[2015-07-27 13:47:26] VERBOSE[1994] chan_sip.c: Reliably Transmitting (no NAT) to IP_ADR_N510:5060:
OPTIONS sip:1000@IP_ADR_N510:5060 SIP/2.0
Via: SIP/2.0/UDP IP_ADR_PBX:5060;branch=z9hG4bK474216dd
Max-Forwards: 70
From: "Unknown" <sip:Unknown@IP_ADR_PBX>;tag=as2caa67a9
To: <sip:1000@IP_ADR_N510:5060>
Contact: <sip:Unknown@IP_ADR_PBX:5060>
Call-ID: 0ac46316084dbfb67d9b3bcd1e42c320@IP_ADR_PBX:5060
CSeq: 102 OPTIONS
User-Agent: FPBX-12.0.74(11.18.0)
Date: Mon, 27 Jul 2015 11:47:26 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
Content-Length: 0
<--- SIP read from UDP:IP_ADR_N510:5060 --->
SIP/2.0 200 OK
To: <sip:1000@IP_ADR_N510:5060>;tag=ar3baa76a8
CSeq: 102 OPTIONS
Supported: replaces
User-Agent: N510 IP PRO/42.210.00.000.000
Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, INFO, SUBSCRIBE, NOTIFY, REFER
Accept: application/sdp,application/dtmf-relay,application/simple-message-summary,message/sipfrag
Accept-Encoding: identity
Accept-Language: en
Content-Length: 0
[2015-07-27 13:47:26] VERBOSE[1994] chan_sip.c: --- (13 headers 0 lines) ---
[2015-07-27 13:47:26] VERBOSE[1994] chan_sip.c: Really destroying SIP dialog '0ac46316084dbfb67d9b3bcd1e42c320@IP_ADR_PBX:5060' Method: OPTIONS
[2015-07-27 13:47:34] VERBOSE[1994][C-0000000b] netsock2.c: == Using SIP RTP TOS bits 184
[2015-07-27 13:47:34] VERBOSE[1994][C-0000000b] netsock2.c: == Using SIP RTP CoS mark 5
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk-sip-tr-fb620:1] Set("SIP/tr-fb620-00000014", "GROUP()=OUT_2") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk-sip-tr-fb620:2] Goto("SIP/tr-fb620-00000014", "from-trunk,620,1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (from-trunk,620,1)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:1] Set("SIP/tr-fb620-00000014", "__FROM_DID=620") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:2] Gosub("SIP/tr-fb620-00000014", "sub-record-check,s,1(in,620,dontcare)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:1] GotoIf("SIP/tr-fb620-00000014", "0?initialized") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:2] Set("SIP/tr-fb620-00000014", "__REC_STATUS=INITIALIZED") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:3] Set("SIP/tr-fb620-00000014", "NOW=1437997654") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:4] Set("SIP/tr-fb620-00000014", "__DAY=27") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:5] Set("SIP/tr-fb620-00000014", "__MONTH=07") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:6] Set("SIP/tr-fb620-00000014", "__YEAR=2015") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:7] Set("SIP/tr-fb620-00000014", "__TIMESTR=20150727-134734") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:8] Set("SIP/tr-fb620-00000014", "__FROMEXTEN=unknown") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:9] Set("SIP/tr-fb620-00000014", "__MON_FMT=wav") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:10] NoOp("SIP/tr-fb620-00000014", "Recordings initialized") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:11] ExecIf("SIP/tr-fb620-00000014", "0?Set(ARG3=dontcare)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:12] Set("SIP/tr-fb620-00000014", "REC_POLICY_MODE_SAVE=") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:13] ExecIf("SIP/tr-fb620-00000014", "0?Set(REC_STATUS=NO)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:14] GotoIf("SIP/tr-fb620-00000014", "2?checkaction") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (sub-record-check,s,17)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:17] GotoIf("SIP/tr-fb620-00000014", "1?sub-record-check,in,1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (sub-record-check,in,1)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [in@sub-record-check:1] NoOp("SIP/tr-fb620-00000014", "Inbound Recording Check to 620") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [in@sub-record-check:2] Set("SIP/tr-fb620-00000014", "FROMEXTEN=unknown") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [in@sub-record-check:3] ExecIf("SIP/tr-fb620-00000014", "11?Set(FROMEXTEN=TEL_EXT)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [in@sub-record-check:4] Gosub("SIP/tr-fb620-00000014", "recordcheck,1(dontcare,in,620)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [recordcheck@sub-record-check:1] NoOp("SIP/tr-fb620-00000014", "Starting recording check against