Anfängerfragen: Asterisk unter SuSE Linux 9.3 Prof.
M
markusd112
Guest
ich habe einen Rechner mit 2 x HFC-S-ISDN-Karten ausgestattet und SuSE Linux 9.3 Prof. inkl. der dort beiliegenden ASTERISK-Pakete installiert.
Die ISDN-Karten wurden einwandfrei erkannt und mit YaST konfiguriert.
Ich habe gemäß dem neuen Einführungs-Artikel auf Pro-Linux.de die Dateien extensions.conf und zapata.conf unter etc/asterisk angelegt (die Original-Konfig-Dateien habe ich in ein anderes Verzeichnis verschoben.
Beim Starten von Asterisk kommt nun aber folgende Fehlermeldung:
  == Parsing '/etc/asterisk/asterisk.conf': Not found (No such file or directory)
  == Parsing '/etc/asterisk/extconfig.conf': Not found (No such file or directory)
Asterisk 1.0.6-BRIstuffed-0.2.0-RC7k, Copyright (C) 1999-2004 Digium.
Written by Mark Spencer <[email protected]>
  == Parsing '/etc/asterisk/logger.conf': Not found (No such file or directory)
Asterisk Event Logger Started /var/log/asterisk/event_log
  == Manager registered action Ping
  == Manager registered action Events
  == Manager registered action Logoff
  == Manager registered action Hangup
  == Manager registered action Status
  == Manager registered action Setvar
  == Manager registered action Getvar
  == Manager registered action Redirect
  == Manager registered action Originate
  == Manager registered action Command
  == Manager registered action ExtensionState
  == Manager registered action AbsoluteTimeout
  == Manager registered action MailboxStatus
  == Manager registered action MailboxCount
  == Manager registered action DBget
  == Manager registered action DBput
  == Manager registered action DBdel
  == Manager registered action ListCommands
  == Parsing '/etc/asterisk/manager.conf': Not found (No such file or directory)
Unable to open management configuration manager.conf.  Call management disabled.
  == Parsing '/etc/asterisk/rtp.conf': Not found (No such file or directory)
  == RTP Allocating from port range 5000 -> 31000
Asterisk PBX Core Initializing
Registering builtin applications:
 [AbsoluteTimeout]
  == Registered application 'AbsoluteTimeout'
 [Answer]
  == Registered application 'Answer'
 [BackGround]
  == Registered application 'BackGround'
 [Busy]
  == Registered application 'Busy'
 [Congestion]
  == Registered application 'Congestion'
 [DigitTimeout]
  == Registered application 'DigitTimeout'
 [Goto]
  == Registered application 'Goto'
 [GotoIf]
  == Registered application 'GotoIf'
 [GotoIfTime]
  == Registered application 'GotoIfTime'
 [Hangup]
  == Registered application 'Hangup'
 [NoOp]
  == Registered application 'NoOp'
 [Prefix]
  == Registered application 'Prefix'
 [Progress]
  == Registered application 'Progress'
 [ResetCDR]
  == Registered application 'ResetCDR'
 [ResponseTimeout]
  == Registered application 'ResponseTimeout'
 [Ringing]
  == Registered application 'Ringing'
 [SayNumber]
  == Registered application 'SayNumber'
 [SayDigits]
  == Registered application 'SayDigits'
 [SayAlpha]
  == Registered application 'SayAlpha'
 [SayPhonetic]
  == Registered application 'SayPhonetic'
 [SetAccount]
  == Registered application 'SetAccount'
 [SetAMAFlags]
  == Registered application 'SetAMAFlags'
 [SetGlobalVar]
  == Registered application 'SetGlobalVar'
 [SetLanguage]
  == Registered application 'SetLanguage'
 [SetVar]
  == Registered application 'SetVar'
 [StripMSD]
  == Registered application 'StripMSD'
 [Suffix]
  == Registered application 'Suffix'
 [Wait]
  == Registered application 'Wait'
 [WaitExten]
  == Registered application 'WaitExten'
Asterisk Dynamic Loader Starting:
  == Parsing '/etc/asterisk/modules.conf': Not found (No such file or directory)
 [res_indications.so] => (Indications Configuration)
  == Parsing '/etc/asterisk/indications.conf': Not found (No such file or directory)
  == Registered application 'Playtones'
  == Registered application 'StopPlaytones'
 [res_features.so] => (Call Parking Resource)
  == Parsing '/etc/asterisk/features.conf': Not found (No such file or directory)
  == Parsing '/etc/asterisk/parking.conf': Not found (No such file or directory)
    -- Registered extension context 'parkedcalls'
    -- Added extension '700' priority 1 to parkedcalls
  == Registered application 'ParkedCall'
  == Registered application 'Park'
  == Manager registered action ParkedCalls
  == Registered application 'HoldedCall'
  == Registered application 'AutoanswerLogin'
  == Registered application 'Autoanswer'
 [res_agi.so] => (Asterisk Gateway Interface (AGI))
  == Registered application 'DeadAGI'
  == Registered application 'EAGI'
  == Registered application 'AGI'
 [res_crypto.so] => (Cryptographic Digital Signatures)
    -- Loaded PUBLIC key 'iaxtel'
    -- Loaded PUBLIC key 'freeworlddialup'
 [res_adsi.so] => (ADSI Resource)
  == Parsing '/etc/asterisk/adsi.conf': Not found (No such file or directory)
 [res_odbc.so] => (ODBC Resource)
  == Parsing '/etc/asterisk/res_odbc.conf': Not found (No such file or directory)
res_odbc loaded.
