root@fritz:/var/mod/root# cat /tmp/printserv.txt
13935 execve("/usr/bin/printserv", ["printserv", "-p", "9100", "-d", "/dev/usblp0"], [/* 228 vars */]) = 0
13935 old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|0x4000000, -1, 0) = 0x2aaad000
13935 open("/usr/lib/freetz/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
13935 open("/mod/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
13935 open("/lib/libgcc_s.so.1", O_RDONLY) = 3
13935 fstat(3, {st_mode=S_IFREG|0755, st_size=56384, ...}) = 0
13935 old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|0x4000000, -1, 0) = 0x2aaae000
13935 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\200\32\0\0004\0\0\0000\330\0\0\7\20\0P4\0 \0\7\0(\0\32\0\31\0\0\0\0p\24\1\0\0\24\1\0\0\24\1\0\0\30\0\0\0\30\0\0\0\4\0\0\0\4\0\0\0\1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\300\325\0\0\300\325\0\0\5\0\0\0\0\0\1\0\1\0\0\0\300\325\0\0\300\325\1\0\300\325\1\0\200\1\0\0\220\3\0\0\6\0\0\0\0\0\1\0\2\0\0\0,\1\0\0,\1\0\0,\1\0\0\360\0\0\0\360\0\0\0\7\0\0\0\4\0\0\0P\345tdp\311\0\0p\311\0\0p\311\0\0\254\2\0\0\254"..., 4096) = 4096
13935 old_mmap(NULL, 122880, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aabe000
13935 old_mmap(0x2aabe000, 54720, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aabe000
13935 old_mmap(0x2aadb000, 1856, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd000) = 0x2aadb000
13935 close(3) = 0
13935 munmap(0x2aaae000, 4096) = 0
13935 open("/usr/lib/freetz/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
13935 open("/mod/lib/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
13935 open("/lib/libc.so.0", O_RDONLY) = 3
13935 fstat(3, {st_mode=S_IFREG|0755, st_size=418588, ...}) = 0
13935 read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0000\257\0\0004\0\0\0\324_\6\0\7\20\0P4\0 \0\n\0(\0\25\0\24\0\6\0\0\0004\0\0\0004\0\0\0004\0\0\0@\1\0\0@\1\0\0\5\0\0\0\4\0\0\0\3\0\0\0\260K\6\0\260K\6\0\260K\6\0\30\0\0\0\30\0\0\0\4\0\0\0\4\0\0\0\0\0\0pt\1\0\0t\1\0\0t\1\0\0\30\0\0\0\30\0\0\0\4\0\0\0\4\0\0\0\1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0 L\6\0 L\6\0\5\0\0\0\0\0\1\0\1\0\0\0\224M\6\0\224M\7\0\224M\7\0x\21\0\0\354"..., 4096) = 4096
13935 old_mmap(NULL, 507904, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aadc000
13935 old_mmap(0x2aadc000, 412704, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aadc000
13935 old_mmap(0x2ab50000, 7948, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x64000) = 0x2ab50000
13935 old_mmap(0x2ab52000, 21888, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2ab52000
13935 close(3) = 0
13935 close(3) = 0
13935 stat("/lib/ld-uClibc.so.0", {st_mode=S_IFREG|0755, st_size=21528, ...}) = 0
13935 mprotect(0x2ab50000, 4096, PROT_READ) = 0
13935 mprotect(0x2aabc000, 4096, PROT_READ) = 0
13935 ioctl(0, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
13935 ioctl(1, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
13935 fork() = 13936
13935 exit(0) = ?
