Tippfehler
IPPF-Promi
- Mitglied seit
- 14 Sep 2004
- Beiträge
- 3,272
- Punkte für Reaktionen
- 29
- Punkte
- 48
Verstehe ich nicht ... mit der Asterisk Console kannst Du Dich z.B. viadoch schon beim stoppen des Asterisk fehlt mir der entsprechende Befehl...
asterisk -rvvvv
stop now
/var # ./cfg_asterisk16 usb_install
Connecting to c2a2b2.com (92.51.130.126:80)
cfg.common 100% |*******************************| 47688 --:--:-- ETA
total used free shared buffers
Mem: 30140 28848 1292 0 1880
Swap: 0 0 0
Total: 30140 28848 1292
INFORMATION: Installing asterisk16 (http://c2a2b2.com/fbox/0.9.29/26) to /var/media/ftp/uStor01/addons ...
freeramdisk 100% |*******************************| 13515 --:--:-- ETA
rd.ko 100% |*******************************| 9287 --:--:-- ETA
cfg.customize 100% |*******************************| 1386 --:--:-- ETA
asterisk14.sqf -> /var/ram0:
ram0 100% |*******************************| 1544k 00:00:00 ETA
mount: mounting /var/ram0 on /var/asterisk16 failed: Invalid argument
ERROR: failed to download or to mount asterisk16.sqf
/var #
/var # ./cfg_asterisk14 usb_install
Swap: 0 0 0
INFORMATION: Installing asterisk14 (http://c2a2b2.com/fbox/0.9.29/26) to /var/media/ftp/uStor01/addons ...
mount: mounting /var/ram0 on /var/asterisk14 failed: Invalid argument
ERROR: failed to download or to mount asterisk14.sqf
/var #
'/etc/asterisk/asterisk.conf' is not a regular file, ignoring
'/etc/asterisk/extconfig.conf' is not a regular file, ignoring
No entry for terminal type "xterm-color";
using dumb terminal settings.
'/etc/asterisk/logger.conf' is not a regular file, ignoring
Started Asterisk Event Logger
'/etc/asterisk/modules.conf' is not a regular file, ignoring
No 'modules.conf' found, no modules will be loaded.
'/etc/asterisk/dnsmgr.conf' is not a regular file, ignoring
'/etc/asterisk/http.conf' is not a regular file, ignoring
'/etc/asterisk/manager.conf' is not a regular file, ignoring
Unable to open AMI configuration manager.conf. Asterisk management interface (AMI) disabled.
'/etc/asterisk/cdr.conf' is not a regular file, ignoring
CDR simple logging enabled.
'/etc/asterisk/rtp.conf' is not a regular file, ignoring
'/etc/asterisk/udptl.conf' is not a regular file, ignoring
'/etc/asterisk/features.conf' is not a regular file, ignoring
Could not load features.conf
Unable to open Asterisk database '/var/lib/asterisk/astdb': No such file or directory
'/etc/asterisk/enum.conf' is not a regular file, ignoring
/var/media/ftp/uStor01/addons # ./cfg_asterisk14 -v usb_install
INFORMATION: cfg.common: current v2.356 >= required v2.356 -> OK
INFORMATION: asterisk14 Version: 1.4.22
INFORMATION: uClibc: 0.9.29
INFORMATION: Install-Script Version: 1.245
INFORMATION: FW specific modules will be downloaded from: http://c2a2b2.com/fbox/0.9.29
EXECUTING: _fct cfgctl@cfg_asterisk14:check:app_status
Mem: 30140 26992 3148 0 532
Swap: 0 0 0
Total: 30140 26992 3148
EXECUTING: _fct instdir@/var/media/ftp:addons/asterisk14:inst_dir:inst_fs_type
EXECUTING: _fct mkdr@/var:log:run:spool:log/asterisk:spool/asterisk
EXECUTING: _fct wgetx@http://c2a2b2.com/fbox/0.9.29/26:/var/media/ftp/uStor01/addons:freeramdisk:rd.ko
EXECUTING: _fct wgetx@http://c2a2b2.com/fbox:/var/media/ftp/uStor01/addons:cfg.customize
EXECUTING: _fct rdsk@start:/var/media/ftp/uStor01/addons
EXECUTING: _fct rdsk@new:ramdev
EXECUTING: _fct wgetx@http://c2a2b2.com/fbox/0.9.29/26:/var/ram0:asterisk14.sqf
EXECUTING: _fct [email protected]
/var # lsmod
Module Size Used by Tainted: P
rd 5536 1
tiap 452800 0
nfsd 116528 0
lockd 75024 1 nfsd
sunrpc 148320 2 nfsd,lockd
exportfs 4704 1 nfsd
fuse 46864 0
coda 35168 3
ext3 127840 1
jbd 58016 1 ext3
mbcache 8144 1 ext3
sch_sfq 5088 4
sch_llq 8896 1
sch_tbf 5888 1
sg 32768 0
sd_mod 15024 2
usb_storage 33296 1
scsi_mod 92560 3 sg,sd_mod,usb_storage
kdsldmod 841776 2
usbahcicore 26064 0
capi_codec 136960 0
isdn_fbox_fon4 894576 1 capi_codec
ubik2 85712 2 capi_codec,isdn_fbox_fon4
tiatm 112544 1 ubik2
Piglet 10656 0
pl2303 20240 1
ftdi_sio 30672 0
usbserial 28736 4 pl2303,ftdi_sio
usbcore 113328 6 usb_storage,usbahcicore,pl2303,ftdi_sio,usbserial
/var # insmod /var/media/ftp/uStora1/addons/rd.ko
insmod: cannot insert '/var/media/ftp/uStora1/addons/rd.ko': File exists
/var # lsmod
rd 5536 1
tiap 452800 0
nfsd 116528 0
lockd 75024 1 nfsd
fuse 46864 0
coda 35168 3
ext3 127840 1
jbd 58016 1 ext3
mbcache 8144 1 ext3
sch_sfq 5088 4
sch_llq 8896 1
sch_tbf 5888 1
sg 32768 0
sd_mod 15024 2
usb_storage 33296 1
kdsldmod 841776 2
usbahcicore 26064 0
capi_codec 136960 0
Piglet 10656 0
pl2303 20240 1
ftdi_sio 30672 0
/var # uname -r
2.6.13.1-ohio
Ja, es sieht danach aus, dass das rd.ko nicht zu Deinem Kernel passt ...Wie schon von anderer Seite beschrieben, scheint es auch bei mir ein Problem mit dem Mounten der RAM-Disk zu geben. Liegt das evtl. auch daran, dass ich "replace kernel" nutze?
