Cisco 7841 meldet sich nicht bei FB 7490
katip
5 Aug 2019
habe die neu FW drauf gespielt (sip78xx.12-5-1SR3-74)
Die config Datei habe ich wie folg vorbereitet:
SEPB2CDAAC1EEDF.cnf.xml
XML:
<?xml version="1.0" encoding="UTF-8"?>
<device>
   <deviceProtocol>SIP</deviceProtocol>
   <sshUserId>admin</sshUserId>
   <sshPassword>admin</sshPassword>
   <devicePool>
      <dateTimeSetting>
         <dateTemplate>d.m.yy</dateTemplate> <!-- Jahreszahl nur 2-stellig -->
         <timeZone>Central Europe Standard/Daylight Time</timeZone>
         <ntps>
            <ntp>
               <name>ntp1.t-online.de</name> <!-- IP des NTP Server. Hier die FRITZ!box -->
               <ntpMode>Unicast</ntpMode>
            </ntp>
         </ntps>
      </dateTimeSetting>
      <callManagerGroup>
         <members>
            <member priority="0">
               <callManager>
                  <ports>
                     <ethernetPhonePort>2000</ethernetPhonePort>
                     <sipPort>5060</sipPort>
                     <securedSipPort>5061</securedSipPort>
                  </ports>
                  <processNodeName>192.168.178.1</processNodeName> <!-- IP Adresse der FRITZ!box -->
               </callManager>
            </member>
         </members>
      </callManagerGroup>
   </devicePool>
   <commonProfile>
      <phonePassword></phonePassword>
      <backgroundImageAccess>true</backgroundImageAccess>
      <callLogBlfEnabled>2</callLogBlfEnabled>
   </commonProfile>
   <loadInformation>sip78xx.12-5-1SR3-74</loadInformation> <!-- Bezeichnung der zu ladenden Firmware -->
   <vendorConfig>
      <disableSpeaker>false</disableSpeaker>
      <disableSpeakerAndHeadset>false</disableSpeakerAndHeadset>
      <pcPort>0</pcPort>
      <settingsAccess>1</settingsAccess>
      <garp>0</garp>
      <voiceVlanAccess>0</voiceVlanAccess>
      <videoCapability>0</videoCapability>
      <autoSelectLineEnable>0</autoSelectLineEnable>
      <sshAccess>0</sshAccess>
      <sshPort>22</sshPort>
      <webAccess>0</webAccess>
      <spanToPCPort>1</spanToPCPort>
      <loggingDisplay>1</loggingDisplay>
      <loadServer></loadServer>
      <daysDisplayNotActive></daysDisplayNotActive>
      <displayOnTime>03:00</displayOnTime>
      <displayOnDuration>00:01</displayOnDuration>
      <displayIdleTimeout>00:05</displayIdleTimeout>
      <displayOnWhenIncomingCall>1</displayOnWhenIncomingCall>
   </vendorConfig>
   <deviceSecurityMode>1</deviceSecurityMode>
   <authenticationURL>http://192.168.178.1/ciscoauth.php</authenticationURL> <!-- wird nicht genutzt -->
   <directoryURL>http://192.168.178.1/directory.php</directoryURL> <!-- wird nicht genutzt -->
   <idleURL></idleURL>
   <informationURL></informationURL>
   <messagesURL></messagesURL>
   <proxyServerURL></proxyServerURL>
   <servicesURL></servicesURL>
   <dscpForSCCPPhoneConfig>96</dscpForSCCPPhoneConfig>
   <dscpForSCCPPhoneServices>0</dscpForSCCPPhoneServices>
   <dscpForCm2Dvce>96</dscpForCm2Dvce>
