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ..0.= Multiple selective polling: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... .0..= Polled sub-address: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... 0...= T.43 coding: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ...0 ....= Plane interleave: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ..0. ....= Voice coding with 32kbit/s ADPCM (Rec. G.726): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .0.. ....= Reserved for the use of extended voice coding set: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ...1= R8x15.4lines/mm: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ..1.= 300x300pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... .1..= R16x15.4lines/mm and/or 400x400pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... 0...= Inch-based resolution preferred: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ...1 ....= Metric-based resolution preferred: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ..0. ....= Minimum scan line time for higher resolutions: T15.4 = T7.7
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .1.. ....= Selective polling: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ...1= Sub-addressing: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ..1.= Password: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... .0..= Ready to transmit a data file (polling): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ...0 ....= Binary file transfer (BFT): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ..0. ....= Document transfer mode (DTM): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .0.. ....= Electronic data interchange (EDI): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ...0= Basic transfer mode (BTM): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... .0..= Ready to transfer a character or mixed mode document (polling): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... 0...= Character mode: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ..0. ....= Mixed mode (Annex E/T.4): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ...0= Processable mode 26 (Rec. T.505): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ..0.= Digital network capability: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... .0..= Duplex capability: Half only
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... 0...= JPEG coding: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ...0 ....= Full colour mode: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .0.. ....= 12bits/pel component: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ...0= No subsampling (1:1:1): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... ..0.= Custom illuminant: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... .0..= Custom gamut range: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .... 0...= North American Letter (215.9mm x 279.4mm): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ...0 ....= North American Legal (215.9mm x 355.6mm): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 ..1. ....= Single-progression sequential coding (Rec. T.85) basic: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 .0.. ....= Single-progression sequential coding (Rec. T.85) optional L0: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 Selected compression 3
[libcapifax] 14.11.2011 03:16:05 - Phase B handler (0x80) DIS
[libcapifax] 14.11.2011 03:16:05 - Phase B: bit rate 9600
[libcapifax] 14.11.2011 03:16:05 - Phase B: ECM on
SENDING FAX (START)
Phase: 2
Connection: 0
Bitrate: 9600
Encoding: 0
Bad rows: 0
Page: 1 / 0
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 Trying to send file 'mytiff.tiff'
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 Start sending document
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.003 00:00:00.000 FLOW T.30 Minimum bits per row will be 0
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 Starting page 1 of transfer
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 Partial page buffer contains 7 frames (256 per frame)
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 ..00 01..= Selected data signalling rate: V.29, 9600bps
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 Changing from state 18 to 4
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 Sending ident '+00 00 0000000'
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 Tx: TSI without final frame tag
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.019 00:00:00.000 FLOW T.30 Tx: ff 03 43 30 30 30 30 30 30 30 20 30 30 20 30 30 2b 20 20 20 20 20 20
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.143 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 4
[libcapifax] 14.11.2011 03:16:05 - 1970/01/01 02:09:50.143 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_RX to T30_PHASE_B_TX
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 ..00 01..= Selected data signalling rate: V.29, 9600bps
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 Tx: DCS with final frame tag
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:51.781 00:00:00.000 FLOW T.30 Tx: ff 13 83 00 46 f8 44
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:52.093 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:52.171 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:52.171 00:00:00.000 FLOW T.30 Changing from state 4 to 5
[libcapifax] 14.11.2011 03:16:07 - 1970/01/01 02:09:52.171 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_TX to T30_PHASE_C_NON_ECM_TX
[libcapifax] 14.11.2011 03:16:09 - 1970/01/01 02:09:54.324 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_C_NON_ECM_TX, state 5
[libcapifax] 14.11.2011 03:16:09 - 1970/01/01 02:09:54.324 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_C_NON_ECM_TX to T30_PHASE_B_RX
[libcapifax] 14.11.2011 03:16:09 - 1970/01/01 02:09:54.324 00:00:00.000 FLOW T.30 Start T4
[libcapifax] 14.11.2011 03:16:09 - 1970/01/01 02:09:54.324 00:00:00.000 FLOW T.30 Changing from state 5 to 6
[libcapifax] 14.11.2011 03:16:09 - 1970/01/01 02:09:54.340 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:09 - 1970/01/01 02:09:54.465 00:00:00.000 FLOW T.30 HDLC signal status is Abort (-8) in state 6
[libcapifax] 14.11.2011 03:16:10 - 1970/01/01 02:09:54.714 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 6
[libcapifax] 14.11.2011 03:16:10 - 1970/01/01 02:09:54.777 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:10 - 1970/01/01 02:09:54.995 00:00:00.000 FLOW T.30 HDLC signal status is Framing OK (-6) in state 6
[libcapifax] 14.11.2011 03:16:10 - 1970/01/01 02:09:54.995 00:00:00.000 FLOW T.30 Start T4A
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.103 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 6
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.103 00:00:00.000 FLOW T.30 Start T4B
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 T4B expired in phase T30_PHASE_B_RX, state 6. The line is now quiet.
