**** FRITZ!Box Fon WLAN 7570 vDSL CONFIGURATION EXPORT
Password=xxx
FirmwareVersion=75.04.91
CONFIG_INSTALL_TYPE=ur8_16MB_xilinx_4eth_2ab_isdn_nt_te_pots_wlan_mimo_usb_host_dect_multiannex_13589
OEM=avme
Country=049
Language=en
**** CFGFILE:ar7.cfg
* /var/flash/ar7.cfg
* Sat Apr 13 01:01:36 2013
ar7cfg {
mode = dsldmode_router;
active_provider = "alice";
igddenabled = yes;
igdd_control_enabled = no;
wan_bridge_with_dhcpc = yes;
wan_bridge_gateway = 0.0.0.0;
dhcpc_use_static_dns = no;
ethmode = ethmode_bridge;
tcom_targetarch = no;
vdsl_resalearch = no;
aontv_arch = no;
hsi_use_wan_vlan = yes;
hsi_vlancfg {
vlanencap = vlanencap_none;
vlanid = 0;
vlanprio = 0;
mtu_cutback_mode = mtumode_auto;
mtu_cutback = 1500;
StatisticStartOfMonth = 1;
enable_mac_override = yes;
macdsl_override = 00:00:00:00:00:00;
ipv6mode = ipv6_off;
serialcfg {
mode = serialmode_off;
number = "*99#";
provider = "internet.t-mobile";
username = "xxx";
passwd = "xxx";
connect_chatscript = "ABORT BUSY ABORT 'NO CARRIER'",
"ABORT VOICE ABORT 'NO DAILTONE'",
"ABORT 'NO ANSWER' ABORT DELAYED",
"ABORT ERROR", "TIMEOUT 20",
"'' 'AT+cgdcont=1,\\"IP\\",\\"${provider}\\"'",
"OK 'ATDT${number}'", "CONNECT",
"WAIT 2";
stay_always_online = no;
inactivity_timeout = 1m;
backup {
enabled = no;
downtime = 3m;
reverttime = 30m;
ethinterfaces {
name = "eth0";
dhcp = no;
ipaddr = 192.168.178.1;
netmask = 255.255.255.0;
dstipaddr = 0.0.0.0;
dhcpenabled = yes;
dhcpstart = 0.0.0.0;
dhcpend = 0.0.0.0;
no_dnsd_static = no;
name = "eth0:0";
dhcp = no;
ipaddr = 169.254.1.1;
netmask = 255.255.0.0;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "wlan";
dhcp = no;
ipaddr = 192.168.182.1;
interfaces = "ath0", "wdsup1", "wdsdw1", "wdsdw2", "wdsdw3",
"wdsdw4";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
brinterfaces {
name = "lan";
dhcp = no;
interfaces = "eth0", "ath0", "wdsup1", "wdsdw1", "wdsdw2",
"wdsdw3", "wdsdw4";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "lan:0";
dhcp = no;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "guest";
dhcp = no;
ipaddr = 192.168.179.1;
interfaces = "guest0", "guest1", "guest2", "guest3",
"guest4";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
no_dnsd_static = yes;
dslinterface {
name = "dsl";
dhcp = no;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface_metric = 2;
ipbridge {
enabled = no;
pppoefw {
interfaces = "lan", "usbrndis", "eth0", "wlan";
nofirewall = yes;
dnsfilter_for_active_directory = yes;
hostuniq_filter = "";
dpconfig {
security = dpsec_host;
filter_teredo = yes;
filter_netbios = yes;
lowinput {
policy = "reject";
accesslist =
"permit ip any any connection outgoing-related",
"permit ip any any connection incoming-related",
"permit icmp any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
"reject ip any 242.0.0.0 255.0.0.0",
"deny ip any host 255.255.255.255",
"reject ip any 169.254.0.0 255.255.0.0";
budget {
Enabled = no;
Period = 2;
VolumeLow = 0;
VolumeHigh = 0;
ConnectionTime = 0;
WarnOnly = yes;
vccs {
VPI = 1;
VCI = 32;
traffic_class = atm_traffic_class_UBR;
pcr = 0;
scr = 0;
priority = 0;
dsl_encap = dslencap_pppoe;
ipbridgeing = no;
ipbridgeing_igmp = no;
pppoeforwarding = no;
connections = "internet", "voip";
VPI = 1;
VCI = 34;
pcr = 0;
scr = 0;
priority = 1;
dsl_encap = dslencap_ether;
ipbridgeing = no;
connections = "mstv";
mcupstream = "internet", "mstv";
voip_forwardrules = "udp 0.0.0.0:5060 0.0.0.0:5060",
"tcp 0.0.0.0:5060 0.0.0.0:5060",
"udp 0.0.0.0:7078+32 0.0.0.0:7078";
