root@fritz:/var/mod/root# strace allcfgconv -c
execve("/bin/allcfgconv", ["allcfgconv", "-c"], [/* 215 vars */]) = 0
old_mmap(NULL, 20, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaad000
stat("/etc/ld-uClibc.so.cache", 0x7ff62548) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libboxlib.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libboxlib.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libboxlib.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libboxlib.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=137896, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaae000
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0i\220\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 192512, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aabe000
old_mmap(0x2aabe000, 117740, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aabe000
old_mmap(0x2aaea000, 8720, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1c000) = 0x2aaea000
close(3) = 0
munmap(0x2aaae000, 4096) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libar7cfg.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libar7cfg.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libar7cfg.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libar7cfg.so.1", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=249168, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0\340\20\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 303104, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaed000
old_mmap(0x2aaed000, 138892, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aaed000
old_mmap(0x2ab1f000, 95140, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x22000) = 0x2ab1f000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libavmcipher.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libavmcipher.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libavmcipher.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libavmcipher.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=45992, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0\v \0\0\0004"..., 4096) = 4096
old_mmap(NULL, 110592, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab37000
old_mmap(0x2ab37000, 42436, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab37000
old_mmap(0x2ab51000, 2048, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xa000) = 0x2ab51000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libavmhmac.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libavmhmac.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libavmhmac.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libavmhmac.so.2", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=14840, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0\0070\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 81920, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab52000
old_mmap(0x2ab52000, 12484, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab52000
old_mmap(0x2ab65000, 472, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x3000) = 0x2ab65000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libwdt.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libwdt.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libwdt.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libwdt.so.1", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=5848, ...}) = 0
old_mmap(NULL, 73728, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab66000
old_mmap(0x2ab66000, 4708, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab66000
old_mmap(0x2ab77000, 752, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x2ab77000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libavmcsock.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libavmcsock.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libavmcsock.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libavmcsock.so.2", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=369008, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0\234`\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 405504, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab78000
old_mmap(0x2ab78000, 305496, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab78000
old_mmap(0x2abd3000, 23980, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4b000) = 0x2abd3000
old_mmap(0x2abd9000, 7792, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2abd9000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libdl.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=9380, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0\0100\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 77824, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2abdb000
old_mmap(0x2abdb000, 6416, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2abdb000
old_mmap(0x2abec000, 4208, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x2abec000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libpthread.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=72732, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0004@\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 147456, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2abee000
old_mmap(0x2abee000, 50536, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2abee000
old_mmap(0x2ac0a000, 22440, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xc000) = 0x2ac0a000
old_mmap(0x2ac10000, 6816, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2ac10000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=72908, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0\32`\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 139264, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ac12000
old_mmap(0x2ac12000, 68324, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ac12000
old_mmap(0x2ac33000, 2068, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x11000) = 0x2ac33000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/ar7/../sharedlibs/../filesystem/lib/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libc.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=698592, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0\253\200\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 741376, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ac34000
old_mmap(0x2ac34000, 645188, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ac34000
old_mmap(0x2ace1000, 8260, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x9d000) = 0x2ace1000
old_mmap(0x2ace4000, 18784, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2ace4000
close(3) = 0
