habe das Gefühl wir kommen der Sache näher
Noch einen TIPP?
Nachtrag...
kann es sein, dass es sn der falschen Uhrzeit liegt? Die Box zeigt mit Ein Datum aus dem Jahr 2000 an...
Running openvpn --cd /var/mobile/Documents/Configurations/iphone --config "iphone.ovpn" --auto-proxy
Sun May 19 17:15:46 2013 OpenVPN 2.2.1_GuizmOVPN_1.1.9 arm-apple-darwin10 [SSL] [LZO2] [eurephia] built on Feb 23 2013
Sun May 19 17:18:56 2013 IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA. OpenVPN 2.0-beta16 and earlier used 5000 as the default port.
Sun May 19 17:18:56 2013 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sun May 19 17:18:56 2013 Re-using SSL/TLS context
Sun May 19 17:18:56 2013 Control Channel MTU parms [ L:1573 D:138 EF:38 EB:0 ET:0 EL:0 ]
Sun May 19 17:18:56 2013 Socket Buffers: R=[42080->65536] S=[9216->65536]
Sun May 19 17:18:56 2013 Data Channel MTU parms [ L:1573 D:1450 EF:41 EB:4 ET:32 EL:0 ]
Sun May 19 17:18:56 2013 Local Options hash (VER=V4): '2c50bd2c'
Sun May 19 17:18:56 2013 Expected Remote Options hash (VER=V4): '0ddbb6e3'
Sun May 19 17:18:56 2013 UDPv4 link local (bound): [undef]:1194
Sun May 19 17:18:56 2013 UDPv4 link remote: 93.xx.xx.xxx:1194
Sun May 19 17:19:12 2013 TLS: Initial packet from 93.1xx.xx.xxx:1194, sid=7e73cb97 e899c702
Sun May 19 17:19:14 2013 VERIFY OK: depth=1, /C=DE/ST=NRW/L=D/O=OpenVPN/OU=JayOU/CN=JAY/name=JayComp/emailAddress=*meineMail*@gmx.de
Sun May 19 17:19:14 2013 VERIFY OK: depth=0, /C=DE/ST=NRW/L=D/O=OpenVPN/OU=JayOU/CN=JAY/name=JayComp/emailAddress=*hier steht meine mail*@gmx.de
Sun May 19 17:19:15 2013 TLS_ERROR: BIO read tls_read_plaintext error: error:1408F119:SSL routines:SSL3_GET_RECORD:decryption failed or bad record mac
Sun May 19 17:19:15 2013 TLS Error: TLS object -> incoming plaintext read error
Sun May 19 17:19:15 2013 TLS Error: TLS handshake failed
Sun May 19 17:19:15 2013 TCP/UDP: Closing socket
Sun May 19 17:19:15 2013 SIGUSR1[soft,tls-error] received, process restarting
Sun May 19 17:19:16 2013 Restart pause, 2 second(s)
Noch einen TIPP?
Nachtrag...