dontcare") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [recordcheck@sub-record-check:2] Goto("SIP/tr-fb620-00000014", "dontcare") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (sub-record-check,recordcheck,3)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [recordcheck@sub-record-check:3] Return("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [in@sub-record-check:5] Return("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:3] Gosub("SIP/tr-fb620-00000014", "app-blacklist-check,s,1()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@app-blacklist-check:1] GotoIf("SIP/tr-fb620-00000014", "0?blacklisted") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@app-blacklist-check:2] Set("SIP/tr-fb620-00000014", "CALLED_BLACKLIST=1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@app-blacklist-check:3] Return("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:4] Set("SIP/tr-fb620-00000014", "CDR(did)=620") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:5] ExecIf("SIP/tr-fb620-00000014", "1 ?Set(CALLERID(name)=TEL_EXT)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:6] Set("SIP/tr-fb620-00000014", "CHANNEL(musicclass)=default") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:7] Set("SIP/tr-fb620-00000014", "__MOHCLASS=default") in new stack
[2015-07-27 13:47:34] WARNING[17178][C-0000000b] func_channel.c: Unknown or unavailable item requested: 'reversecharge'
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:8] GotoIf("SIP/tr-fb620-00000014", "0?macro-hangupcall") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:9] Set("SIP/tr-fb620-00000014", "__CALLINGPRES_SV=allowed_not_screened") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:10] Set("SIP/tr-fb620-00000014", "CALLERPRES()=allowed_not_screened") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [620@from-trunk:11] Goto("SIP/tr-fb620-00000014", "from-did-direct,1001,1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (from-did-direct,1001,1)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [1001@from-did-direct:1] GotoIf("SIP/tr-fb620-00000014", "1?ext-local,1001,1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (ext-local,1001,1)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [1001@ext-local:1] Set("SIP/tr-fb620-00000014", "__RINGTIMER=20") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [1001@ext-local:2] Macro("SIP/tr-fb620-00000014", "exten-vm,1001,1001,0,0,0") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:1] Macro("SIP/tr-fb620-00000014", "user-callerid,") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:1] Set("SIP/tr-fb620-00000014", "TOUCH_MONITOR=1437997654.20") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:2] Set("SIP/tr-fb620-00000014", "AMPUSER=TEL_EXT") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:3] GotoIf("SIP/tr-fb620-00000014", "0?report") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:4] ExecIf("SIP/tr-fb620-00000014", "1?Set(REALCALLERIDNUM=TEL_EXT)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:5] Set("SIP/tr-fb620-00000014", "AMPUSER=") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:6] GotoIf("SIP/tr-fb620-00000014", "0?limit") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:7] Set("SIP/tr-fb620-00000014", "AMPUSERCIDNAME=") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:8] GotoIf("SIP/tr-fb620-00000014", "1?report") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (macro-user-callerid,s,16)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:16] GotoIf("SIP/tr-fb620-00000014", "0?continue") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:17] ExecIf("SIP/tr-fb620-00000014", "1?Set(__CALLEE_ACCOUNCODE=2001)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:18] Set("SIP/tr-fb620-00000014", "__TTL=64") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:19] GotoIf("SIP/tr-fb620-00000014", "1?continue") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (macro-user-callerid,s,30)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:30] Set("SIP/tr-fb620-00000014", "CALLERID(number)=TEL_EXT") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:31] Set("SIP/tr-fb620-00000014", "CALLERID(name)=TEL_EXT") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:32] Set("SIP/tr-fb620-00000014", "CDR(cnum)=TEL_EXT") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:33] Set("SIP/tr-fb620-00000014", "CDR(cnam)=TEL_EXT") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-user-callerid:34] Set("SIP/tr-fb620-00000014", "CHANNEL(language)=en") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:2] Set("SIP/tr-fb620-00000014", "RingGroupMethod=none") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:3] Set("SIP/tr-fb620-00000014", "__EXTTOCALL=1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:4] Set("SIP/tr-fb620-00000014", "__PICKUPMARK=1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:5] Set("SIP/tr-fb620-00000014", "RT=20") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:6] ExecIf("SIP/tr-fb620-00000014", "0?Macro(vm,1001,DIRECTDIAL,)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:7] ExecIf("SIP/tr-fb620-00