allcfgconv: /var/flash/voip.cfg:19: member authenticatemode not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:19: member authenticatemode not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:20: member infodtmfnotsupported not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:20: member infodtmfnotsupported not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:34: member is_ddi not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:34: member is_ddi not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:47: member authenticatemode not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:47: member authenticatemode not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:48: member infodtmfnotsupported not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:48: member infodtmfnotsupported not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:62: member is_ddi not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:62: member is_ddi not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:75: member authenticatemode not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:75: member authenticatemode not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:76: member infodtmfnotsupported not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:76: member infodtmfnotsupported not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:90: member is_ddi not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:90: member is_ddi not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:103: member authenticatemode not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:103: member authenticatemode not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:104: member infodtmfnotsupported not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:104: member infodtmfnotsupported not in uacfg, try to recover
allcfgconv: /var/flash/voip.cfg:118: member is_ddi not found in ST_struct uacfg
allcfgconv: /var/flash/voip.cfg:118: member is_ddi not in uacfg, try to recover
allcfgconv: load_config(voip): warning: converted
Generating short names for all SIP accounts ...
