# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# User competence ------------------------
# FREETZ_USER_LEVEL_BEGINNER is not set
# FREETZ_USER_LEVEL_ADVANCED is not set
FREETZ_USER_LEVEL_EXPERT=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_EXPERT=y
# Hardware/Firmware ----------------------
# FREETZ_TYPE_300IP is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_WLAN is not set
# FREETZ_TYPE_W501V is not set
# FREETZ_TYPE_2170 is not set
# WLAN
# FREETZ_TYPE_3020 is not set
# FREETZ_TYPE_3030 is not set
# FREETZ_TYPE_3130 is not set
# FREETZ_TYPE_3131 is not set
# FREETZ_TYPE_3170 is not set
# FREETZ_TYPE_3270_V2 is not set
# FREETZ_TYPE_3270_V3 is not set
# FREETZ_TYPE_3272 is not set
# FREETZ_TYPE_3370 is not set
# FREETZ_TYPE_3390 is not set
# Fon
# FREETZ_TYPE_5010 is not set
# FREETZ_TYPE_5050 is not set
# FREETZ_TYPE_5124 is not set
# FREETZ_TYPE_5140 is not set
# LTE
# FREETZ_TYPE_6810 is not set
# FREETZ_TYPE_6840 is not set
# FREETZ_TYPE_6842 is not set
# Fon WLAN
# FREETZ_TYPE_7050 is not set
# FREETZ_TYPE_7112 is not set
# FREETZ_TYPE_7113 is not set
# FREETZ_TYPE_7140 is not set
# FREETZ_TYPE_7141 is not set
# FREETZ_TYPE_7150 is not set
# FREETZ_TYPE_7170 is not set
# FREETZ_TYPE_7240 is not set
# FREETZ_TYPE_7270_V1 is not set
# FREETZ_TYPE_7270_V2 is not set
# FREETZ_TYPE_7270_V3 is not set
# FREETZ_TYPE_7272 is not set
# FREETZ_TYPE_7312 is not set
# FREETZ_TYPE_7320 is not set
# FREETZ_TYPE_7330_XL is not set
# FREETZ_TYPE_7330_SL is not set
# FREETZ_TYPE_7340 is not set
# FREETZ_TYPE_7360_XL is not set
# FREETZ_TYPE_7360_SL is not set
# FREETZ_TYPE_7362 is not set
FREETZ_TYPE_7390=y
# FREETZ_TYPE_7490 is not set
# VDSL
# FREETZ_TYPE_7570 is not set
# Custom
# FREETZ_TYPE_CUSTOM is not set
# FREETZ_TYPE_LANG_DE is not set
FREETZ_TYPE_LANG_EN=y
# FREETZ_TYPE_FIRMWARE_05_2X is not set
FREETZ_TYPE_FIRMWARE_05_5X=y
# FREETZ_TYPE_FIRMWARE_EWE_05_5X is not set
FREETZ_TYPE_FIRMWARE_FINAL=y
FREETZ_TYPE_LANGUAGE="en"
# FREETZ_TYPE_ALIEN_HARDWARE is not set
# Original components --------------------
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_REPLACE_KERNEL=y
# SquashFS options
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_262144 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_524288 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_1048576 is not set
FREETZ_SQUASHFS_BLOCKSIZE=65536
# Removal patches
# Removal patches ------------------------
FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_DIFFS=y
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_PRIME is not set
# Remove piglet
# FREETZ_REMOVE_ASSISTANT is not set
# FREETZ_REMOVE_AHA is not set
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_NAS is not set
# FREETZ_REMOVE_FHEM is not set
# FREETZ_REMOVE_AVM_VPN is not set
# Remove brandings
# FREETZ_REMOVE_BRANDING_avme is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_CHRONYD is not set
# FREETZ_REMOVE_DECT is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_RAMZSWAP is not set
# FREETZ_REMOVE_LSOF is not set
FREETZ_REMOVE_SOCAT=y
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_NTFS is not set
FREETZ_REMOVE_PRINTSERV=y
# FREETZ_REMOVE_PRINTSERV_MODULE is not set
# FREETZ_REMOVE_RUNCLOCK is not set
# FREETZ_REMOVE_SAMBA is not set
# FREETZ_REMOVE_SUPPORT is not set
# FREETZ_REMOVE_TR069 is not set
FREETZ_REMOVE_UMTSD=y
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_KIDS is not set
# FREETZ_REMOVE_QOS is not set
FREETZ_REMOVE_AVM_E2FSPROGS=y
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_TELEPHONY is not set
# FREETZ_REMOVE_WEBDAV is not set
# FREETZ_REMOVE_WLAN is not set
# Other patches
# Web menu patches -----------------------
# FREETZ_PATCH_ATA is not set
# FREETZ_PATCH_SIGNED is not set
# USB patches --------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT2=y
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_EXT4=y
FREETZ_AUTOMOUNT_FAT=y
# FREETZ_AUTOMOUNT_HFS is not set
# FREETZ_AUTOMOUNT_HFS_PLUS is not set
# FREETZ_AUTOMOUNT_LUKS is not set
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTOMOUNT_LINUXSWAP is not set
FREETZ_PATCH_MAXDEVCOUNT=y
# FREETZ_CUSTOM_UDEV_RULES is not set
# Replacement patches --------------------
# FREETZ_REPLACE_SSL_LIBS is not set
# FREETZ_REPLACE_DTRACE is not set
# FREETZ_REPLACE_ONLINECHANGED is not set
# Additional patches ---------------------
FREETZ_ADD_ETCSERVICES=y
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
FREETZ_AVMDAEMON_DISABLE_NTP=y
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
# FREETZ_AVMDAEMON_DISABLE_TR069 is not set
# FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS is not set
# Additional components ------------------
# Packages
# *** not all packages support selected language ***
# FREETZ_SELECTED_LANG_ONLY is not set
# Debug helpers
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
FREETZ_PACKAGE_LDD=y
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_TARGET_TESTER is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AUTOSSH is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BITTWIST is not set
FREETZ_PACKAGE_BLUEZ_UTILS=y
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CNTLM is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DANTE is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_DVBSNOOP is not set
