Dec 26 10:36:45 fritz daemon.info dnsmasq[14977]: started, version 2.78 cachesize 150
Dec 26 10:36:45 fritz daemon.info dnsmasq[14977]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect no-inotify
Dec 26 10:36:45 fritz daemon.info dnsmasq[14977]: DNSSEC validation enabled
Dec 26 10:36:45 fritz daemon.warn dnsmasq[14977]: warning: using interface lan instead
Dec 26 10:36:45 fritz daemon.info dnsmasq[14977]: asynchronous logging enabled, queue limit is 10 messages
Dec 26 10:36:45 fritz daemon.info dnsmasq[14977]: using nameserver 127.0.0.1#5353
Dec 26 10:36:45 fritz daemon.info dnsmasq[14977]: read /etc/hosts - 2 addresses
Dec 26 10:37:20 fritz daemon.info dnsmasq[14977]: query[A] www.ip-phone-forum.de from 192.168.2.105
Dec 26 10:37:20 fritz daemon.info dnsmasq[14977]: forwarded www.ip-phone-forum.de to 127.0.0.1
Dec 26 10:37:20 fritz daemon.info dnsmasq[14977]: validation result is INSECURE
Dec 26 10:37:20 fritz daemon.info dnsmasq[14977]: reply www.ip-phone-forum.de is 91.121.242.117
Dec 26 10:37:21 fritz daemon.info dnsmasq[14977]: query[A] fonts.googleapis.com from 192.168.2.105
Dec 26 10:37:21 fritz daemon.info dnsmasq[14977]: forwarded fonts.googleapis.com to 127.0.0.1
Dec 26 10:37:21 fritz daemon.info dnsmasq[14977]: validation result is INSECURE
Dec 26 10:37:21 fritz daemon.info dnsmasq[14977]: reply fonts.googleapis.com is <CNAME>
Dec 26 10:37:21 fritz daemon.info dnsmasq[14977]: reply googleadapis.l.google.com is 172.217.8.170
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: query[A] dnssec-debugger.verisignlabs.com from 192.168.2.105
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: forwarded dnssec-debugger.verisignlabs.com to 127.0.0.1
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: query[AAAA] dnssec-debugger.verisignlabs.com from 192.168.2.105
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: dnssec-query[DS] com to 127.0.0.1
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: dnssec-query[DNSKEY] . to 127.0.0.1
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply . is DNSKEY keytag 20326, algo 8
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply . is DNSKEY keytag 19036, algo 8
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply . is DNSKEY keytag 41824, algo 8
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply . is DNSKEY keytag 46809, algo 8
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply com is DS keytag 30909, algo 8, digest 2
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: dnssec-query[DS] verisignlabs.com to 127.0.0.1
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: dnssec-query[DNSKEY] com to 127.0.0.1
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply com is DNSKEY keytag 30909, algo 8
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply com is DNSKEY keytag 11324, algo 8
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply verisignlabs.com is DS keytag 19773, algo 8, digest 2
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: dnssec-query[DNSKEY] verisignlabs.com to 127.0.0.1
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply verisignlabs.com is DNSKEY keytag 60692, algo 8
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply verisignlabs.com is DNSKEY keytag 19773, algo 8
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply verisignlabs.com is DNSKEY keytag 55484, algo 8
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: validation result is SECURE
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply dnssec-debugger.verisignlabs.com is <CNAME>
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply dnssec-debugger-c.verisignlabs.com is 72.13.58.105
Dec 26 10:37:32 fritz daemon.info dnsmasq[15308]: query[A] dnssec-debugger.verisignlabs.com from 192.168.2.105
Dec 26 10:37:32 fritz daemon.info dnsmasq[15308]: cached dnssec-debugger.verisignlabs.com is <CNAME>
Dec 26 10:37:32 fritz daemon.info dnsmasq[15308]: cached dnssec-debugger-c.verisignlabs.com is 72.13.58.105
Dec 26 10:37:32 fritz daemon.info dnsmasq[15308]: query[AAAA] dnssec-debugger.verisignlabs.com from 192.168.2.105
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply dnssec-debugger-c.verisignlabs.com is 2620:74:13:4400::30d
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: query[A] www.ip-phone-forum.de from 192.168.2.105
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: cached www.ip-phone-forum.de is 91.121.242.117
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: query[AAAA] www.ip-phone-forum.de from 192.168.2.105
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: forwarded www.ip-phone-forum.de to 127.0.0.1
Dec 26 10:37:32 fritz daemon.info dnsmasq[15308]: forwarded dnssec-debugger.verisignlabs.com to 127.0.0.1