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libwebsrv.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libwebsrv.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libwebsrv.so.2", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=108992, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0008\300\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 167936, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ace9000
old_mmap(0x2ace9000, 95492, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ace9000
old_mmap(0x2ad10000, 5488, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x17000) = 0x2ad10000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libewnwnet.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libewnwnet.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libewnwnet.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=73804, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0002P\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 69632, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ad12000
old_mmap(0x2ad12000, 65380, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ad12000
old_mmap(0x2ad22000, 1012, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x10000) = 0x2ad22000
close(3) = 0
open("/home/jpluschke/FBox/0-spezial/GU_R_iks_7390/RELEASE_NETWORK_SOURCE_iks_build/sharedlibs/../filesystem/lib/libewnwlinux.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libewnwlinux.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libewnwlinux.so.2", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=81600, ...}) = 0
read(3, "\177ELF\1\2\1\0\0\0\0\0\0\0\0\0\0\3\0\10\0\0\0\1\0\0&\300\0\0\0004"..., 4096) = 4096
old_mmap(NULL, 143360, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ad23000
old_mmap(0x2ad23000, 73188, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ad23000
old_mmap(0x2ad45000, 892, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x12000) = 0x2ad45000
close(3) = 0
old_mmap(NULL, 23, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaaf000
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
stat("/lib/ld.so.1", {st_mode=S_IFREG|0755, st_size=22772, ...}) = 0
mprotect(0x2abec000, 4096, PROT_READ) = 0
mprotect(0x2ac0a000, 4096, PROT_READ) = 0
mprotect(0x2ace1000, 4096, PROT_READ) = 0
mprotect(0x2aabc000, 4096, PROT_READ) = 0
ioctl(0, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
ioctl(1, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
getpid() = 7527
getrlimit(RLIMIT_STACK, {rlim_cur=2147483647, rlim_max=699104*1024}) = 0
setrlimit(RLIMIT_STACK, {rlim_cur=2147483647, rlim_max=699104*1024}) = 0
rt_sigaction(SIGRT_0, {SIG_DFL, [RT_65 RT_66 RT_67 RT_68 RT_69 RT_70 RT_71 RT_75 RT_76 RT_77 RT_81 RT_82], SA_STACK|SA_INTERRUPT|SA_NOCLDWAIT|0x2be9cf4}, NULL, 16) = 0
rt_sigaction(SIGRT_1, {SIG_DFL, [RT_65 RT_66 RT_67 RT_68 RT_69 RT_70 RT_71 RT_75 RT_76 RT_77 RT_81 RT_82], SA_STACK|SA_INTERRUPT|SA_NOCLDWAIT|0x2be9c04}, NULL, 16) = 0
rt_sigaction(SIGRT_2, {SIG_DFL, [RT_65 RT_66 RT_67 RT_68 RT_69 RT_70 RT_71 RT_75 RT_76 RT_77 RT_81 RT_82], SA_STACK|SA_INTERRUPT|SA_NOCLDWAIT|0x2be9024}, NULL, 16) = 0
rt_sigprocmask(SIG_BLOCK, [RT_0], NULL, 16) = 0
rt_sigprocmask(SIG_UNBLOCK, [RT_1], NULL, 16) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab0000
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab1000
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab2000
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab3000
open("/proc/sys/dev/adam2/environment", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/proc/sys/urlader/environment", O_RDONLY) = 3
ioctl(3, TIOCNXCL, 0x7ff600f0) = -1 ENOTTY (Inappropriate ioctl for device)
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab4000
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab5000
read(3, "HWRevision\t156\nHWSubRevision\t0\nP"..., 8192) = 902
close(3) = 0
ioctl(3, TIOCNXCL, 0x7ff60040) = -1 ENOTTY (Inappropriate ioctl for device)
close(3) = 0
close(3) = 0
open("/proc/devices", O_RDONLY) = 3
ioctl(3, TIOCNXCL, 0x7ff625f8) = -1 ENOTTY (Inappropriate ioctl for device)
read(3, "Character devices:\n255 avm_net_t"..., 4096) = 526
close(3) = 0
access("/var/flash/crash.log", W_OK) = 0
sigaction(SIGSEGV, {0x40000008, [QUIT ILL IOT EMT FPE KILL SEGV SYS TERM USR1 USR2 CHLD WINCH URG IO TSTP TTIN VTALRM XCPU], 0}, NULL, 0) = 0
sigaction(SIGILL, {0x40000008, [QUIT ILL IOT EMT FPE KILL SEGV SYS TERM USR1 USR2 CHLD WINCH URG IO TSTP TTIN VTALRM XCPU], 0}, NULL, 0) = 0
sigaction(SIGBUS, {0x40000008, [QUIT ILL IOT EMT FPE KILL SEGV SYS TERM USR1 USR2 CHLD WINCH URG IO TSTP TTIN VTALRM XCPU], 0}, NULL, 0) = 0
sigaction(SIGFPE, {0x40000008, [QUIT ILL IOT EMT FPE KILL SEGV SYS TERM USR1 USR2 CHLD WINCH URG IO TSTP TTIN VTALRM XCPU], 0}, NULL, 0) = 0
sigaction(SIGIOT, {0x40000008, [QUIT ILL IOT EMT FPE KILL SEGV SYS TERM USR1 USR2 CHLD WINCH URG IO TSTP TTIN VTALRM XCPU], 0}, NULL, 0) = 0
sigaction(SIGQUIT, {0x40000008, [QUIT ILL IOT EMT FPE KILL SEGV SYS TERM USR1 USR2 CHLD WINCH URG IO TSTP TTIN VTALRM XCPU], 0}, NULL, 0) = 0
ioctl(3, TIOCNXCL, 0x7ff62648) = -1 ENOTTY (Inappropriate ioctl for device)
close(3) = 0
mkdir("/var", 0777) = -1 EEXIST (File exists)
mkdir("/var/flash", 0777) = -1 EEXIST (File exists)
unlink("/var/flash/ar7.cfg") = 0
mknod("/var/flash/ar7.cfg", S_IFCHR|0666, makedev(240, 113)) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab6000
open("/var/flash/ar7.cfg", O_RDONLY) = 3
ioctl(3, TIOCNXCL, 0x7ff61700) = -1 EOPNOTSUPP (Operation not supported)
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab7000
read(3, "/*\n * /var/flash/ar7.cfg\n * Tue "..., 4096) = 4096
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab8000
read(3, "\n dhcpend = 0.0.0"..., 4096) = 4096
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aab9000
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaba000
read(3, "ached = 10m;\n red"..., 4096) = 4096
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aabb000
read(3, "5\", \n "..., 4096) = 4096
read(3, "= 1;\n aut"..., 4096) = 4096
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ad46000
read(3, "oe;\n } {\n "..., 4096) = 4096
read(3, " retries = 0;\n "..., 4096) = 4096
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ad47000
read(3, " domain = \"\";\n "..., 4096) = 4096
read(3, " touchtime = 0w;\n "..., 4096) = 4096
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ad48000
read(3, " ip = 192.168.78.106;\n "..., 4096) = 4096
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ad49000
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ad4a000
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ad4b000
read(3, " }\n } {\n "..., 4096) = 4096
read(3, "\n allow_more = ye"..., 4096) = 2600
time(NULL) = 1286955039
read(3, "", 4096) = 0
close(3) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ad4c000
exit(0) = ?