# FREETZ_PACKAGE_DVBSTREAM is not set
# FREETZ_PACKAGE_DVBTUNE is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# E-MailRelay (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FOWSR is not set
# FREETZ_PACKAGE_FSTYP is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_GHOSTSCRIPT_FONTS is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNTPSEND is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HAPROXY is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTML2TEXT is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTPDATE is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_IMAGEMAGICK is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INADYN_OPENDNS is not set
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_INETD_TIME is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPSEC_TOOLS is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_JS is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_LFTP is not set
FREETZ_PACKAGE_LIGHTTPD=y
FREETZ_PACKAGE_LIGHTTPD_WITH_SSL=y
# FREETZ_PACKAGE_LIGHTTPD_USE_CYASSL is not set
FREETZ_PACKAGE_LIGHTTPD_LDD=y
# FREETZ_PACKAGE_LIGHTTPD_WITH_LUA is not set
# lighttpd Modules
# Select the modules you want to be included in the image
FREETZ_PACKAGE_LIGHTTPD_MOD_ACCESS=y
FREETZ_PACKAGE_LIGHTTPD_MOD_DIRLISTING=y
FREETZ_PACKAGE_LIGHTTPD_MOD_INDEXFILE=y
FREETZ_PACKAGE_LIGHTTPD_MOD_STATICFILE=y
FREETZ_PACKAGE_LIGHTTPD_MOD_ACCESSLOG=y
FREETZ_PACKAGE_LIGHTTPD_MOD_ALIAS=y
FREETZ_PACKAGE_LIGHTTPD_MOD_AUTH=y
FREETZ_PACKAGE_LIGHTTPD_MOD_CGI=y
FREETZ_PACKAGE_LIGHTTPD_MOD_COMPRESS=y
FREETZ_PACKAGE_LIGHTTPD_MOD_EVASIVE=y
FREETZ_PACKAGE_LIGHTTPD_MOD_EVHOST=y
FREETZ_PACKAGE_LIGHTTPD_MOD_EXPIRE=y
FREETZ_PACKAGE_LIGHTTPD_MOD_EXTFORWARD=y
FREETZ_PACKAGE_LIGHTTPD_MOD_FASTCGI=y
FREETZ_PACKAGE_LIGHTTPD_MOD_FLV_STREAMING=y
FREETZ_PACKAGE_LIGHTTPD_MOD_PROXY=y
FREETZ_PACKAGE_LIGHTTPD_MOD_REDIRECT=y
FREETZ_PACKAGE_LIGHTTPD_MOD_REWRITE=y
FREETZ_PACKAGE_LIGHTTPD_MOD_RRDTOOL=y
FREETZ_PACKAGE_LIGHTTPD_MOD_SCGI=y
FREETZ_PACKAGE_LIGHTTPD_MOD_SECDOWNLOAD=y
FREETZ_PACKAGE_LIGHTTPD_MOD_SETENV=y
FREETZ_PACKAGE_LIGHTTPD_MOD_SIMPLE_VHOST=y
FREETZ_PACKAGE_LIGHTTPD_MOD_SSI=y
FREETZ_PACKAGE_LIGHTTPD_MOD_STATUS=y
FREETZ_PACKAGE_LIGHTTPD_MOD_TRIGGER_B4_DL=y
FREETZ_PACKAGE_LIGHTTPD_MOD_USERDIR=y
FREETZ_PACKAGE_LIGHTTPD_MOD_USERTRACK=y
FREETZ_PACKAGE_LIGHTTPD_MOD_WEBDAV=y
# FREETZ_PACKAGE_LIGHTTPD_MOD_WEBDAV_WITH_PROPS is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NETATALK is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NFSROOT is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
# FREETZ_PACKAGE_OPENNTPD is not set
# OpenSSH
# FREETZ_PACKAGE_OPENSSH_sshd is not set
# FREETZ_PACKAGE_OPENSSH_ssh is not set
# FREETZ_PACKAGE_OPENSSH_scp is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_sftp is not set
# FREETZ_PACKAGE_OPENSSH_sftp_server is not set
# FREETZ_PACKAGE_OPENSSL is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
FREETZ_PACKAGE_PHP=y
# FREETZ_PHP_VERSION_5_3 is not set
FREETZ_PHP_VERSION_5_4=y
# FREETZ_PHP_VERSION_5_5 is not set
# PHP features
FREETZ_PACKAGE_PHP_WITH_CURL=y
FREETZ_PACKAGE_PHP_WITH_GD=y
FREETZ_PACKAGE_PHP_WITH_ICONV=y
FREETZ_PACKAGE_PHP_WITH_JSON=y
# FREETZ_PACKAGE_PHP_WITH_PCNTL is not set
FREETZ_PACKAGE_PHP_WITH_SESSION=y
FREETZ_PACKAGE_PHP_WITH_SOCKETS=y
FREETZ_PACKAGE_PHP_WITH_SQLITE3=y
FREETZ_PACKAGE_PHP_WITH_SSL=y
# FREETZ_PACKAGE_PHP_WITH_SYSVIPC is not set
FREETZ_PACKAGE_PHP_WITH_LIBXML=y
FREETZ_PACKAGE_PHP_WITH_ZLIB=y
FREETZ_PACKAGE_PHP_WITH_ZIP=y
# FREETZ_PACKAGE_PHP_STATIC is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_PPP is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_PYLOAD is not set
# FREETZ_PACKAGE_PYTHON is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_RIPMIME is not set
FREETZ_PACKAGE_RRDTOOL=y
FREETZ_PACKAGE_RSYNC=y
# FREETZ_PACKAGE_RTMPDUMP is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SHELLINABOX is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
# FREETZ_PACKAGE_SMSTOOLS3 is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
FREETZ_PACKAGE_SQLITE=y
FREETZ_PACKAGE_SQLITE_WITH_READLINE=y
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_SSLH is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SUNDTEK is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# Tesseract OCR (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_TIFF is not set
# FREETZ_PACKAGE_TINC is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TMUX is not set
# FREETZ_PACKAGE_TOR is not set
FREETZ_PACKAGE_TRANSMISSION=y
# FREETZ_PACKAGE_TRANSMISSION_CLIENT is not set
FREETZ_PACKAGE_TRANSMISSION_DAEMON=y
# FREETZ_PACKAGE_TRANSMISSION_REMOTE is not set
# FREETZ_PACKAGE_TRANSMISSION_CREATE is not set
# FREETZ_PACKAGE_TRANSMISSION_EDIT is not set
# FREETZ_PACKAGE_TRANSMISSION_SHOW is not set
# FREETZ_PACKAGE_TRANSMISSION_STATIC is not set
FREETZ_PACKAGE_TRANSMISSION_WEBINTERFACE=y
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNFS3 is not set
# FREETZ_PACKAGE_UNRAR is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_UTIL_LINUX_NG is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VPNC is not set
FREETZ_PACKAGE_VSFTPD=y
FREETZ_PACKAGE_VSFTPD_WITH_SSL=y
# FREETZ_PACKAGE_VSFTPD_STATIC is not set
# FREETZ_PACKAGE_VTUN is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XMAIL is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# Unstable
# FREETZ_PACKAGE_ASTERISK is not set
# FREETZ_PACKAGE_AVM_FORWARDING is not set
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_HPLIP is not set
# FREETZ_PACKAGE_HP_UTILS is not set
# FREETZ_PACKAGE_IPTABLES is not set
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
# FREETZ_PACKAGE_MINI_FO is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# SCANBUTTOND
# FREETZ_PACKAGE_SCANBUTTOND is not set
# FREETZ_PACKAGE_SQUID is not set
# truecrypt (not available, needs libstdc++ as the Standard C++ Library)
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_ZABBIX is not set
# Web interfaces
# FREETZ_PACKAGE_AUTHORIZED_KEYS is not set
FREETZ_PACKAGE_AVM_FIREWALL=y
