[Problem] Error in patch-file freetz 1.2 für FB7340
nesq
8 Mai 2012
I'm trying to make an Freetz image for one of my FB7340 boxes but keep getting this error while making:
STEP 2: MODIFY
applying symlinks, deleting additional webinterfaces in: usr/www usr/www.nas
applying patches
ERROR: modpatch: Error in patch-file ./patches/7340/110-rc.S-mknod.patch
make: *** [firmware-nocompile] Fehler 2
I've tried freetz-1.2_rc2, freetz-1.2stable and 2 firmware versions (99.05.05) and searched the forum and freetz.org site without no luck.
You can only use firmwares listed in FIRMWARES. If you want to freetz 99.05.05 you have to use the trunk. For more information please read the FAQ on freetz.org.
Regards
Oliver
Hi Oliver,
Thanks, it works now. The thing I did wrong was renaming the 99.04.89 image file to 99.04.90 and putted it in dl/fw. Didn't knew that anymore 3 days later. I've downloaded a fresh 04.90 image and the image is built now.
