Compiling fails for 7170 when enabling Nanoseconds in busybox for date (which I need)
frater
23 Nov 2008
It works for other modems
  CC      coreutils/date.o
coreutils/date.c: In function 'date_main':
coreutils/date.c:255:23: error: 'struct stat' has no member named 'st_mtim'
make[2]: *** [coreutils/date.o] Error 1
make[1]: *** [coreutils] Error 2
make[1]: *** Waiting for unfinished jobs....
Can this be fixed?
There is no support for st_mtim in uClibc 0.9.29. You can try to use uClibc-0.9.32 and build your own toolchain (menuconfig).
Regards
Oliver
Try to replace statbuf.st_mtim.tv_nsec with statbuf.st_mtimensec in this line.
Didn't test it myself, but should work from reading the code.
Thanks er13
it Worked!
sed -i 's/statbuf.st_mtim.tv_nsec/statbuf.st_mtimensec/g' ./source/target-mipsel_uClibc-0.9.29/busybox-1.21.0/coreutils/date.c