# FREETZ_PACKAGE_DNSD_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_PPP_CGI is not set
# FREETZ_PACKAGE_RRDSTATS is not set
FREETZ_PACKAGE_SPINDOWN_CGI=y
FREETZ_PACKAGE_SG3UTILS=y
FREETZ_PACKAGE_SYSLOGD_CGI=y
FREETZ_PACKAGE_TRANSMISSION_CGI=y
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Shared libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
# FREETZ_LIB_STDCXXLIB is not set
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
# FREETZ_LIB_libuClibc__ is not set
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# Digests ---
# FREETZ_LIB_libgcrypt_WITH_DIGEST_crc is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md4 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md5 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_rmd160 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha1 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha256 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha512 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_tiger is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_whirlpool is not set
# Symmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_aes is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_arcfour is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_blowfish is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_camellia is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_cast5 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_des is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_rfc2268 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_seed is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_serpent is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_twofish is not set
# Asymmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_dsa is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_ecc is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_elgamal is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_rsa is not set
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl is not set
# FREETZ_LIB_libpolarssl_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl_WITH_GENRSA is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
FREETZ_OPENSSL_VERSION_PROMPT=y
FREETZ_OPENSSL_VERSION_0=y
# FREETZ_OPENSSL_VERSION_1 is not set
FREETZ_OPENSSL_SHLIB_VERSION="0.9.8"
# Data compression
# FREETZ_LIB_liblzo2 is not set
FREETZ_LIB_libz=y
# Database
# FREETZ_LIB_libdb is not set
FREETZ_LIB_libsqlite3=y
# File systems
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
FREETZ_LIB_libfreetype=y
FREETZ_LIB_libart_lgpl_2=y
# FREETZ_LIB_libexif is not set
FREETZ_LIB_libjpeg=y
# FREETZ_LIB_liblept is not set
FREETZ_LIB_libpng12=y
FREETZ_LIB_libgd=y
# FREETZ_LIB_libopenjpeg is not set
# FREETZ_LIB_libtiff is not set
# FREETZ_LIB_libtiffxx is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libogg is not set
# FREETZ_LIB_libopus is not set
# FREETZ_LIB_libspeex is not set
# FREETZ_LIB_libspeexdsp is not set
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libtag is not set
# ncurses
FREETZ_LIB_libncurses=y
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
FREETZ_SHARE_terminfo=y
# FREETZ_SHARE_terminfo_showall is not set
FREETZ_SHARE_terminfo_ansi=y
FREETZ_SHARE_terminfo_gnome=y
FREETZ_SHARE_terminfo_konsole=y
FREETZ_SHARE_terminfo_linux=y
FREETZ_SHARE_terminfo_putty=y
FREETZ_SHARE_terminfo_rxvt=y
FREETZ_SHARE_terminfo_screen=y
FREETZ_SHARE_terminfo_screenMINUSw=y
FREETZ_SHARE_terminfo_sun=y
FREETZ_SHARE_terminfo_vt100=y
FREETZ_SHARE_terminfo_vt102=y
FREETZ_SHARE_terminfo_vt102MINUSnsgr=y
FREETZ_SHARE_terminfo_vt102MINUSw=y
FREETZ_SHARE_terminfo_vt200=y
FREETZ_SHARE_terminfo_vt220=y
FREETZ_SHARE_terminfo_vt52=y
FREETZ_SHARE_terminfo_xterm=y
FREETZ_SHARE_terminfo_xtermMINUS256color=y
FREETZ_SHARE_terminfo_xtermMINUScolor=y
FREETZ_SHARE_terminfo_xtermMINUSxfree86=y
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
FREETZ_LIB_libbluetooth=y
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
# FREETZ_LIB_libcapi20 is not set
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libgsm is not set
# FREETZ_LIB_libiksemel is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_liboping is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# FREETZ_LIB_libsrtp is not set
# PJ Project
# FREETZ_LIB_libpj is not set
# FREETZ_LIB_libpjlib_util is not set
# FREETZ_LIB_libpjmedia is not set
# FREETZ_LIB_libpjmedia_audiodev is not set
# FREETZ_LIB_libpjmedia_codec is not set
# FREETZ_LIB_libpjmedia_videodev is not set
# FREETZ_LIB_libpjnath is not set
# FREETZ_LIB_libpjsip is not set
# FREETZ_LIB_libpjsip_simple is not set
# FREETZ_LIB_libpjsip_ua is not set
# FREETZ_LIB_libpjsua is not set
# 3rdparty libraries
# FREETZ_LIB_libg7221codec is not set
# FREETZ_LIB_libilbccodec is not set
# FREETZ_LIB_libmilenage is not set
# Readline
FREETZ_LIB_libreadline=y
# FREETZ_LIB_libhistory is not set
# Regular expressions
FREETZ_LIB_libpcre=y
# FREETZ_LIB_libpcreposix is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# USB & FTDI
# FREETZ_LIB_libusb_0 is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
FREETZ_LIB_libcurl=y
FREETZ_LIB_libcurl_WITH_SSL=y
# FREETZ_LIB_libcurl_WITH_CYASSL is not set
FREETZ_LIB_libcurl_WITH_OPENSSL=y
# FREETZ_LIB_libcurl_WITH_POLARSSL is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# FREETZ_LIB_libserf is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
FREETZ_LIB_libxml2=y
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libev is not set
FREETZ_LIB_libevent=y
# FREETZ_LIB_libffi is not set
FREETZ_LIB_libctlmgr=y
# FREETZ_LIB_libmultid is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libpcsclite is not set
FREETZ_LIB_libpopt=y
