wrrdlbrrmpft
- Mitglied seit
- 17 Jul 2004
- Beiträge
- 263
- Punkte für Reaktionen
- 0
- Punkte
- 0
[macro-ch]
exten => s,1,Playtones(congestion)
exten => s,2,Wait(5)
exten => s,3,Hangup
[macro-invalidline]
exten => s,1,Answer
exten => s,2,Wait(0.5)
exten => s,3,Playback(privacy-incorrect)
exten => s,4,Setvar(PRI_CAUSE=21)
exten => s,5,Hangup
[dialextern]
exten => s,1,StopPlaytones
exten => s,2,Playtones(dial)
exten => s,3,DigitTimeout(0)
exten => s,4,ResponseTimeout(10)
exten => *,1,SetVar(DIALED=${DIALED}${EXTEN})
exten => *,2,WaitExten(2)
exten => _X,1,SetVar(DIALED=${DIALED}${EXTEN})
exten => _X,2,GotoIf(${LEN(${DIALED})} > 1?3:4)
exten => _X,3,StopPlaytones
exten => _X,4,ResponseTimeout(2)
exten => _X,5,WaitExten(2)
exten => t,1,GotoIf(${LEN({${DIALED})} > 1?10:2)
exten => t,2,Macro(ch)
exten => t,10,Goto(isdn2out,${DIALED},1)
exten => i,1,Macro(invalidline)
[dialintern]
exten => s,2,SetCIDNum(${MYLIVINGID})
exten => s,3,WaitExten(0.2)
exten => _X,2,Goto(local,${DIALED},1)
exten => t,1,Macro(ch)
exten => i,1,Macro(ch)
[dialtone]
exten => _X.,1,Wait(0.0)
exten => _X.,2,Macro(user${EXTEN})
exten => _X.,3,Playtones(internal)
exten => _X.,4,DigitTimeout(0)
exten => _X.,5,ResponseTimeout(10)
exten => _X.,6,WaitExten(2)
exten => 0,1,SetVar(DIALED=${EXTEN})
exten => 0,2,Goto(dialextern,s,1)
exten => _Z,1,SetVar(DIALED=${EXTEN})
exten => _Z,2,Goto(dialintern,s,1)
[macro-ch]
exten => s,3,Hangup
[macro-invalidline]
exten => s,1,Answer
exten => s,5,Hangup
[dialextern]
[dialintern]
[dialtone]
[nl]
alias = de
description = Netherlands
ringcadance = 1000,4000
; Most of these 425's can also be 450's
dial = 425
busy = 425/500,0/500
ring = 425/1000,0/4000
congestion = 425/250,0/250
; XXX I'm making up the call wait tone XXX
callwaiting = 440/300,0/10000
; XXX Assuming this is "Special Dial Tone" XXX
dialrecall = 425/500,0/50
; XXX I'm making up the record tone XXX
record = 1400/500,0/15000
info = 950/330,1400/330,1800/330,0/1000
internal = 440/200,0/300,440/200,0/300,440/200,0/800
[general]
static=yes
writeprotect=no
[globals]
[default]
include => incoming
exten => s,1,SetLanguage(de)
exten => s,2,Playtones(internal)
exten => s,4,WaitExten(2)
exten => 0,1,Goto(outgoing,s,1)
exten => _Z,1,Goto(internal,s,1)
[internal]
exten => s,2,DigitTimeout(2)
exten => s,2,WaitExten(2)
exten => _X.,1,SetVar(DIALED=${DIALED}${EXTEN})
exten => _X.,2,Goto(${DIALED},1)
exten => 10,1,Dial(SIP/10,60,tT)
exten => 10,2,Voicemail(su10)
exten => 10,3,Hangup
exten => 10,102,Busy
exten => 11,1,Dial(SIP/11,60,tT)
exten => 11,2,Congestion
exten => 11,102,Busy
exten => 12,1,Dial(Zap/1/12,60,tT)
exten => 12,2,Congestion
exten => 12,102,Busy
exten => 20,1,Dial(SIP/10&SIP/11&Zap/1/12,60,tT)
exten => 20,2,Congestion
exten => 20,102,Busy
exten => 8500,1,SetLanguage(de)
exten => 8500,2,VoicemailMain2(s${CALLERIDNUM})
exten => 8500,3,Hangup
[incoming]
exten => SIP-ID,1,Dial(SIP/10&SIP/11&Zap/1/12,60)
exten => SIP-ID,2,Congestion
exten => SIP-ID,102,Busy