000014", "0?MacroExit()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:8] Gosub("SIP/tr-fb620-00000014", "sub-record-check,s,1(exten,1001,dontcare)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:1] GotoIf("SIP/tr-fb620-00000014", "11?initialized") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (sub-record-check,s,10)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:14] GotoIf("SIP/tr-fb620-00000014", "5?checkaction") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@sub-record-check:17] GotoIf("SIP/tr-fb620-00000014", "1?sub-record-check,exten,1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (sub-record-check,exten,1)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [exten@sub-record-check:1] NoOp("SIP/tr-fb620-00000014", "Exten Recording Check between TEL_EXT and 1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [exten@sub-record-check:2] Set("SIP/tr-fb620-00000014", "CALLTYPE=external") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [exten@sub-record-check:3] ExecIf("SIP/tr-fb620-00000014", "0?Set(CALLTYPE=)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [exten@sub-record-check:4] Set("SIP/tr-fb620-00000014", "CALLEE=no") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [exten@sub-record-check:5] ExecIf("SIP/tr-fb620-00000014", "0?Set(CALLEE=dontcare)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [exten@sub-record-check:6] GotoIf("SIP/tr-fb620-00000014", "1?callee") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (sub-record-check,exten,11)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [exten@sub-record-check:11] Gosub("SIP/tr-fb620-00000014", "recordcheck,1(no,external,1001)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [recordcheck@sub-record-check:1] NoOp("SIP/tr-fb620-00000014", "Starting recording check against no") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [recordcheck@sub-record-check:2] Goto("SIP/tr-fb620-00000014", "no") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (sub-record-check,recordcheck,12)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [recordcheck@sub-record-check:12] Set("SIP/tr-fb620-00000014", "__REC_POLICY_MODE=NO") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [recordcheck@sub-record-check:13] Return("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [exten@sub-record-check:12] Return("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:9] GotoIf("SIP/tr-fb620-00000014", "1?macrodial") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (macro-exten-vm,s,15)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:15] GosubIf("SIP/tr-fb620-00000014", "0?clrheader,1()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-exten-vm:16] Macro("SIP/tr-fb620-00000014", "dial-one,20,Ttr,1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:1] Set("SIP/tr-fb620-00000014", "DEXTEN=1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:2] Set("SIP/tr-fb620-00000014", "DIALSTATUS_CW=") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:3] GosubIf("SIP/tr-fb620-00000014", "0?screen,1()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:4] GosubIf("SIP/tr-fb620-00000014", "0?cf,1()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:5] GotoIf("SIP/tr-fb620-00000014", "1?skip1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (macro-dial-one,s,8)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:8] GotoIf("SIP/tr-fb620-00000014", "0?nodial") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:9] GotoIf("SIP/tr-fb620-00000014", "0?continue") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:10] Set("SIP/tr-fb620-00000014", "EXTHASCW=ENABLED") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:11] GotoIf("SIP/tr-fb620-00000014", "0?next1:cwinusebusy") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (macro-dial-one,s,23)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:23] GotoIf("SIP/tr-fb620-00000014", "1?next3:continue") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (macro-dial-one,s,24)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:24] ExecIf("SIP/tr-fb620-00000014", "0?Set(DIALSTATUS_CW=BUSY)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:25] GotoIf("SIP/tr-fb620-00000014", "0?nodial") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:26] GosubIf("SIP/tr-fb620-00000014", "1?dstring,1():dlocal,1()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:1] Set("SIP/tr-fb620-00000014", "DSTRING=") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:2] Set("SIP/tr-fb620-00000014", "DEVICES=1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:3] ExecIf("SIP/tr-fb620-00000014", "0?Return()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:4] ExecIf("SIP/tr-fb620-00000014", "0?Set(DEVICES=001)