   <transportLayerProtocol>4</transportLayerProtocol>
   <capfAuthMode>0</capfAuthMode>
   <capfList>
      <capf>
         <phonePort>3772</phonePort>
      </capf>
   </capfList>
   <certHash></certHash>
   <encrConfig>false</encrConfig>
   <sipProfile>
      <sipProxies>
         <backupProxy></backupProxy>
         <backupProxyPort></backupProxyPort>
         <emergencyProxy></emergencyProxy>
         <emergencyProxyPort></emergencyProxyPort>
         <outboundProxy></outboundProxy>
         <outboundProxyPort></outboundProxyPort>
         <registerWithProxy>true</registerWithProxy>
      </sipProxies>
      <sipCallFeatures>
         <cnfJoinEnabled>true</cnfJoinEnabled>
         <callForwardURI>x--serviceuri-cfwdall</callForwardURI>
         <callPickupURI>x-cisco-serviceuri-pickup</callPickupURI>
         <callPickupListURI>x-cisco-serviceuri-opickup</callPickupListURI>
         <callPickupGroupURI>x-cisco-serviceuri-gpickup</callPickupGroupURI>
         <meetMeServiceURI>x-cisco-serviceuri-meetme</meetMeServiceURI>
         <abbreviatedDialURI>x-cisco-serviceuri-abbrdial</abbreviatedDialURI>
         <rfc2543Hold>false</rfc2543Hold>
         <callHoldRingback>2</callHoldRingback>
         <localCfwdEnable>true</localCfwdEnable>
         <semiAttendedTransfer>true</semiAttendedTransfer>
         <anonymousCallBlock>2</anonymousCallBlock>
         <callerIdBlocking>2</callerIdBlocking>
         <dndControl>0</dndControl>
         <remoteCcEnable>true</remoteCcEnable>
      </sipCallFeatures>
      <sipStack>
         <sipInviteRetx>6</sipInviteRetx>
         <sipRetx>10</sipRetx>
         <timerInviteExpires>180</timerInviteExpires>
         <timerRegisterExpires>3600</timerRegisterExpires>
         <timerRegisterDelta>5</timerRegisterDelta>
         <timerKeepAliveExpires>120</timerKeepAliveExpires>
         <timerSubscribeExpires>120</timerSubscribeExpires>
         <timerSubscribeDelta>5</timerSubscribeDelta>
         <timerT1>500</timerT1>
         <timerT2>4000</timerT2>
         <maxRedirects>70</maxRedirects>
         <remotePartyID>false</remotePartyID>
         <userInfo>None</userInfo>
      </sipStack>
      <autoAnswerTimer>1</autoAnswerTimer>
      <autoAnswerAltBehavior>false</autoAnswerAltBehavior>
      <autoAnswerOverride>true</autoAnswerOverride>
      <transferOnhookEnabled>false</transferOnhookEnabled>
      <enableVad>false</enableVad>
      <preferredCodec>none</preferredCodec>
      <dtmfAvtPayload>101</dtmfAvtPayload>
      <dtmfDbLevel>3</dtmfDbLevel>
      <dtmfOutofBand>avt</dtmfOutofBand>
      <alwaysUsePrimeLine>false</alwaysUsePrimeLine>
      <alwaysUsePrimeLineVoiceMail>false</alwaysUsePrimeLineVoiceMail>
      <kpml>3</kpml>
      <natEnabled>false</natEnabled>
      <natAddress></natAddress>
      <stutterMsgWaiting>0</stutterMsgWaiting>
      <callStats>false</callStats>
      <silentPeriodBetweenCallWaitingBursts>10</silentPeriodBetweenCallWaitingBursts>
      <disableLocalSpeedDialConfig>false</disableLocalSpeedDialConfig>