exten => Voice-MSN,1,Dial(SIP/10&SIP/11&Zap/1/12,60)
exten => Voice-MSN,2,Congestion
exten => Fax-MSN,1,Goto(fax,s,1)
[outgoing]
include => notallowed
include => freecall
include => emergency
exten => s,3,DigitTimeout(4)
exten => _X.,1,Dial(SIP/${EXTEN}@sipgate,60)
exten => _X.,2,Congestion
exten => _X.,102,Busy
[notallowed]
exten => _019X.,1,Macro(notallowed) ; 019x
exten => _0900X.,1,Macro(notallowed) ; 0900
exten => _0137X.,1,Macro(notallowed) ; 0137
exten => _018X.,1,Macro(notallowed) ; 018x
exten => _012X.,1,Macro(notallowed) ; 012x
exten => _118X.,1,Macro(notallowed) ; 118x
exten => _0087X.,1,Macro(notallowed) ; 0087 IMSAT
exten => _0088X.,1,Macro(notallowed) ; 0088 EMSAT
[freecall]
exten => _0800X.,1,Macro(ISDN,${EXTEN})
exten => _00800X.,1,Macro(ISDN,${EXTEN})
[emergency]
exten => _110,1,Macro(ISDN,${EXTEN})
exten => _112,1,Macro(ISDN,${EXTEN})
[macro-notallowed]
exten => s,1,Answer
exten => s,3,SetLanguage(de)
exten => s,4,Playback(ss-noservice)
exten => s,5,Hangup
[macro-ISDN]
exten => s,1,Dial(CAPI/Voice-MSN:${ARG1},60)
exten => s,2,Congestion
exten => s,102,Busy
[fax]
exten => s,1,SetVar(FAXFILE=/var/spool/asterisk/fax/${UNIQUEID}.tif)
exten => s,2,SetVar([email protected])
exten => s,3,rxfax(${FAXFILE})
exten => h,1,system(/usr/local/sbin/mailfax ${FAXFILE} ${EMAILADDR} ${CALLERIDNUM})
[dialextern]
exten => t,1,StopPlaytones
exten => t,2,Playtones(congestion)
exten => t,3,Congestion
exten => t,4,Hangup
exten => i,1,StopPlaytones
exten => i,2,Playtones(congestion)
exten => i,3,Congestion
exten => i,4,Hangup
exten => _X,1,StopPlaytones
exten => _X,2,DigitTimeout(3)
exten => _X,3,SetVar(DIALED=${EXTEN})
exten => _X,4,WaitExten(2)
exten => _X.,2,Macro(tsblcr,${DIALED},/etc/asterisk/lcr/tsblcr.routing,${ZAP_DEF_OUT_CIDNum},${ZAP_DEF_OUT_CIDName},Zap$
allesOK schrieb:Code:[dialtone] exten => _X.,1,Wait(0.0) exten => _X.,2,Macro(user${EXTEN}) exten => _X.,3,Playtones(internal) exten => _X.,4,DigitTimeout(0) exten => _X.,5,ResponseTimeout(10) exten => _X.,6,WaitExten(2) exten => 0,1,SetVar(DIALED=${EXTEN}) exten => 0,2,Goto(dialextern,s,1) exten => _Z,1,SetVar(DIALED=${EXTEN}) exten => _Z,2,Goto(dialintern,s,1) exten => t,1,Macro(ch) exten => i,1,Macro(ch)
[general]
priorityjumping=yes
static=yes
writeprotect=no
autofallthrough=no
*CLI>
ich hebe ab:
-- Executing PlayTones("Zap/2-1", "internal") in new stack
-- Executing Wait("Zap/2-1", "0.1") in new stack
-- Accepting voice call from 'yxxxyxx' to 's' on channel 0/2, span 1
-- Executing Set("Zap/2-1", "TIMEOUT(digit)=2") in new stack
-- Digit timeout set to 2
- snip - Uservariablen werden hier gesetzt
-- Goto (dialtone,s,1)
-- Executing Set("Zap/2-1", "TIMEOUT(digit)=0") in new stack
-- Digit timeout set to 0
-- Executing Set("Zap/2-1", "TIMEOUT(response)=3") in new stack
-- Response timeout set to 3
-- Executing WaitExten("Zap/2-1", "1.5") in new stack
ich drücke 0 um Freizeichen zu erhalten:
== Auto fallthrough, channel 'Zap/2-1' status is 'UNKNOWN'
-- Hungup 'Zap/2-1'