# FREETZ_LIB_libprotobuf_c is not set
FREETZ_LIB_librrd=y
# FREETZ_LIB_librrd_th is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
FREETZ_KERNEL_VERSION_2_6_28=y
# FREETZ_KERNEL_VERSION_2_6_32_41 is not set
# FREETZ_KERNEL_VERSION_2_6_32_60 is not set
# FREETZ_KERNEL_VERSION_2_6_32 is not set
FREETZ_KERNEL_VERSION="2.6.28"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
# FREETZ_KERNEL_VERSION_2_6_32_MIN is not set
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
FREETZ_KERNEL_VERSION_2_6_28_MAX=y
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_IKS=y
FREETZ_KERNEL_LAYOUT="iks"
FREETZ_MODULES_KVER="2.6.28.10"
FREETZ_KERNEL_PATCHES="${FREETZ_MODULES_KVER}"
# Kernel modules
# FREETZ_MODULES_ALL is not set
# block
# FREETZ_MODULE_block2mtd is not set
# FREETZ_MODULE_ramzswap is not set
# FREETZ_MODULE_xvmalloc is not set
# crypto
# FREETZ_MODULE_crypto_blkcipher is not set
# FREETZ_MODULE_crypto_hash is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha256_generic is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_cp2101 is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_bfusb is not set
FREETZ_MODULE_btusb=y
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_autofs4 is not set
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
FREETZ_MODULE_ext2=y
FREETZ_MODULE_ext4=y
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
FREETZ_MODULE_fuse=y
# FREETZ_MODULE_iso9660 is not set
FREETZ_MODULE_jbd2=y
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdos is not set
# FREETZ_MODULE_jffs2 is not set
FREETZ_MODULE_mbcache=y
# lib
FREETZ_MODULE_crc16=y
# FREETZ_MODULE_crc_ccitt is not set
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
FREETZ_MODULE_bluetooth=y
FREETZ_MODULE_bnep=y
# FREETZ_MODULE_cls_u32 is not set
FREETZ_MODULE_l2cap=y
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
FREETZ_MODULE_rfcomm=y
# FREETZ_MODULE_sunrpc is not set
# Busybox applets
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__IPV6_UTILS=y
# FREETZ_BUSYBOX__PACKER is not set
# FREETZ_BUSYBOX__NETWORK is not set
# FREETZ_BUSYBOX__TERMINAL is not set
# FREETZ_BUSYBOX__DEVELOPER is not set
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
# Busybox Settings
# General Configuration
# FREETZ_BUSYBOX_DESKTOP is not set
# FREETZ_BUSYBOX_EXTRA_COMPAT is not set
# FREETZ_BUSYBOX_INCLUDE_SUSv2 is not set
# FREETZ_BUSYBOX_USE_PORTABLE_CODE is not set
FREETZ_BUSYBOX_PLATFORM_LINUX=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_USE_MALLOC is not set
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_IN_BSS is not set
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
# FREETZ_BUSYBOX_FEATURE_COMPRESS_USAGE is not set
# FREETZ_BUSYBOX_FEATURE_INSTALLER is not set
# FREETZ_BUSYBOX_INSTALL_NO_USR is not set
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
# FREETZ_BUSYBOX_FEATURE_CLEAN_UP is not set
# FREETZ_BUSYBOX_FEATURE_UTMP is not set
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
# FREETZ_BUSYBOX_FEATURE_SUID_CONFIG is not set
# FREETZ_BUSYBOX_SELINUX is not set
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
# Build Options
# FREETZ_BUSYBOX_STATIC is not set
# FREETZ_BUSYBOX_PIE is not set
# FREETZ_BUSYBOX_NOMMU is not set
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
# Debugging Options
# FREETZ_BUSYBOX_DEBUG is not set
# FREETZ_BUSYBOX_WERROR is not set
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
# FREETZ_BUSYBOX_DMALLOC is not set
# FREETZ_BUSYBOX_EFENCE is not set
# Installation Options ("make install" behavior)
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
# FREETZ_BUSYBOX_INSTALL_APPLET_HARDLINKS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_SCRIPT_WRAPPERS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_DONT is not set
FREETZ_BUSYBOX_PREFIX="./_install"
# Busybox Library Tuning
# FREETZ_BUSYBOX_FEATURE_SYSTEMD is not set
# FREETZ_BUSYBOX_FEATURE_RTMINMAX is not set
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
# FREETZ_BUSYBOX_FEATURE_FAST_TOP is not set
# FREETZ_BUSYBOX_FEATURE_ETC_NETWORKS is not set
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
# FREETZ_BUSYBOX_FEATURE_EDITING_VI is not set
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
# FREETZ_BUSYBOX_FEATURE_EDITING_SAVEHISTORY is not set
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
# FREETZ_BUSYBOX_FEATURE_EDITING_ASK_TERMINAL is not set
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
# FREETZ_BUSYBOX_FEATURE_VERBOSE_CP_MESSAGE is not set
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
# Applets
# Archival Utilities
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_XZ is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_LZMA is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_BZ2 is not set
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_Z is not set
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_BUNZIP2 is not set
# FREETZ_BUSYBOX_BZIP2 is not set
# FREETZ_BUSYBOX_CPIO is not set
# FREETZ_BUSYBOX_DPKG is not set
# FREETZ_BUSYBOX_DPKG_DEB is not set
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
# FREETZ_BUSYBOX_LZOP is not set
# FREETZ_BUSYBOX_RPM2CPIO is not set
# FREETZ_BUSYBOX_RPM is not set
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
# FREETZ_BUSYBOX_FEATURE_TAR_AUTODETECT is not set
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_FEATURE_TAR_OLDSUN_COMPATIBILITY is not set
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
# FREETZ_BUSYBOX_FEATURE_TAR_UNAME_GNAME is not set
# FREETZ_BUSYBOX_FEATURE_TAR_NOPRESERVE_TIME is not set
# FREETZ_BUSYBOX_UNCOMPRESS is not set
# FREETZ_BUSYBOX_UNLZMA is not set
# FREETZ_BUSYBOX_UNXZ is not set
# FREETZ_BUSYBOX_UNZIP is not set
# Coreutils
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
# FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
# FREETZ_BUSYBOX_HOSTID is not set
FREETZ_BUSYBOX_ID=y
# FREETZ_BUSYBOX_GROUPS is not set
FREETZ_BUSYBOX_TEST=y
# FREETZ_BUSYBOX_FEATURE_TEST_64 is not set
FREETZ_BUSYBOX_TOUCH=y
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
# FREETZ_BUSYBOX_BASE64 is not set
# FREETZ_BUSYBOX_CAL is not set
# FREETZ_BUSYBOX_CATV is not set
# FREETZ_BUSYBOX_CHGRP is not set
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
# FREETZ_BUSYBOX_CHROOT is not set
# FREETZ_BUSYBOX_CKSUM is not set
# FREETZ_BUSYBOX_COMM is not set
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
# FREETZ_BUSYBOX_FEATURE_DD_THIRD_STATUS_LINE is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
FREETZ_BUSYBOX_DF=y
# FREETZ_BUSYBOX_FEATURE_DF_FANCY is not set
FREETZ_BUSYBOX_DIRNAME=y
# FREETZ_BUSYBOX_DOS2UNIX is not set
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
# FREETZ_BUSYBOX_EXPAND is not set
FREETZ_BUSYBOX_EXPR=y
# FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64 is not set
FREETZ_BUSYBOX_FALSE=y
# FREETZ_BUSYBOX_FOLD is not set
# FREETZ_BUSYBOX_FSYNC is not set
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
# FREETZ_BUSYBOX_INSTALL is not set
FREETZ_BUSYBOX_LN=y
# FREETZ_BUSYBOX_LOGNAME is not set
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
# FREETZ_BUSYBOX_NICE is not set
FREETZ_BUSYBOX_NOHUP=y
# FREETZ_BUSYBOX_OD is not set
# FREETZ_BUSYBOX_PRINTENV is not set
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
# FREETZ_BUSYBOX_READLINK is not set
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SHA256SUM is not set
# FREETZ_BUSYBOX_SHA512SUM is not set
# FREETZ_BUSYBOX_SHA3SUM is not set
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
# FREETZ_BUSYBOX_FEATURE_FLOAT_SLEEP is not set
FREETZ_BUSYBOX_SORT=y
# FREETZ_BUSYBOX_FEATURE_SORT_BIG is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
# FREETZ_BUSYBOX_SUM is not set
FREETZ_BUSYBOX_SYNC=y
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
# FREETZ_BUSYBOX_UNEXPAND is not set
# FREETZ_BUSYBOX_UNIQ is not set
# FREETZ_BUSYBOX_USLEEP is not set
FREETZ_BUSYBOX_UUDECODE=y
# FREETZ_BUSYBOX_UUENCODE is not set
FREETZ_BUSYBOX_WC=y
# FREETZ_BUSYBOX_FEATURE_WC_LARGE is not set
# FREETZ_BUSYBOX_WHOAMI is not set
FREETZ_BUSYBOX_YES=y
# Common options for cp and mv
# FREETZ_BUSYBOX_FEATURE_PRESERVE_HARDLINKS is not set
# Common options for ls, more and telnet
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
# Common options for df, du, ls
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
# Common options for md5sum, sha1sum, sha256sum, sha512sum, sha3sum
# FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK is not set
# Console Utilities
# FREETZ_BUSYBOX_CHVT is not set
# FREETZ_BUSYBOX_FGCONSOLE is not set
# FREETZ_BUSYBOX_CLEAR is not set
# FREETZ_BUSYBOX_DEALLOCVT is not set
# FREETZ_BUSYBOX_DUMPKMAP is not set
# FREETZ_BUSYBOX_KBD_MODE is not set
# FREETZ_BUSYBOX_LOADFONT is not set
# FREETZ_BUSYBOX_LOADKMAP is not set
# FREETZ_BUSYBOX_OPENVT is not set
# FREETZ_BUSYBOX_RESET is not set
# FREETZ_BUSYBOX_RESIZE is not set
# FREETZ_BUSYBOX_SETCONSOLE is not set
# FREETZ_BUSYBOX_SETFONT is not set
# FREETZ_BUSYBOX_SETKEYCODES is not set
# FREETZ_BUSYBOX_SETLOGCONS is not set
# FREETZ_BUSYBOX_SHOWKEY is not set
# Debian Utilities
# FREETZ_BUSYBOX_MKTEMP is not set
# FREETZ_BUSYBOX_PIPE_PROGRESS is not set
# FREETZ_BUSYBOX_RUN_PARTS is not set
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_FEATURE_START_STOP_DAEMON_FANCY=y
FREETZ_BUSYBOX_WHICH=y
# Editors
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
# FREETZ_BUSYBOX_FEATURE_VI_REGEX_SEARCH is not set
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
FREETZ_BUSYBOX_AWK=y
# FREETZ_BUSYBOX_FEATURE_AWK_LIBM is not set
# FREETZ_BUSYBOX_CMP is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_ED is not set
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
# Finding Utilities
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
# FREETZ_BUSYBOX_FEATURE_FIND_DELETE is not set
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
# FREETZ_BUSYBOX_FEATURE_FIND_LINKS is not set
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
# Init Utilities
# FREETZ_BUSYBOX_BOOTCHARTD is not set
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
# FREETZ_BUSYBOX_FEATURE_INIT_SCTTY is not set
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
# FREETZ_BUSYBOX_FEATURE_EXTRA_QUIET is not set
# FREETZ_BUSYBOX_FEATURE_INIT_COREDUMPS is not set
# FREETZ_BUSYBOX_FEATURE_INITRD is not set
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
# FREETZ_BUSYBOX_MESG is not set
# Login/Password Management Utilities
# FREETZ_BUSYBOX_ADD_SHELL is not set
# FREETZ_BUSYBOX_REMOVE_SHELL is not set
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
# FREETZ_BUSYBOX_USE_BB_PWD_GRP is not set
FREETZ_BUSYBOX_USE_BB_CRYPT=y
# FREETZ_BUSYBOX_USE_BB_CRYPT_SHA is not set
FREETZ_BUSYBOX_ADDUSER=y
# FREETZ_BUSYBOX_FEATURE_CHECK_NAMES is not set
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
# FREETZ_BUSYBOX_GETTY is not set
FREETZ_BUSYBOX_LOGIN=y
# FREETZ_BUSYBOX_LOGIN_SESSION_AS_CHILD is not set
# FREETZ_BUSYBOX_PAM is not set
# FREETZ_BUSYBOX_LOGIN_SCRIPTS is not set
# FREETZ_BUSYBOX_FEATURE_NOLOGIN is not set
# FREETZ_BUSYBOX_FEATURE_SECURETTY is not set
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
# FREETZ_BUSYBOX_CHPASSWD is not set
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