tr069_forwardrules = "tcp 0.0.0.0:8089 0.0.0.0:8089";
internet_in_nat_rules_enabled = yes;
internet_out_nat_rules_enabled = yes;
dslifaces {
enabled = yes;
name = "internet";
dsl_encap = dslencap_inherit;
dslinterfacename = "dsl";
no_masquerading = no;
no_firewall = no;
pppoevlanauto = no;
pppoevlanauto_startwithvlan = no;
ppptarget = "internet";
etherencapcfg {
use_dhcp = yes;
use_dhcp_if_not_encap_ether = no;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
is_mcupstream = yes;
stay_always_online = yes;
disable_ondemand = no;
only_route_when_connected = no;
redial_delay_after_auth_failure = 1m;
redial_limit = 3;
redial_after_limit_reached = 10m;
redial_after_limit_reached_variance = 5m;
redial_delay_after_low_error = 10s;
redial_delay_after_ppp_timeout = 10s;
redial_delay_after_ppp_error = 0w;
routes_only_for_local = no;
tcclassroutes = "sip_internet", "rtp_internet";
disable_staticroutes_on_dhcproutes = no;
ripv2receiver_enabled = no;
set_replicate_dhcpoptions_in_parameter_request_list = no;
unset_ignored_dhcpoptions_in_parameter_request_list = yes;
dsldpconfig {
security = dpsec_firewall;
lowinput {
policy = "permit";
accesslist =
"deny ip any 242.0.0.0 255.0.0.0",
"deny ip any host 255.255.255.255";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
enabled = yes;
name = "voip";
no_firewall = no;
pppoevlanauto = no;
ppptarget = "voip";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
is_mcupstream = no;
redial_limit = 3;
tcclassroutes = "sipdns", "sip", "rtp";
dsldpconfig {
lowinput {
policy = "permit";
accesslist = "permit udp any any",
"permit icmp any any",
"reject ip any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
enabled = yes;
name = "mstv";
no_firewall = no;
pppoevlanauto = no;
ppptarget = "mstv";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
redial_limit = 3;
tcclassroutes = "iptv";
dsldpconfig {
lowinput {
policy = "permit";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
targets {
type = pppcfg_target_internet;
name = "internet";
only_crypt_auth = no;
local {
username = "xxx";
passwd = "xxx";
remoteauth = pppcfg_authtype_chap;
remoteauth_only_on_incoming = yes;
remote {
inactivity_timeout = 5m;
bUseChargeInterval = no;
nChargeInterval = 1m;
lcpecho_disconnect_mode = lcpecho_auto;
logicaldisconnect_with_physical = yes;
disconnect_timeout = 0w;
finaldisconnectcall = no;
ipnetbiosspoofing = no;
dnsfilter_for_active_directory = no;
no_outgoing_calls = no;
coso = pppcfg_coso_caller;
callback_delay = 1s;
icbmode = pppcfg_icbmode_none;
ocbmode = pppcfg_ocbmode_none;
mscbprefered = no;
multilink {
extra_static_channels = 0;
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
header_compression = yes;
data_compression = pppcfg_datacomp_auto;
stac_reset_with_history_number = no;
encryption = pppcfg_crypt_none;
inactivity_prevention_interval = 0w;
new_ipaddr_on_connect = no;
my_ipaddr = 0.0.0.0;
his_ipaddr = 0.0.0.0;
overwrite_dns1 = 0.0.0.0;
overwrite_dns2 = 0.0.0.0;
bVolumeRoundUp = no;
VolumeRoundUpBytes = 0;
bProviderDisconnectPrevention = no;
ProviderDisconnectPreventionInterval = 1d;
ProviderDisconnectPreventionHour = 3;
bProviderDisconnectPreventionHourSet = yes;
passiv_on_outgoing = no;
mode6 = mode6_off;
name = "voip";
local {
username = "";
passwd = "";
remote {
inactivity_timeout = 0w;
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
mode6 = mode6_off;
name = "mstv";
local {
username = "";
passwd = "";
remote {
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
ProviderDisconnectPreventionHour = 5;