      <startMediaPort>16384</startMediaPort>
      <stopMediaPort>32766</stopMediaPort>
     <voipControlPort>5060</voipControlPort>
     <dscpForAudio>184</dscpForAudio>
     <ringSettingBusyStationPolicy>0</ringSettingBusyStationPolicy>
     <dialTemplate></dialTemplate>
      <phoneLabel>Office</phoneLabel>
      <sipLines>
         <!-- Konfiguriert die Funktionstasten neben dem Display
            <featureID>9</featureID> gilt für ausgehende Leitungen (primary Lines)
            <featureID>2</featureID> für Kurzwahltasten (Speed Dial)
         <line button="1">
            <featureLabel>Amt1</featureLabel>   <!-- Bezeichnung der Taste / Anzeige im Display -->
            <name>620</name>
            <displayName>Wohnzimmer</displayName>
            <contact>Wohnzimmer</contact>
             <!--Den folgenden Eintrag USECALLMANAGER so belassen. Wenn man hier die IP
             der FRITZ!box einträgt funktioniert die Konfiguration nicht. Die IP wird bereits
             oben im Abschnitt <callManagerGroup> definiert -->
            <proxy>USECALLMANAGER</proxy>
            <port>5060</port>
            <autoAnswer>
               <autoAnswerEnabled>2</autoAnswerEnabled>
            </autoAnswer>
            <callWaiting>3</callWaiting>
            <authName>myvoip</authName> <!-- Name des IP Telefons aus der FRITZ!box -->
            <authPassword>myvoip123456</authPassword> <!-- Passwort des IP Telefons aus der FRITZ!box -->
            <sharedLine>false</sharedLine>
            <messageWaitingLampPolicy>1</messageWaitingLampPolicy>
            <messagesNumber>*97</messagesNumber>
            <ringSettingIdle>4</ringSettingIdle>
            <ringSettingActive>5</ringSettingActive>
            <forwardCallInfoDisplay>
               <callerName>true</callerName>
               <callerNumber>true</callerNumber>
               <redirectedNumber>false</redirectedNumber>
               <dialedNumber>true</dialedNumber>
            </forwardCallInfoDisplay>
         </line>
         <!-- Die Tasten können frei belegt werden. Hier ein Beispiel für eine Kurzwhl -->
         <line button="6">
            <featureLabel>Notruf</featureLabel>
            <speedDialNumber>110</speedDialNumber>
         </line>
      </sipLines>
   </sipProfile>
</device>
auf dem Display vom Cisco steht seit über ne Stunde
"Registration in progress"
kann jemand mir sagen was ich hier falsch mache?
VG
katip
Ist der Benutzername für das IP-Telefon wirklich "myvoip"? Der Benutzername muss bei aktuellen FW-Versionen mindestens acht Zeichen lang sein (das steht ja sogar in der Eingabemaske der FB).
Benutzername und Passwort dürfen außerdem nicht identisch sein.
Der Name lautet eigentlich myvoip1980 und das Passwort ist eine Automarke mit Zahlen.
Könnte mir einer sagen ob die xml Datei in Ordnung ist?
Versuche mal als ntp-server die IP der Fritzbox. Dies führte manchmal iirc bei anderen Cisco-Modellen und bestimmten SIP-Firmware-Versionen zu Problemen.