# FREETZ_BUSYBOX_SU is not set
# FREETZ_BUSYBOX_SULOGIN is not set
# FREETZ_BUSYBOX_VLOCK is not set
# Linux Ext2 FS Progs
# FREETZ_BUSYBOX_CHATTR is not set
# FREETZ_BUSYBOX_FSCK is not set
# FREETZ_BUSYBOX_LSATTR is not set
# FREETZ_BUSYBOX_TUNE2FS is not set
# Linux Module Utilities
# FREETZ_BUSYBOX_MODINFO is not set
# FREETZ_BUSYBOX_MODPROBE_SMALL is not set
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
# FREETZ_BUSYBOX_FEATURE_MODPROBE_BLACKLIST is not set
# FREETZ_BUSYBOX_DEPMOD is not set
# Options common to multiple modutils
# FREETZ_BUSYBOX_FEATURE_2_4_MODULES is not set
# FREETZ_BUSYBOX_FEATURE_INSMOD_TRY_MMAP is not set
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
# FREETZ_BUSYBOX_FEATURE_MODUTILS_ALIAS is not set
# FREETZ_BUSYBOX_FEATURE_MODUTILS_SYMBOLS is not set
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
# Linux System Utilities
# FREETZ_BUSYBOX_BLOCKDEV is not set
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_REV is not set
# FREETZ_BUSYBOX_ACPID is not set
FREETZ_BUSYBOX_BLKID=y
FREETZ_BUSYBOX_FEATURE_BLKID_TYPE=y
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
# FREETZ_BUSYBOX_FBSET is not set
# FREETZ_BUSYBOX_FDFLUSH is not set
# FREETZ_BUSYBOX_FDFORMAT is not set
# FREETZ_BUSYBOX_FDISK is not set
# FREETZ_BUSYBOX_FINDFS is not set
# FREETZ_BUSYBOX_FLOCK is not set
# FREETZ_BUSYBOX_FREERAMDISK is not set
# FREETZ_BUSYBOX_FSCK_MINIX is not set
# FREETZ_BUSYBOX_MKFS_EXT2 is not set
# FREETZ_BUSYBOX_MKFS_MINIX is not set
# FREETZ_BUSYBOX_MKFS_REISER is not set
# FREETZ_BUSYBOX_MKFS_VFAT is not set
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
# FREETZ_BUSYBOX_HEXDUMP is not set
# FREETZ_BUSYBOX_HWCLOCK is not set
# FREETZ_BUSYBOX_IPCRM is not set
# FREETZ_BUSYBOX_IPCS is not set
# FREETZ_BUSYBOX_LOSETUP is not set
# FREETZ_BUSYBOX_LSPCI is not set
# FREETZ_BUSYBOX_LSUSB is not set
FREETZ_BUSYBOX_MKSWAP=y
# FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID is not set
# FREETZ_BUSYBOX_MORE is not set
FREETZ_BUSYBOX_MOUNT=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_FAKE is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_FEATURE_MOUNT_LABEL is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
# FREETZ_BUSYBOX_RDATE is not set
# FREETZ_BUSYBOX_RDEV is not set
# FREETZ_BUSYBOX_READPROFILE is not set
# FREETZ_BUSYBOX_RTCWAKE is not set
# FREETZ_BUSYBOX_SCRIPT is not set
# FREETZ_BUSYBOX_SCRIPTREPLAY is not set
# FREETZ_BUSYBOX_SETARCH is not set
FREETZ_BUSYBOX_SWAPONOFF=y
# FREETZ_BUSYBOX_FEATURE_SWAPON_PRI is not set
# FREETZ_BUSYBOX_SWITCH_ROOT is not set
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
# Common options for mount/umount
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
# FREETZ_BUSYBOX_FEATURE_MTAB_SUPPORT is not set
FREETZ_BUSYBOX_VOLUMEID=y
# Filesystem/Volume identification
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_BTRFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_REISERFS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_FAT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXFAT is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_HFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_JFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_XFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_NILFS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NTFS=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ISO9660 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_UDF is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LUKS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXSWAP is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_CRAMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ROMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SQUASHFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SYSV is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_OCFS2 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXRAID is not set
# Miscellaneous Utilities
# FREETZ_BUSYBOX_CONSPY is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NANDWRITE is not set
# FREETZ_BUSYBOX_NANDDUMP is not set
# FREETZ_BUSYBOX_SETSERIAL is not set
# FREETZ_BUSYBOX_UBIATTACH is not set
# FREETZ_BUSYBOX_UBIDETACH is not set
# FREETZ_BUSYBOX_UBIMKVOL is not set
# FREETZ_BUSYBOX_UBIRMVOL is not set
# FREETZ_BUSYBOX_UBIRSVOL is not set
# FREETZ_BUSYBOX_UBIUPDATEVOL is not set
# FREETZ_BUSYBOX_ADJTIMEX is not set
# FREETZ_BUSYBOX_BBCONFIG is not set
# FREETZ_BUSYBOX_BEEP is not set
# FREETZ_BUSYBOX_CHAT is not set
# FREETZ_BUSYBOX_CHRT is not set
FREETZ_BUSYBOX_CROND=y
# FREETZ_BUSYBOX_FEATURE_CROND_D is not set
# FREETZ_BUSYBOX_FEATURE_CROND_CALL_SENDMAIL is not set
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
FREETZ_BUSYBOX_CRONTAB=y
# FREETZ_BUSYBOX_DC is not set
# FREETZ_BUSYBOX_DEVFSD is not set
# FREETZ_BUSYBOX_FEATURE_DEVFS is not set
# FREETZ_BUSYBOX_DEVMEM is not set
# FREETZ_BUSYBOX_EJECT is not set
# FREETZ_BUSYBOX_FBSPLASH is not set
# FREETZ_BUSYBOX_FLASHCP is not set
# FREETZ_BUSYBOX_FLASH_LOCK is not set
# FREETZ_BUSYBOX_FLASH_UNLOCK is not set
# FREETZ_BUSYBOX_FLASH_ERASEALL is not set
# FREETZ_BUSYBOX_IONICE is not set
# FREETZ_BUSYBOX_INOTIFYD is not set
# FREETZ_BUSYBOX_HDPARM is not set
FREETZ_BUSYBOX_MAKEDEVS=y
# FREETZ_BUSYBOX_FEATURE_MAKEDEVS_LEAF is not set
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
# FREETZ_BUSYBOX_MAN is not set
# FREETZ_BUSYBOX_MICROCOM is not set
# FREETZ_BUSYBOX_MOUNTPOINT is not set
# FREETZ_BUSYBOX_MT is not set
# FREETZ_BUSYBOX_RAIDAUTORUN is not set
# FREETZ_BUSYBOX_READAHEAD is not set
# FREETZ_BUSYBOX_RFKILL is not set
# FREETZ_BUSYBOX_RX is not set
# FREETZ_BUSYBOX_SETSID is not set
# FREETZ_BUSYBOX_STRINGS is not set
# FREETZ_BUSYBOX_TASKSET is not set
# FREETZ_BUSYBOX_TIME is not set
# FREETZ_BUSYBOX_TIMEOUT is not set
# FREETZ_BUSYBOX_TTYSIZE is not set
# FREETZ_BUSYBOX_VOLNAME is not set
# FREETZ_BUSYBOX_WATCHDOG is not set
# Networking Utilities
# FREETZ_BUSYBOX_NAMEIF is not set
# FREETZ_BUSYBOX_NBDCLIENT is not set
FREETZ_BUSYBOX_NC=y