Dec 26 10:37:32 fritz daemon.info dnsmasq[15308]: validation result is SECURE
Dec 26 10:37:32 fritz daemon.info dnsmasq[15308]: reply dnssec-debugger.verisignlabs.com is <CNAME>
Dec 26 10:37:32 fritz daemon.info dnsmasq[15308]: reply dnssec-debugger-c.verisignlabs.com is 2620:74:13:4400::30d
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: validation result is INSECURE
Dec 26 10:37:32 fritz daemon.info dnsmasq[14977]: reply www.ip-phone-forum.de is NODATA-IPv6
Dec 26 10:37:36 fritz daemon.info dnsmasq[14977]: query[A] debianforum.de from 192.168.2.105
Dec 26 10:37:36 fritz daemon.info dnsmasq[14977]: forwarded debianforum.de to 127.0.0.1
Dec 26 10:37:36 fritz daemon.info dnsmasq[14977]: validation result is INSECURE
Dec 26 10:37:36 fritz daemon.info dnsmasq[14977]: reply debianforum.de is 144.76.154.165
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: query[A] www.debian.org from 192.168.2.105
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: forwarded www.debian.org to 127.0.0.1
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: query[AAAA] www.debian.org from 192.168.2.105
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: dnssec-query[DS] org to 127.0.0.1
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply org is DS keytag 9795, algo 7, digest 1
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply org is DS keytag 9795, algo 7, digest 2
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: dnssec-query[DS] debian.org to 127.0.0.1
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: dnssec-query[DNSKEY] org to 127.0.0.1
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply org is DNSKEY keytag 9795, algo 7
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply org is DNSKEY keytag 17883, algo 7
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply org is DNSKEY keytag 1862, algo 7
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply org is DNSKEY keytag 6368, algo 7
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply debian.org is DS keytag 6487, algo 8, digest 2
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: dnssec-query[DS] www.debian.org to 127.0.0.1
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: dnssec-query[DNSKEY] debian.org to 127.0.0.1
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply debian.org is DNSKEY keytag 6487, algo 8
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply debian.org is DNSKEY keytag 28725, algo 8
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply www.debian.org is DS keytag 15429, algo 8, digest 2
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: dnssec-query[DNSKEY] www.debian.org to 127.0.0.1
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply www.debian.org is DNSKEY keytag 15429, algo 8
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: validation result is SECURE
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply www.debian.org is 5.153.231.4
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply www.debian.org is 130.89.148.14
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply www.debian.org is 2001:41c8:1000:21::21:4
Dec 26 10:37:40 fritz daemon.info dnsmasq[14977]: reply www.debian.org is 2001:67c:2564:a119::148:14
Dec 26 10:37:40 fritz daemon.info dnsmasq[15309]: query[A] www.debian.org from 192.168.2.105
Dec 26 10:37:40 fritz daemon.info dnsmasq[15309]: cached www.debian.org is 130.89.148.14
Dec 26 10:37:40 fritz daemon.info dnsmasq[15309]: cached www.debian.org is 5.153.231.4
Dec 26 10:37:40 fritz daemon.info dnsmasq[15309]: query[AAAA] www.debian.org from 192.168.2.105
Dec 26 10:37:40 fritz daemon.info dnsmasq[15309]: cached www.debian.org is 2001:67c:2564:a119::148:14
Dec 26 10:37:40 fritz daemon.info dnsmasq[15309]: cached www.debian.org is 2001:41c8:1000:21::21:4
Dec 26 10:37:42 fritz daemon.info dnsmasq[14977]: query[A] tracker.debian.org from 192.168.2.105
Dec 26 10:37:42 fritz daemon.info dnsmasq[14977]: forwarded tracker.debian.org to 127.0.0.1
Dec 26 10:37:42 fritz daemon.info dnsmasq[14977]: query[AAAA] tracker.debian.org from 192.168.2.105
Dec 26 10:37:42 fritz daemon.info dnsmasq[14977]: validation result is SECURE
Dec 26 10:37:42 fritz daemon.info dnsmasq[14977]: reply tracker.debian.org is 5.153.231.23
Dec 26 10:37:42 fritz daemon.info dnsmasq[14977]: reply tracker.debian.org is 2001:41c8:1000:21::21:23
Dec 26 10:37:42 fritz daemon.info dnsmasq[15310]: query[A] tracker.debian.org from 192.168.2.105
Dec 26 10:37:42 fritz daemon.info dnsmasq[15310]: cached tracker.debian.org is 5.153.231.23
Dec 26 10:37:42 fritz daemon.info dnsmasq[15310]: query[AAAA] tracker.debian.org from 192.168.2.105
Dec 26 10:37:42 fritz daemon.info dnsmasq[15310]: cached tracker.debian.org is 2001:41c8:1000:21::21:23