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 T4 expired in phase T30_PHASE_B_RX, state 6
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 Retry number 1
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_RX to T30_PHASE_B_TX
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 ..00 01..= Selected data signalling rate: V.29, 9600bps
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 Changing from state 6 to 4
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 Sending ident '+00 00 0000000'
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 Tx: TSI without final frame tag
[libcapifax] 14.11.2011 03:16:11 - 1970/01/01 02:09:56.290 00:00:00.000 FLOW T.30 Tx: ff 03 43 30 30 30 30 30 30 30 20 30 30 20 30 30 2b 20 20 20 20 20 20
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 ..00 01..= Selected data signalling rate: V.29, 9600bps
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 Tx: DCS with final frame tag
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:57.943 00:00:00.000 FLOW T.30 Tx: ff 13 83 00 46 f8 44
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:58.271 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:58.365 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:58.365 00:00:00.000 FLOW T.30 Changing from state 4 to 5
[libcapifax] 14.11.2011 03:16:13 - 1970/01/01 02:09:58.365 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_TX to T30_PHASE_C_NON_ECM_TX
[libcapifax] 14.11.2011 03:16:15 - 1970/01/01 02:10:00.502 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_C_NON_ECM_TX, state 5
[libcapifax] 14.11.2011 03:16:15 - 1970/01/01 02:10:00.502 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_C_NON_ECM_TX to T30_PHASE_B_RX
[libcapifax] 14.11.2011 03:16:15 - 1970/01/01 02:10:00.502 00:00:00.000 FLOW T.30 Start T4
[libcapifax] 14.11.2011 03:16:15 - 1970/01/01 02:10:00.502 00:00:00.000 FLOW T.30 Changing from state 5 to 6
[libcapifax] 14.11.2011 03:16:15 - 1970/01/01 02:10:00.533 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:16 - 1970/01/01 02:10:00.892 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 6
[libcapifax] 14.11.2011 03:16:16 - 1970/01/01 02:10:01.001 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:16 - 1970/01/01 02:10:01.141 00:00:00.000 FLOW T.30 HDLC signal status is Framing OK (-6) in state 6
[libcapifax] 14.11.2011 03:16:16 - 1970/01/01 02:10:01.141 00:00:00.000 FLOW T.30 Start T4A
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 Rx: FTT with final frame tag
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 Rx: ff 13 44
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 In state 6
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 Trainability test failed
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 ..00 11..= Selected data signalling rate: V.29 7200bps
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 Changing from state 6 to 4
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 Sending ident '+00 00 0000000'
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 Tx: TSI without final frame tag
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.234 00:00:00.000 FLOW T.30 Tx: ff 03 43 30 30 30 30 30 30 30 20 30 30 20 30 30 2b 20 20 20 20 20 20
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.343 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 4
[libcapifax] 14.11.2011 03:16:17 - 1970/01/01 02:10:02.343 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_RX to T30_PHASE_B_TX
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 ..00 11..= Selected data signalling rate: V.29 7200bps
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 Tx: DCS with final frame tag
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:03.981 00:00:00.000 FLOW T.30 Tx: ff 13 83 00 4e f8 44
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:04.293 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:04.386 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:04.386 00:00:00.000 FLOW T.30 Changing from state 4 to 5
[libcapifax] 14.11.2011 03:16:19 - 1970/01/01 02:10:04.386 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_TX to T30_PHASE_C_NON_ECM_TX
[libcapifax] 14.11.2011 03:16:21 - 1970/01/01 02:10:06.524 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_C_NON_ECM_TX, state 5