mode6 = mode6_off;
dslglobalconfig {
autodetect = no;
autodetectparams {
nround = 2;
timeout = 3s;
npacket = 1;
speed_in_netto = 1024;
speed_out_netto = 128;
manual_speed = no;
connect_delay_when_synced = 3s;
sync_lost_delay = 0w;
default_tcom_vlan = 7;
templates {
VPI = 1;
VCI = 32;
retries = 7;
VPI = 8;
VCI = 35;
retries = 0;
VPI = 8;
VCI = 35;
retries = 0;
VPI = 8;
VCI = 48;
retries = 0;
encap = dslencap_pppoa;
VPI = 8;
VCI = 48;
retries = 0;
VPI = 8;
VCI = 48;
retries = 0;
encap = dslencap_pppoa_llc;
VPI = 8;
VCI = 67;
retries = 0;
VPI = 8;
VCI = 67;
retries = 0;
VPI = 8;
VCI = 64;
retries = 0;
VPI = 8;
VCI = 36;
retries = 0;
VPI = 0;
VCI = 35;
retries = 0;
VPI = 0;
VCI = 35;
retries = 0;
VPI = 0;
VCI = 35;
retries = 0;
VPI = 9;
VCI = 35;
retries = 0;
VPI = 1;
VCI = 32;
retries = 0;
VPI = 1;
VCI = 32;
retries = 0;
VPI = 0;
VCI = 32;
retries = 0;
VPI = 0;
VCI = 32;
retries = 0;
VPI = 0;
VCI = 32;
retries = 0;
VPI = 0;
VCI = 34;
retries = 0;
VPI = 0;
VCI = 34;
retries = 0;
VPI = 0;
VCI = 34;
retries = 0;
VPI = 0;
VCI = 33;
retries = 0;
VPI = 8;
VCI = 32;
retries = 0;
VPI = 8;
VCI = 32;
retries = 0;
VPI = 8;
VCI = 32;
retries = 0;
VPI = 0;
VCI = 38;
retries = 0;
VPI = 0;
VCI = 38;
retries = 0;
VPI = 8;
VCI = 35;
retries = 0;
VPI = 8;
VCI = 35;
retries = 0;
VPI = 0;
VCI = 81;
retries = 0;
VPI = 0;
VCI = 81;
retries = 0;
VPI = 0;
VCI = 81;
retries = 0;
VPI = 8;
VCI = 81;
retries = 0;
VPI = 8;
VCI = 81;
retries = 0;
VPI = 8;
VCI = 81;
retries = 0;
VPI = 0;
VCI = 100;
retries = 0;
VPI = 0;
VCI = 100;
retries = 0;
VPI = 0;
VCI = 100;
retries = 0;
VPI = 1;
VCI = 50;
retries = 0;
VPI = 1;
VCI = 50;
retries = 0;
VPI = 0;
VCI = 100;
retries = 0;
VPI = 0;
VCI = 33;
retries = 0;
VPI = 0;
VCI = 32;
retries = 0;
VPI = 14;
VCI = 24;
retries = 0;
MaxDownstreamRate = 0;
MaxUpstreamRate = 0;
RFI = 0;
DownstreamBlackoutBandStart = 0;
DownstreamBlackoutBandEnd = 0;
ControlBitfield = 4;
DownstreamMarginOffset = 40;
DownstreamPcbOffset = 0;
UpstreamPcbOffset = 0;
UsNoiseBits = 0;
RFI_mode = 0;
DsINP = 0;
DiagnosticEnabled = no;
Annex = "B";
DSLMode = 0;
IsDSLModeSet = no;
VinaxConfigBitField = 3;
accesslist_version = 3;
ar7cfg_version = 2;
tr069discover_active = yes;
tr069discover_without_dhcpoption = no;
tr069discover_vlancfg {
vlanid = 0;
vlanprio = 0;
use_fixed_wlan_guest_ip = no;
servercfg {
hostname = "(none)";
dns1 = 192.168.180.1;
dns2 = 192.168.180.2;
websrv {
port = "80";
read_timeout = 15m;
request_timeout = 30s;
keepalive_timeout = 5m;
nokeepalive = "*";
errordir = "/usr/www/html/errors";
webdir = "/usr/www";
cgidir = "cgi-bin";
indexfn = "index.var", "index.htm", "index.html";
users_only_for_https = no;
ipv6 {
ulamode = ulamode_dynamic;
use_default_ula = yes;
ula = fd00::;
use_fixed_mtu = no;
fixed_mtu = 1280;
radv {
MinRtrAdvInterval = 450;
MaxRtrAdvInterval = 600;
AdvDefaultLifetime = 1800;
PreferedLifeTime = 3600;
ValidLifeTime = 7200;
AdvDNS = yes;
ip6_6to4static_cfg {
popaddr = 0.0.0.0;
local = ::;
remote = ::;
prefix = ::;
prefixlen = 0;
ip6_6rd_cfg {
popaddr = 192.88.99.1;
prefix = 2002::;
prefixlen = 16;
sixxs {
ticserver = "tic.sixxs.net";
dhcpserver {
saveinterval = 1h;
generic {
default_lease_time = 10d;
max_lease_time = 13d;
dhcpclient {
metric = 9;
dnsserver {
cache_maxKB = 16;
negative_ttl = 5m;
ddns {
accounts {
enabled = no;
domain = "";
iface = 0;
username = "";
passwd = "";
ddnsprovider = "dyndns.org";
types {
type = "dyndns";
url = "/nic/update?system=dyndns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-custom";