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:5] Set("SIP/tr-fb620-00000014", "LOOPCNT=1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:6] Set("SIP/tr-fb620-00000014", "ITER=1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:7] Set("SIP/tr-fb620-00000014", "THISDIAL=SIP/1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:8] GosubIf("SIP/tr-fb620-00000014", "1?zap2dahdi,1()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:1] ExecIf("SIP/tr-fb620-00000014", "0?Return()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:2] Set("SIP/tr-fb620-00000014", "NEWDIAL=") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:3] Set("SIP/tr-fb620-00000014", "LOOPCNT2=1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:4] Set("SIP/tr-fb620-00000014", "ITER2=1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:5] Set("SIP/tr-fb620-00000014", "THISPART2=SIP/1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:6] ExecIf("SIP/tr-fb620-00000014", "0?Set(THISPART2=DAHDI/1001)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:7] Set("SIP/tr-fb620-00000014", "NEWDIAL=SIP/1001&") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:8] Set("SIP/tr-fb620-00000014", "ITER2=2") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:9] GotoIf("SIP/tr-fb620-00000014", "0?begin2") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:10] Set("SIP/tr-fb620-00000014", "THISDIAL=SIP/1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [zap2dahdi@macro-dial-one:11] Return("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:9] GotoIf("SIP/tr-fb620-00000014", "1?doset") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (macro-dial-one,dstring,13)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:13] Set("SIP/tr-fb620-00000014", "DSTRING=SIP/1001&") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:14] Set("SIP/tr-fb620-00000014", "ITER=2") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:15] GotoIf("SIP/tr-fb620-00000014", "0?begin") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:16] ExecIf("SIP/tr-fb620-00000014", "0?Return()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:17] Set("SIP/tr-fb620-00000014", "DSTRING=SIP/1001") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [dstring@macro-dial-one:18] Return("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:27] GotoIf("SIP/tr-fb620-00000014", "0?nodial") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:28] GotoIf("SIP/tr-fb620-00000014", "0?skiptrace") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:29] GosubIf("SIP/tr-fb620-00000014", "1?ctset,1():ctclear,1()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [ctset@macro-dial-one:1] Set("SIP/tr-fb620-00000014", "DB(CALLTRACE/1001)=TEL_EXT") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [ctset@macro-dial-one:2] Return("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:30] Set("SIP/tr-fb620-00000014", "D_OPTIONS=Ttr") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:31] ExecIf("SIP/tr-fb620-00000014", "0?SIPAddHeader(Alert-Info: )") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:32] ExecIf("SIP/tr-fb620-00000014", "0?SIPAddHeader()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:33] ExecIf("SIP/tr-fb620-00000014", "1?Set(CHANNEL(musicclass)=default)") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:34] GosubIf("SIP/tr-fb620-00000014", "0?qwait,1()") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:35] Set("SIP/tr-fb620-00000014", "__CWIGNORE=") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:36] Set("SIP/tr-fb620-00000014", "__KEEPCID=TRUE") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:37] GotoIf("SIP/tr-fb620-00000014", "0?usegoto,1") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:38] GotoIf("SIP/tr-fb620-00000014", "1?godial") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (macro-dial-one,s,43)
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:43] Macro("SIP/tr-fb620-00000014", "dialout-one-predial-hook,") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dialout-one-predial-hook:1] MacroExit("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-dial-one:44] Dial("SIP/tr-fb620-00000014", "SIP/1001,20,Ttr") in new stack
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] netsock2.c: == Using SIP RTP TOS bits 184
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] netsock2.c: == Using SIP RTP CoS mark 5
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] chan_sip.c: Audio is at 19274
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] chan_sip.c: Adding codec 100004 (alaw) to SDP
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] chan_sip.c: Adding codec 100003 (ulaw) to SDP
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] chan_sip.c: Adding codec 100002 (gsm) to SDP
