cant find where to add external file
e-r-a-n
4 Okt 2012
I have upgraded my freetz to a new revision and added some more packages i was interested in
however, after installing the new .image (freetz-trunk) i have two issues:
1. i cant find in the freetz menus where to load the external file. where is it ?
2. I have no dsl sync at all. the dsl led is blinking constantly.
EDIT:
I reverted back to my old ver. rev. 9445 and it works.
however, i really want to have minidlna package.
is it possible to install it via ssh somehow?
do i really have to go over all the installation & build process for just adding a feature?
And again.
Yes you have to use the new firmware. The external upload is on the firmware update page. (Freetz Webinterface)
Please post your .config and the output of dmesg/syslog to analyze your DSL problems.
Regards
Oliver