# FREETZ_BUSYBOX_NC_SERVER is not set
FREETZ_BUSYBOX_NC_EXTRA=y
# FREETZ_BUSYBOX_NC_110_COMPAT is not set
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
# FREETZ_BUSYBOX_FEATURE_UNIX_LOCAL is not set
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_VERBOSE_RESOLUTION_ERRORS is not set
# FREETZ_BUSYBOX_ARP is not set
# FREETZ_BUSYBOX_ARPING is not set
FREETZ_BUSYBOX_BRCTL=y
# FREETZ_BUSYBOX_FEATURE_BRCTL_FANCY is not set
# FREETZ_BUSYBOX_DNSD is not set
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FTPD is not set
# FREETZ_BUSYBOX_FTPGET is not set
# FREETZ_BUSYBOX_FTPPUT is not set
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_RANGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_USE_SENDFILE is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_SETUID is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_SET_REMOTE_PORT_TO_ENV is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_ERROR_PAGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_PROXY is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_GZIP is not set
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_SLIP is not set
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_MEMSTART_IOADDR_IRQ is not set
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
# FREETZ_BUSYBOX_IFENSLAVE is not set
# FREETZ_BUSYBOX_IFPLUGD is not set
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IP is not set
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_EXTERNAL_DHCP is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_ECHO is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DISCARD is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_TIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DAYTIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_CHARGEN is not set
# FREETZ_BUSYBOX_FEATURE_INETD_RPC is not set
# FREETZ_BUSYBOX_IP is not set
# FREETZ_BUSYBOX_IPCALC is not set
FREETZ_BUSYBOX_NETSTAT=y
# FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE is not set
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
# FREETZ_BUSYBOX_NSLOOKUP is not set
# FREETZ_BUSYBOX_NTPD is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_ROUTE=y
# FREETZ_BUSYBOX_SLATTACH is not set
# FREETZ_BUSYBOX_TCPSVD is not set
# FREETZ_BUSYBOX_TELNET is not set
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
# FREETZ_BUSYBOX_FEATURE_TELNETD_INETD_WAIT is not set
# FREETZ_BUSYBOX_TFTP is not set
# FREETZ_BUSYBOX_TFTPD is not set
# FREETZ_BUSYBOX_TRACEROUTE is not set
# FREETZ_BUSYBOX_TUNCTL is not set
# FREETZ_BUSYBOX_UDHCPC6 is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDPSVD is not set
FREETZ_BUSYBOX_VCONFIG=y
FREETZ_BUSYBOX_WGET=y
FREETZ_BUSYBOX_FEATURE_WGET_STATUSBAR=y
FREETZ_BUSYBOX_FEATURE_WGET_AUTHENTICATION=y
FREETZ_BUSYBOX_FEATURE_WGET_TIMEOUT=y
# FREETZ_BUSYBOX_ZCIP is not set
# Print Utilities
# FREETZ_BUSYBOX_LPD is not set
# FREETZ_BUSYBOX_LPR is not set
# FREETZ_BUSYBOX_LPQ is not set
# Mail Utilities
# FREETZ_BUSYBOX_MAKEMIME is not set
# FREETZ_BUSYBOX_POPMAILDIR is not set
# FREETZ_BUSYBOX_REFORMIME is not set
# FREETZ_BUSYBOX_SENDMAIL is not set
# Process Utilities
# FREETZ_BUSYBOX_IOSTAT is not set
# FREETZ_BUSYBOX_LSOF is not set
# FREETZ_BUSYBOX_MPSTAT is not set
# FREETZ_BUSYBOX_NMETER is not set
# FREETZ_BUSYBOX_PMAP is not set
# FREETZ_BUSYBOX_POWERTOP is not set
# FREETZ_BUSYBOX_PSTREE is not set
# FREETZ_BUSYBOX_PWDX is not set
# FREETZ_BUSYBOX_SMEMCAP is not set
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_CPU is not set
# FREETZ_BUSYBOX_FEATURE_TOP_DECIMALS is not set
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_PROCESS is not set
# FREETZ_BUSYBOX_FEATURE_TOPMEM is not set
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FREE=y
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
# FREETZ_BUSYBOX_KILLALL5 is not set
# FREETZ_BUSYBOX_PGREP is not set
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
# FREETZ_BUSYBOX_PKILL is not set
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
# FREETZ_BUSYBOX_RENICE is not set
FREETZ_BUSYBOX_BB_SYSCTL=y
# FREETZ_BUSYBOX_FEATURE_SHOW_THREADS is not set
# FREETZ_BUSYBOX_WATCH is not set
# Runit Utilities
# FREETZ_BUSYBOX_RUNSV is not set
# FREETZ_BUSYBOX_RUNSVDIR is not set
# FREETZ_BUSYBOX_SV is not set
# FREETZ_BUSYBOX_SVLOGD is not set
# FREETZ_BUSYBOX_CHPST is not set
# FREETZ_BUSYBOX_SETUIDGID is not set
# FREETZ_BUSYBOX_ENVUIDGID is not set
# FREETZ_BUSYBOX_ENVDIR is not set
# FREETZ_BUSYBOX_SOFTLIMIT is not set
# Shells
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
# FREETZ_BUSYBOX_ASH_IDLE_TIMEOUT is not set
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
FREETZ_BUSYBOX_ASH_CMDCMD=y
# FREETZ_BUSYBOX_ASH_MAIL is not set
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
# FREETZ_BUSYBOX_ASH_RANDOM_SUPPORT is not set
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
# FREETZ_BUSYBOX_CTTYHACK is not set
# FREETZ_BUSYBOX_HUSH is not set
# FREETZ_BUSYBOX_MSH is not set
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
# FREETZ_BUSYBOX_FEATURE_SH_IS_NONE is not set
# FREETZ_BUSYBOX_FEATURE_BASH_IS_ASH is not set
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
# FREETZ_BUSYBOX_SH_MATH_SUPPORT_64 is not set
# FREETZ_BUSYBOX_FEATURE_SH_EXTRA_QUIET is not set
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
# FREETZ_BUSYBOX_FEATURE_SH_HISTFILESIZE is not set
# System Logging Utilities
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_CFG is not set