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] chan_sip.c: Adding codec 100011 (g726) to SDP
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] chan_sip.c: Adding non-codec 0x1 (telephone-event) to SDP
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] chan_sip.c: Reliably Transmitting (no NAT) to IP_ADR_N510:5060:
INVITE sip:1001@IP_ADR_N510:5060 SIP/2.0
Via: SIP/2.0/UDP IP_ADR_PBX:5060;branch=z9hG4bK73bb53c7
Max-Forwards: 70
From: "TEL_EXT" <sip:TEL_EXT@IP_ADR_PBX>;tag=as62015720
To: <sip:1001@IP_ADR_N510:5060>
Contact: <sip:TEL_EXT@IP_ADR_PBX:5060>
Call-ID: 2df1981b29daa0d97e601e2753d7b4ff@IP_ADR_PBX:5060
CSeq: 102 INVITE
Date: Mon, 27 Jul 2015 11:47:34 GMT
P-Asserted-Identity: "TEL_EXT" <sip:TEL_EXT@IP_ADR_PBX>
Content-Type: application/sdp
Content-Length: 316
v=0
o=root 1876418300 1876418300 IN IP4 IP_ADR_PBX
s=Asterisk PBX 11.18.0
c=IN IP4 IP_ADR_PBX
t=0 0
m=audio 19274 RTP/AVP 8 0 3 111 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:3 GSM/8000
a=rtpmap:111 G726-32/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
[2015-07-27 13:47:34] VERBOSE[17178][C-0000000b] app_dial.c: -- Called SIP/1001
[2015-07-27 13:47:34] VERBOSE[1994] chan_sip.c:
SIP/2.0 100 Trying
To: <sip:1001@IP_ADR_N510:5060>;tag=818420201
CSeq: 102 INVITE
Contact: <sip:1001@IP_ADR_N510:5060>
Content-Length: 0
[2015-07-27 13:47:34] VERBOSE[1994] chan_sip.c: --- (9 headers 0 lines) ---
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] chan_sip.c: Scheduling destruction of SIP dialog '2df1981b29daa0d97e601e2753d7b4ff@IP_ADR_PBX:5060' in 6400 ms (Method: INVITE)
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] chan_sip.c: Reliably Transmitting (no NAT) to IP_ADR_N510:5060:
CANCEL sip:1001@IP_ADR_N510:5060 SIP/2.0
Max-Forwards: 70
CSeq: 102 CANCEL
Content-Length: 0
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] app_macro.c: == Spawn extension (macro-dial-one, s, 44) exited non-zero on 'SIP/tr-fb620-00000014' in macro 'dial-one'
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] app_macro.c: == Spawn extension (macro-exten-vm, s, 16) exited non-zero on 'SIP/tr-fb620-00000014' in macro 'exten-vm'
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] pbx.c: == Spawn extension (ext-local, 1001, 2) exited non-zero on 'SIP/tr-fb620-00000014'
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [h@ext-local:1] Macro("SIP/tr-fb620-00000014", "hangupcall,") in new stack
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-hangupcall:1] ExecIf("SIP/tr-fb620-00000014", "0?Set(CDR(recordingfile)=.wav)") in new stack
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-hangupcall:2] GotoIf("SIP/tr-fb620-00000014", "1?theend") in new stack
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] pbx.c: -- Goto (macro-hangupcall,s,4)
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] pbx.c: -- Executing [s@macro-hangupcall:4] Hangup("SIP/tr-fb620-00000014", "") in new stack
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] app_macro.c: == Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'SIP/tr-fb620-00000014' in macro 'hangupcall'
[2015-07-27 13:47:35] VERBOSE[17178][C-0000000b] pbx.c: == Spawn extension (ext-local, h, 1) exited non-zero on 'SIP/tr-fb620-00000014'
[2015-07-27 13:47:35] VERBOSE[1994] chan_sip.c:
SIP/2.0 200 OK
CSeq: 102 CANCEL
Content-Length: 0
[2015-07-27 13:47:35] VERBOSE[1994] chan_sip.c: --- (9 headers 0 lines) ---
SIP/2.0 487 Request Cancelled
CSeq: 102 INVITE
Content-Length: 0
[2015-07-27 13:47:35] VERBOSE[1994][C-0000000b] chan_sip.c: Transmitting (no NAT) to IP_ADR_N510:5060:
ACK sip:1001@IP_ADR_N510:5060 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
[2015-07-27 13:47:35] VERBOSE[1994][C-0000000b] chan_sip.c: Scheduling destruction of SIP dialog '2df1981b29daa0d97e601e2753d7b4ff@IP_ADR_PBX:5060' in 6400 ms (Method: INVITE)
[2015-07-27 13:47:37] VERBOSE[1994] chan_sip.c: Reliably Transmitting (no NAT) to IP_ADR_N510:5060:
OPTIONS sip:1001@IP_ADR_N510:5060 SIP/2.0
Via: SIP/2.0/UDP IP_ADR_PBX:5060;branch=z9hG4bK1af82f0c
Max-Forwards: 70
From: "Unknown" <sip:Unknown@IP_ADR_PBX>;tag=as433297ca
Call-ID: 66bc5bc911b610581a374ff7390ae25d@IP_ADR_PBX:5060
CSeq: 102 OPTIONS
Date: Mon, 27 Jul 2015 11:47:37 GMT
Content-Length: 0
SIP/2.0 200 OK
To: <sip:1001@IP_ADR_N510:5060>;tag=ar522386ba
CSeq: 102 OPTIONS
Supported: replaces
Accept-Language: en
Content-Length: 0
[2015-07-27 13:47:37] VERBOSE[1994] chan_sip.c: --- (13 headers 0 lines) ---
[2015-07-27 13:47:37] VERBOSE[1994] chan_sip.c: Really destroying SIP dialog '66bc5bc911b610581a374ff7390ae25d@IP_ADR_PBX:5060' Method: OPTIONS
[2015-07-27 13:47:41] VERBOSE[1994] chan_sip.c: Really destroying SIP dialog '2df1981b29daa0d97e601e2753d7b4ff@IP_ADR_PBX:5060' Method: INVITE