[libcapifax] 14.11.2011 03:16:21 - 1970/01/01 02:10:06.524 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_C_NON_ECM_TX to T30_PHASE_B_RX
[libcapifax] 14.11.2011 03:16:21 - 1970/01/01 02:10:06.524 00:00:00.000 FLOW T.30 Start T4
[libcapifax] 14.11.2011 03:16:21 - 1970/01/01 02:10:06.524 00:00:00.000 FLOW T.30 Changing from state 5 to 6
[libcapifax] 14.11.2011 03:16:22 - 1970/01/01 02:10:06.555 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:22 - 1970/01/01 02:10:06.898 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 6
[libcapifax] 14.11.2011 03:16:22 - 1970/01/01 02:10:07.023 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:22 - 1970/01/01 02:10:07.179 00:00:00.000 FLOW T.30 HDLC signal status is Framing OK (-6) in state 6
[libcapifax] 14.11.2011 03:16:22 - 1970/01/01 02:10:07.179 00:00:00.000 FLOW T.30 Start T4A
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 Rx: FTT with final frame tag
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 Rx: ff 13 44
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 In state 6
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 Trainability test failed
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 ..00 10..= Selected data signalling rate: V.27ter 4800bps
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 Changing from state 6 to 4
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 Sending ident '+00 00 0000000'
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 Tx: TSI without final frame tag
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.255 00:00:00.000 FLOW T.30 Tx: ff 03 43 30 30 30 30 30 30 30 20 30 30 20 30 30 2b 20 20 20 20 20 20
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.364 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 4
[libcapifax] 14.11.2011 03:16:23 - 1970/01/01 02:10:08.364 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_RX to T30_PHASE_B_TX
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 ..00 10..= Selected data signalling rate: V.27ter 4800bps
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 Tx: DCS with final frame tag
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.049 00:00:00.000 FLOW T.30 Tx: ff 13 83 00 4a f8 44
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.330 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.424 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.424 00:00:00.000 FLOW T.30 Changing from state 4 to 5
[libcapifax] 14.11.2011 03:16:25 - 1970/01/01 02:10:10.424 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_TX to T30_PHASE_C_NON_ECM_TX
[libcapifax] 14.11.2011 03:16:28 - 1970/01/01 02:10:13.091 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_C_NON_ECM_TX, state 5
[libcapifax] 14.11.2011 03:16:28 - 1970/01/01 02:10:13.091 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_C_NON_ECM_TX to T30_PHASE_B_RX
[libcapifax] 14.11.2011 03:16:28 - 1970/01/01 02:10:13.091 00:00:00.000 FLOW T.30 Start T4
[libcapifax] 14.11.2011 03:16:28 - 1970/01/01 02:10:13.091 00:00:00.000 FLOW T.30 Changing from state 5 to 6
[libcapifax] 14.11.2011 03:16:28 - 1970/01/01 02:10:13.107 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:28 - 1970/01/01 02:10:13.310 00:00:00.000 FLOW T.30 HDLC signal status is Abort (-8) in state 6
[libcapifax] 14.11.2011 03:16:28 - 1970/01/01 02:10:13.434 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 6
[libcapifax] 14.11.2011 03:16:29 - 1970/01/01 02:10:13.637 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:29 - 1970/01/01 02:10:13.778 00:00:00.000 FLOW T.30 HDLC signal status is Framing OK (-6) in state 6
[libcapifax] 14.11.2011 03:16:29 - 1970/01/01 02:10:13.778 00:00:00.000 FLOW T.30 Start T4A
[libcapifax] 14.11.2011 03:16:29 - 1970/01/01 02:10:13.840 00:00:00.000 FLOW T.30 HDLC signal status is Abort (-8) in state 6
[libcapifax] 14.11.2011 03:16:29 - 1970/01/01 02:10:13.902 00:00:00.000 FLOW T.30 HDLC signal status is Abort (-8) in state 6
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:14.932 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 6
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:14.932 00:00:00.000 FLOW T.30 Start T4B
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 T4B expired in phase T30_PHASE_B_RX, state 6. The line is now quiet.
