Asterisk GUI tool for OSX - German localisation
benjk
11 Aug 2004
With the kind help of Jan Czmok, we have completed the German localisation of the New Extension Assistant (Nebenstellenassitant).
Preview screenshots are on the Asterisk Wiki:
http://www.voip-info.org/wiki-Asterisk+New+Extension+Assistant+in+German
The localisations will be part of the upcoming 1.1 release (probably some time later this week or weekend). It's all open source and GPLed.
rgds
benjk
Well, it looks quite fine. How does it work? Is it extending the sip.conf, extensions.conf and iax.conf? Or is it using some kind of database?
Unfortunately I am missing a few things:
1) G726 iand G729 are also not to unimportant over here. There are still many Hardware-Clients that do not support LIBC or GSM.
2) There are a few special Options: e.g. canreinvite, that are important if you try to use the Clients behind NAT. Is it possible to edit the settings manually later, to append the settings?
