./install-start <- erfolgreich durchgeführt
(kernel.image - and
fw_Speedport_W701V_04.57-0_Fritz_Box_SpeedportW701V_04.59-0-sp2fr-28.08.08_OEM-avm_AnnexB_de.image
are now in output directory:
/home/slightly/Desktop/speed-to-fritz/Firmware.new)
./start-freetz.sh
Did you run speed-to-fritz to set up the variables in use' (y/n)?y
The update and install procedure has to be repeated until all errors are gone!
Do an update and installation of missing tools? (y/n)?y
Update ----->
Ign [url]http://www.openembedded.org[/url] packages/ Release.gpg
Ign [url]http://www.openembedded.org[/url] packages/ Packages/DiffIndex
Hole:1 [url]http://ftp.de.debian.org[/url] etch Release.gpg [386B]
Fehl [url]http://www.openembedded.org[/url] packages/ Packages
302 Found
OK [url]http://ftp.de.debian.org[/url] etch Release
Hole:2 [url]http://security.debian.org[/url] etch/updates Release.gpg [189B]
OK [url]http://security.debian.org[/url] etch/updates Release
Ign [url]http://ftp.de.debian.org[/url] etch/main Packages/DiffIndex
Ign [url]http://ftp.de.debian.org[/url] etch/non-free Packages/DiffIndex
Ign [url]http://ftp.de.debian.org[/url] etch/main Sources/DiffIndex
Ign [url]http://ftp.de.debian.org[/url] etch/non-free Sources/DiffIndex
OK [url]http://ftp.de.debian.org[/url] etch/main Packages
OK [url]http://ftp.de.debian.org[/url] etch/non-free Packages
OK [url]http://ftp.de.debian.org[/url] etch/main Sources
OK [url]http://ftp.de.debian.org[/url] etch/non-free Sources
Ign [url]http://security.debian.org[/url] etch/updates/main Packages/DiffIndex
Ign [url]http://security.debian.org[/url] etch/updates/contrib Packages/DiffIndex
Ign [url]http://security.debian.org[/url] etch/updates/non-free Packages/DiffIndex
Ign [url]http://security.debian.org[/url] etch/updates/main Sources/DiffIndex
Ign [url]http://security.debian.org[/url] etch/updates/contrib Sources/DiffIndex
Ign [url]http://security.debian.org[/url] etch/updates/non-free Sources/DiffIndex
OK [url]http://security.debian.org[/url] etch/updates/main Packages
OK [url]http://security.debian.org[/url] etch/updates/contrib Packages
OK [url]http://security.debian.org[/url] etch/updates/non-free Packages
OK [url]http://security.debian.org[/url] etch/updates/main Sources
OK [url]http://security.debian.org[/url] etch/updates/contrib Sources
OK [url]http://security.debian.org[/url] etch/updates/non-free Sources
Es wurden 2B in 1s geholt (2B/s)
Konnte [url]http://www.openembedded.org/dl/packages/Packages.gz[/url] nicht holen 302 Found
Paketlisten werden gelesen... Fertig
E: Einige Indexdateien konnten nicht heruntergeladen werden, sie wurden ignoriert oder alte an ihrer Stelle benutzt.
302 Found
302 Found
302 Found
End update <-----
Liegt es an diesen fehlenden Dateien evtl?
Execute: 'svn co [url]http://svn.freetz.org/trunk[/url] freetz-trunk' (y/n)? y
Looking for new freetz version, wait ...
Wieder hergestellt »freetz-trunk/Config.in«
Wieder hergestellt »freetz-trunk/fwmod«
Ausgecheckt, Revision 2554.
Image files present in './freetz-trunk/dl':
ls: ./freetz-trunk/dl/*.image: Datei oder Verzeichnis nicht gefunden
Now you can run 'make menuconfig', at the first time a lot of warnings will be displayed!
Select '7170' or '7150' suitable for your speedporttype 'W900, W701 or Sinus 500'
As next step run 'make'
But the used firmware has to be copied to the './freetz-trunk/dl' directory first,
if it is not present in ./speed-to-fritz/Firmware.orig at the time of starting this script.
If you did invoke speed-to-fritz before with the same firmwares in use, all should be present in:
'./freetz-trunk/dl' directory without copying the files after this script did run!
If started:
Ignore WARNINGS, especially the first time this tool is started!
Invoke 'make menuconfig' now? (y/n)? y
Nur Auswahl des openvpn-Packages, ansonsten keine Änderungen.
Be patient ...
Makefile:79: WARNING: uClibc-version changed. Packages, toolchain and some other stuff must be rebuilt. This will take a while
# using defaults found in .config
*** End of Freetz configuration.
*** Check the top-level Makefile for additional configuration options.
If started:
Be prepared that the first time this could take one hour or more!
Invoke 'make' now? (y/n)? y
Ganz, ganz viel make ...
gzip: stdin: invalid compressed data--crc error
tar: Child returned status 1
tar: Fehler beim Beenden, verursacht durch vorhergehende Fehler.
make: *** [source/avm-gpl-04.57/.unpacked] Fehler 2
./start-freetz.sh: line 268: ./freetz_var: Datei oder Verzeichnis nicht gefunden