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 T4 expired in phase T30_PHASE_B_RX, state 6
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 Retry number 1
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_RX to T30_PHASE_B_TX
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 ..00 10..= Selected data signalling rate: V.27ter 4800bps
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 Changing from state 6 to 4
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 Sending ident '+00 00 0000000'
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 Tx: TSI without final frame tag
[libcapifax] 14.11.2011 03:16:30 - 1970/01/01 02:10:15.135 00:00:00.000 FLOW T.30 Tx: ff 03 43 30 30 30 30 30 30 30 20 30 30 20 30 30 2b 20 20 20 20 20 20
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 DCS:
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .... ...0= Store and forward Internet fax (T.37): Not set
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .... .0..= Real-time Internet fax (T.38): Not set
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .... 0...= 3G mobile network: Not set
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .... ..1.= Receive fax: Set
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 ..00 10..= Selected data signalling rate: V.27ter 4800bps
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .1.. ....= R8x7.7lines/mm and/or 200x200pels/25.4mm: Set
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 0... ....= 2-D coding: Not set
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .... ..00= Recording width: 215mm +- 1
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .... 10..= Recording length: Unlimited
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .111 ....= Minimum scan line time: 0ms
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 1... ....= Extension indicator: Set
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .... ..0.= Compressed/uncompressed mode: Compressed
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .... .1..= Error correction mode (ECM): ECM
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .... 0...= Frame size: 256 octets
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 .1.. ....= T.6 coding: Set
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 0... ....= Extension indicator: Not set
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 Tx: DCS with final frame tag
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:16.773 00:00:00.000 FLOW T.30 Tx: ff 13 83 00 4a f8 44
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:17.100 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:17.194 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_B_TX, state 4
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:17.194 00:00:00.000 FLOW T.30 Changing from state 4 to 5
[libcapifax] 14.11.2011 03:16:32 - 1970/01/01 02:10:17.194 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_TX to T30_PHASE_C_NON_ECM_TX
[libcapifax] 14.11.2011 03:16:35 - 1970/01/01 02:10:19.862 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_C_NON_ECM_TX, state 5
[libcapifax] 14.11.2011 03:16:35 - 1970/01/01 02:10:19.862 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_C_NON_ECM_TX to T30_PHASE_B_RX
[libcapifax] 14.11.2011 03:16:35 - 1970/01/01 02:10:19.862 00:00:00.000 FLOW T.30 Start T4
[libcapifax] 14.11.2011 03:16:35 - 1970/01/01 02:10:19.862 00:00:00.000 FLOW T.30 Changing from state 5 to 6
[libcapifax] 14.11.2011 03:16:35 - 1970/01/01 02:10:19.893 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:35 - 1970/01/01 02:10:20.252 00:00:00.000 FLOW T.30 HDLC signal status is Carrier down (-1) in state 6
[libcapifax] 14.11.2011 03:16:36 - 1970/01/01 02:10:21.032 00:00:00.000 FLOW T.30 HDLC signal status is Carrier up (-2) in state 6
[libcapifax] 14.11.2011 03:16:36 - 1970/01/01 02:10:21.172 00:00:00.000 FLOW T.30 HDLC signal status is Framing OK (-6) in state 6
[libcapifax] 14.11.2011 03:16:36 - 1970/01/01 02:10:21.172 00:00:00.000 FLOW T.30 Start T4A
[libcapifax] 14.11.2011 03:16:37 - 1970/01/01 02:10:22.264 00:00:00.000 FLOW T.30 Rx: DCN with final frame tag
[libcapifax] 14.11.2011 03:16:37 - 1970/01/01 02:10:22.264 00:00:00.000 FLOW T.30 Rx: ff 13 fa
[libcapifax] 14.11.2011 03:16:37 - 1970/01/01 02:10:22.264 00:00:00.000 FLOW T.30 In state 6
[libcapifax] 14.11.2011 03:16:37 - 1970/01/01 02:10:22.264 00:00:00.000 FLOW T.30 Disconnecting
[libcapifax] 14.11.2011 03:16:37 - 1970/01/01 02:10:22.264 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_B_RX to T30_PHASE_E
[libcapifax] 14.11.2011 03:16:37 - 1970/01/01 02:10:22.264 00:00:00.000 FLOW T.30 Changing from state 6 to 2
[libcapifax] 14.11.2011 03:16:38 - 1970/01/01 02:10:23.294 00:00:00.000 FLOW T.30 Send complete in phase T30_PHASE_E, state 2
[libcapifax] 14.11.2011 03:16:38 - Phase E handler (0xE) Received bad response to DCS or training
[libcapifax] 14.11.2011 03:16:38 - Phase E: pages transferred 0
[libcapifax] 14.11.2011 03:16:38 - Phase E: image resolution 8031 x 7700
[libcapifax] 14.11.2011 03:16:38 - Phase E: compression type 3
[libcapifax] 14.11.2011 03:16:38 - Phase E: coding method T.6
SENDING FAX (END)
Phase: 4
Connection: 0
Bitrate: 4800
Encoding: 3
Bad rows: 0
Page: 0 / 1
[libcapifax] 14.11.2011 03:16:38 - 1970/01/01 02:10:23.294 00:00:00.000 FLOW T.30 Changing from state 2 to 32
[libcapifax] 14.11.2011 03:16:38 - 1970/01/01 02:10:23.294 00:00:00.000 FLOW T.30 Changing from phase T30_PHASE_E to T30_PHASE_CALL_FINISHED
[libcapifax] 14.11.2011 03:16:38 - CAPI 0x3490 - Normal call clearing
[libcapifax] 14.11.2011 03:16:38 - IND: CAPI_DISCONNECT - CON: 0, PLCI: 1029, NCCI: 0
SENDING FAX (FAILED 14)
Phase: 6
Connection: 0
Bitrate: 4800
Encoding: 3
Bad rows: 0
Page: 0 / 1
[libcapifax] 14.11.2011 03:16:39 - libcapifax v0.7.3 closed!
capifax exited!