 [res_config_odbc.so] => (ODBC Configuration)
Registered Config Engine odbc
res_config_odbc loaded.
 [res_monitor.so] => (Call Monitoring Resource)
  == Registered application 'Monitor'
  == Registered application 'StopMonitor'
  == Registered application 'ChangeMonitor'
  == Manager registered action Monitor
  == Manager registered action StopMonitor
  == Manager registered action ChangeMonitor
 [res_musiconhold.so] => (Music On Hold Resource)
  == Parsing '/etc/asterisk/musiconhold.conf': Not found (No such file or directory)
  == Registered application 'MusicOnHold'
  == Registered application 'WaitMusicOnHold'
  == Registered application 'SetMusicOnHold'
 [app_sms.so] => (SMS/PSTN handler)
  == Registered application 'SMS'
 [app_hasnewvoicemail.so] => (Indicator for whether a voice mailbox has messages in a given folder.
  == Registered application 'HasVoicemail'
  == Registered application 'HasNewVoicemail'
 [format_wav_gsm.so] => (Microsoft WAV format (Proprietary GSM))
  == Registered file format wav49, extension(s) WAV|wav49
 [app_url.so] => (Send URL Applications)
  == Registered application 'SendURL'
 [chan_modem_i4l.so]/usr/lib/asterisk/modules/chan_modem_i4l.so: undefined symbol: ast_unregister_modem_driver
Loading module chan_modem_i4l.so failed!
Ich komme irgendwie nicht weiter und durchblicke auch noch nicht die verschiedenen Varianten, wie Asterisk auf die ISDN-Karten zugreift (mit CAPI? mit HFC-S-Treibern?!) und wo der Unterschied ist.
Auch die Versuche, das Paket bri-stuff von Junghanns.net zu installieren scheitern mit diversen Fehlermeldungen beim Compilieren.
Kann mir jemand helfen? Hat jemand Asterisk unter Suse 9.3 zum Laufen bekommen und kann mir eine kleine "Schritt-für-Schritt-Anleitung" geben?
Herzlichen Dank vorab und Gruß
Markus
P.S.: Hier die Konfig-Files:
zapata.conf:
[channels]
context = default
switchtype = euroisdn
signalling = bri_net_ptmp
pridialplan=local
echocancel=yes
immediate=yes
group = 1
channel=> 1-2
signalling = bri_cpe_ptmp
group = 2
channel => 4-5
und extensions.conf:
[default]
exten => 123456,1,Dial(Zap/g1/$(EXTEN))
exten => _X.,1,Dial(Zap/g2/$(EXTEN))
1. solltest Du * nicht alle config-Dateien klauen, das ist keine gute Idee
2. Die Karten in yast einzurichten ebensowenig
3. Ja, Du brauchst bristuff von junghanns.net, das schliesst aber die Verwendung der SuSE-Asterisk-Pakete aus, daher deinstallieren.
4. Das ist Asterisk mit HFC, ergo verschiebe ich das gleich mal dahin
5. Wenn Du in Asterisk mit HFC hier im Forum reinschaust, wirst Du dort auch ein Howto zu Bristuff + SuSE (9.2, aber das macht jetzt glaube ich keinen Unterschied) finden ;)
Gruss,
rajo
Hallo!
Tausend Dank für die schnelle Hilfe und den wertvollen Tipp zum Howto. Damit hat es geklappt!!!! Ich habe schon mehrere schlaflose Nächte hinter mir, aber jetzt kann ich mich endlich an das eigentliche Konfigurieren von Asterisk wagen...
Schöne Grüße
Markus
amandapage09