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
# FREETZ_BUSYBOX_FEATURE_KMSG_SYSLOG is not set
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
# External processing
EXTERNAL_ENABLED=y
EXTERNAL_SUBDIRS=y
# EXTERNAL_LINKS is not set
EXTERNAL_DYNAMIC=y
EXTERNAL_DYNAMIC_SCRIPTS=y
EXTERNAL_CREATEPAK=y
# EXTERNAL_CREATEPAK_DYNAMIC is not set
EXTERNAL_OWN_FILES=""
# packages
EXTERNAL_FREETZ_PACKAGE_LDD=y
EXTERNAL_FREETZ_PACKAGE_BLUEZ_UTILS=y
EXTERNAL_FREETZ_PACKAGE_LIGHTTPD=y
EXTERNAL_FREETZ_PACKAGE_PHP=y
EXTERNAL_FREETZ_PACKAGE_RRDTOOL=y
EXTERNAL_FREETZ_PACKAGE_RSYNC=y
EXTERNAL_FREETZ_PACKAGE_SQLITE=y
# EXTERNAL_FREETZ_PACKAGE_TRANSMISSION is not set
EXTERNAL_FREETZ_PACKAGE_VSFTPD=y
# libraries
EXTERNAL_FREETZ_LIB_libart_lgpl_2=y
EXTERNAL_FREETZ_LIB_libbluetooth=y
EXTERNAL_FREETZ_LIB_libcrypto=y
EXTERNAL_FREETZ_LIB_libssl=y
EXTERNAL_FREETZ_LIB_libcurl=y
EXTERNAL_FREETZ_LIB_libevent=y
EXTERNAL_FREETZ_LIB_libncurses=y
EXTERNAL_FREETZ_LIB_libfreetype=y
EXTERNAL_FREETZ_LIB_libgd=y
EXTERNAL_FREETZ_LIB_libreadline=y
EXTERNAL_FREETZ_LIB_libjpeg=y
EXTERNAL_FREETZ_LIB_librrd=y
EXTERNAL_FREETZ_LIB_libpcre=y
EXTERNAL_FREETZ_LIB_libpng12=y
EXTERNAL_FREETZ_LIB_libpopt=y
EXTERNAL_FREETZ_LIB_libsqlite3=y
EXTERNAL_FREETZ_LIB_libxml2=y
EXTERNAL_FREETZ_LIB_libz=y
# modules
# Mod customizations ---------------------
# Web Interface
# FREETZ_LANG_DE is not set
FREETZ_LANG_EN=y
FREETZ_LANG_STRING="en"
FREETZ_SECURITY_LEVEL=1
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Freetz skins
FREETZ_SKIN_legacy=y
FREETZ_SKIN_newfreetz=y
# FREETZ_SKIN_phoenix is not set
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
FREETZ_MODIFY_AVM_VERSION=y
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
# FREETZ_REMOVE_DOT_CONFIG is not set
# Build system ---------------------------
# Toolchain options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_BINUTILS_2_22=y
FREETZ_KERNEL_GCC_4_6=y
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
FREETZ_KERNEL_GCC_VERSION="4.6.4"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_0_9_32=y
# FREETZ_TARGET_UCLIBC_SUPPORTS_libubacktrace is not set
FREETZ_TARGET_BINUTILS_2_22=y
FREETZ_TARGET_GCC_4_6=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_GCC_VERSION="4.6.4"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
# Firmware packaging (fwmod) options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_SDK is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
# Strip options
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_LIBRARIES is not set
# FREETZ_STRIP_MODULES_NONE is not set
FREETZ_STRIP_MODULES_FREETZ=y
# FREETZ_STRIP_MODULES_ALL is not set
# FREETZ_STRIP_SCRIPTS is not set
# Override options
FREETZ_DL_SITE_USER=""
# FREETZ_DL_TOOLCHAIN_OVERRIDE is not set
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="4622c6e00b05f6369ed3d777acb57ad2"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="b3d4da39d502edb1efa35930cd612a8c"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE="${FREETZ_AVM_VERSION_STRING}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="ec2130c7ff5238a8f78e12fa95681dbe"
FREETZ_DL_SITE="@AVM/fritzbox.fon_wlan_7390/firmware/english"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.05.51.image"
FREETZ_DL_SOURCE_CONTAINER=""
FREETZ_DL_SOURCE_CONTAINER_MD5=""
FREETZ_DL_SOURCE_MD5="dc3165d3bf753e2db25384760328bcff"
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_MODULE_AVAILABLE=y
# FREETZ_AVM_HAS_LABOR is not set
# FREETZ_AVM_HAS_FW6XX is not set
FREETZ_AVM_HAS_FW55X=y
FREETZ_AVM_HAS_FW52X=y
# FREETZ_AVM_HAS_FW4XX is not set
# FREETZ_AVM_HAS_FWEWE_05_2X is not set
FREETZ_AVM_HAS_FWEWE_05_5X=y
FREETZ_AVM_HAS_LANG_DE=y
# FREETZ_AVM_HAS_LANG_A_CH is not set
FREETZ_AVM_HAS_LANG_EN=y
# FREETZ_AVM_HAS_LANG_IT is not set
# FREETZ_AVM_UCLIBC_0_9_28 is not set
# FREETZ_AVM_UCLIBC_0_9_29 is not set
FREETZ_AVM_UCLIBC_0_9_32=y
# FREETZ_AVM_UCLIBC_0_9_33 is not set
# FREETZ_AVM_UCLIBC_NPTL_ENABLED is not set
# FREETZ_AVM_GCC_3_4 is not set
FREETZ_AVM_GCC_4_6=y
# FREETZ_AVM_GCC_4_7 is not set
FREETZ_AVM_HAS_PRINTK=y
# FREETZ_AVM_HAS_PIGLET is not set
FREETZ_AVM_HAS_PTY_SUPPORT=y
# FREETZ_AVM_HAS_CDROM_ISO is not set
FREETZ_AVM_HAS_AURA_USB=y
# FREETZ_AVM_HAS_MINID is not set
FREETZ_AVM_HAS_NTFS=y
FREETZ_AVM_HAS_IPV6=y
FREETZ_AVM_HAS_WEBDAV=y
FREETZ_AVM_HAS_INETD=y
FREETZ_AVM_HAS_EXT3=y
# FREETZ_AVM_HAS_ISOFS is not set
FREETZ_AVM_HAS_TR069=y
FREETZ_AVM_HAS_TR069_FWUPDATE=y
FREETZ_AVM_HAS_CHRONYD=y
FREETZ_AVM_HAS_DECT=y
FREETZ_AVM_HAS_OPENSSL_LIBS=y
FREETZ_AVM_HAS_LSOF=y
FREETZ_AVM_HAS_SOCAT=y
FREETZ_AVM_HAS_NAS=y
FREETZ_AVM_HAS_MYFRITZ=y
FREETZ_AVM_HAS_FHEM=y
FREETZ_AVM_HAS_PHONE=y
# FREETZ_AVM_HAS_STRACE is not set
FREETZ_AVM_HAS_TAM=y
FREETZ_AVM_HAS_UDEV=y
# FREETZ_AVM_HAS_UPDATE_FILESYSTEM_IMAGE is not set
# FREETZ_AVM_HAS_ETHERNET_OVER_USB is not set
FREETZ_AVM_HAS_USB_HOST=y
# FREETZ_AVM_HAS_USB_HOST_AHCI is not set
FREETZ_AVM_HAS_E2FSPROGS=y
FREETZ_AVM_HAS_WLAN=y
FREETZ_AVM_HAS_UMTS=y
# FREETZ_AVM_HAS_JFFS2 is not set
FREETZ_AVM_HAS_JUNK_BYTES=y
# FREETZ_AVM_HAS_MICROVOIP_DSL is not set
# FREETZ_AVM_HAS_ANNEX_A_AND_B is not set
FREETZ_AVM_HAS_MULTI_ANNEX=y
FREETZ_AVM_HAS_RAMZSWAP=y
FREETZ_AVM_HAS_AHA=y
FREETZ_AVM_HAS_TEMPERATURE_SENSOR=y
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_TARGET_ARCH_BE=y
FREETZ_TARGET_ARCH="mips"
FREETZ_TARGET_CROSS="mips-linux-uclibc-"
FREETZ_KERNEL_CROSS="mips-unknown-linux-gnu-"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_AVM_VERSION_7390_05_52=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_5X_MIN=y
FREETZ_AVM_VERSION_05_5X=y
FREETZ_AVM_VERSION_STRING="7390_05.52"
FREETZ_TYPE_PREFIX="7390"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="05_5X"