LG
hi,
habe das abgeändert. Beim flashen bekomme ich nun folgendes von TFTPd64 LOG:
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac B4:A8:B9:4C:BD:C4 [06/08 18:47:53.057] DHCP: proposed address 192.168.0.100 [06/08 18:47:53.058] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac B4:A8:B9:4C:BD:C4 [06/08 18:47:53.070] Previously allocated address 192.168.0.100 acked [06/08 18:47:53.077] Connection received from 192.168.0.100 on port 50186 [06/08 18:48:08.880] Read request for file <CTLSEPB2CDAAC1EEDF.tlv>. Mode octet [06/08 18:48:08.880] File <CTLSEPB2CDAAC1EEDF.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:48:08.881] Connection received from 192.168.0.100 on port 49265 [06/08 18:48:15.726] Read request for file <ITLSEPB2CDAAC1EEDF.tlv>. Mode octet [06/08 18:48:15.726] File <ITLSEPB2CDAAC1EEDF.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:48:15.726] Connection received from 192.168.0.100 on port 51970 [06/08 18:48:22.517] Read request for file <ITLFile.tlv>. Mode octet [06/08 18:48:22.518] File <ITLFile.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:48:22.518] Connection received from 192.168.0.100 on port 49863 [06/08 18:48:29.531] Read request for file <SEPB2CDAAC1EEDF.cnf.xml>. Mode octet [06/08 18:48:29.531] Using local port 63162 [06/08 18:48:29.531] <SEPB2CDAAC1EEDF.cnf.xml>: sent 17 blks, 8458 bytes in 0 s. 0 blk resent [06/08 18:48:29.542] Connection received from 192.168.0.100 on port 50895 [06/08 18:48:41.842] Read request for file </sp-sip.jar>. Mode octet [06/08 18:48:41.843] File <sp-sip.jar> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:48:41.843] Connection received from 192.168.0.100 on port 50866 [06/08 18:48:48.679] Read request for file </g3-tones.xml>. Mode octet [06/08 18:48:48.679] File <g3-tones.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:48:48.680] Connection received from 192.168.0.100 on port 49555 [06/08 18:48:57.460] Read request for file <dialplan.xml>. Mode octet [06/08 18:48:57.460] File <dialplan.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:48:57.460] Connection received from 192.168.0.100 on port 50020 [06/08 18:49:04.549] Read request for file <CTLSEPB2CDAAC1EEDF.tlv>. Mode octet [06/08 18:49:04.550] File <CTLSEPB2CDAAC1EEDF.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:49:04.550] Connection received from 192.168.0.100 on port 50232 [06/08 18:49:11.354] Read request for file <ITLSEPB2CDAAC1EEDF.tlv>. Mode octet [06/08 18:49:11.355] File <ITLSEPB2CDAAC1EEDF.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:49:11.355] Connection received from 192.168.0.100 on port 51389 [06/08 18:49:18.153] Read request for file <ITLFile.tlv>. Mode octet [06/08 18:49:18.153] File <ITLFile.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:49:18.154] Connection received from 192.168.0.100 on port 50026 [06/08 18:49:25.076] Read request for file <SEPB2CDAAC1EEDF.cnf.xml>. Mode octet [06/08 18:49:25.076] Using local port 63349 [06/08 18:49:25.076] <SEPB2CDAAC1EEDF.cnf.xml>: sent 17 blks, 8458 bytes in 0 s. 0 blk resent [06/08 18:49:25.087] Connection received from 192.168.0.100 on port 49558 [06/08 18:49:36.185] Read request for file </sp-sip.jar>. Mode octet [06/08 18:49:36.185] File <sp-sip.jar> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:49:36.186] Connection received from 192.168.0.100 on port 51747 [06/08 18:49:43.006] Read request for file </g3-tones.xml>. Mode octet [06/08 18:49:43.006] File <g3-tones.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:49:43.006] Connection received from 192.168.0.100 on port 50900 [06/08 18:49:51.426] Read request for file <dialplan.xml>. Mode octet [06/08 18:49:51.427] File <dialplan.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [06/08 18:49:51.427] Rcvd DHCP Rqst Msg for IP 192.168.0.100, Mac B4:A8:B9:4C:BD:C4 [06/08 18:49:55.251] Previously allocated address 192.168.0.100 acked [06/08 18:49:55.252] Rcvd DHCP Rqst Msg for IP 192.168.0.100, Mac B4:A8:B9:4C:BD:C4 [06/08 18:51:56.378] Previously allocated address 192.168.0.100 acked [06/08 18:51:56.379]
192.168.0.100 gehört aber schon zu einem anderen IP-Bereich wie 192.168.178.1 der Fritzbox? Da scheinen TFTP-Server FB und CISCO in unterschiedlichen Netzen zu agieren, was eher nicht trivial ist, ohne weitere Angaben.
LG
um zu flshen, verbinde ich das IP Telefon mit dem PC direkt über die zweite Netzwerkkarte.
Diese ist mit 192.168.0.99 Mask:255.255.255.0 konfiguriert.