url = "/nic/update?system=custom&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-statdns";
url = "/nic/update?system=statdns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "noip";
url = "/ducupdate.php?update=<b64>username=<username>&pass=<pass>&h[]=<domain>&ip=<ipaddr></b64>";
type = "2mydns";
url = "/dyn.asp?username=<username>&password=<pass>&hostname=<domain>&myip=<ipaddr>";
type = "dns4biz";
url = "/nic/update?hostname=<domain>&myip=<ipaddr>";
type = "selfhost";
url = "/nic/update?myip=<ipaddr>&host=<domain>&textmodi=1&http_status=1";
type = "strato";
url = "/nic/update?hostname=<domain>";
type = "TZO";
url = "/webclient/tzoperl.html?TZOName=<domain>&Email=<username>&TZOKey=<pass>&IPAddress=<ipaddr>&system=tzodns&info=1";
type = "namemaster";
url = "/dyn.php?username=<username>&password=<pass>&hostname=<domain>";
type = "userdefined";
url = "";
provider {
name = "dyndns.org";
type = "dyndns";
livedelay = 0w;
touchtime = 30d;
server = "members.dyndns.org";
infourl = "http://www.dyndns.org/";
name = "dyndns.org-custom";
livedelay = 0w;
touchtime = 30d;
name = "dyndns.org-statdns";
livedelay = 0w;
touchtime = 30d;
name = "No-IP.com";
type = "noip";
livedelay = 4m;
touchtime = 0w;
server = "dynupdate.no-ip.com:8245";
infourl = "http://www.no-ip.com/";
name = "2myDNS";
type = "2mydns";
livedelay = 0w;
touchtime = 0w;
server = "dyn.2mydns.com";
infourl = "http://www.2mydns.com/";
name = "DNS4BIZ.DE Premium";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.net";
infourl = "http://www.dns4biz.com/services_avm.php3";
name = "DNS4BIZ.DE Business";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.biz";
name = "selfhost.de";
type = "selfhost";
livedelay = 0w;
touchtime = 0w;
server = "carol.selfhost.de";
infourl = "http://www.selfhost.de";
name = "STRATO AG";
type = "strato";
livedelay = 4m;
touchtime = 0w;
server = "dyndns.strato.com";
infourl = "http://www.strato.de/webhosting/index.html";
name = "TZO.com";
type = "TZO";
livedelay = 0w;
touchtime = 0w;
server = "rh.tzo.com";
infourl = "http://www.tzo.com";
name = "namemaster.de";
livedelay = 0w;
touchtime = 0w;
server = "dynup.de";
infourl = "http://www.namemaster.de";
name = "User-defined";
livedelay = 4m;
touchtime = 0w;
server = "";
infourl = "http://";
webui {
username = "";
password = "xxx";
expertmode = yes;
wizard_completed = no;
event_filter = 3;
read_access_without_login = no;
app_enabled = no;
fminiframework {
enabled = no;
converted = yes;
capiovertcp {
enabled = no;
maxctrl = 1;
port = 5031;
emailnotify {
enabled = no;
interval = daily;
From = "";
To = "";
SMTPServer = "";
accountname = "";
passwd = "";
show_eventlist = yes;
show_voipstat = yes;
show_kidsstat = yes;
show_onlinecntstat = yes;
show_fonstat = yes;
starttls = yes;
dsl_pushmail_mode = 0;
enable_incident_supportdata = no;
night_time_control {
enabled = no;
time_on = "";
time_off = "";
ring_blocked = no;
ntpclient {
server_list = "ntp.netcologne.de";
chrony_enabled = yes;
led {
infoled_reason = 0;
timezone_manual {
enabled = no;
offset = 0;
dst_enabled = no;
TZ_string = "";
name = "";
mrouter {
igmp_version_for_upstream = 3;
igmp_version_for_other = 3;
igmp_prio = 48;
rip {
cpu_schedule {
dsl_token = 5000;
lan_token = 20000;
TR_064 {
enabled = yes;
username = "dslf-config";
persistent_data = "";
only_https = no;
landevices {
prios {
profiles {
name = "profile_http";
rules = "TCP 80 0 0 0";
name = "profile_ftp";
rules = "TCP 20 21 0 0";
name = "profile_torrent";
rules = "TCP 0 0 6881 6999";
name = "profile_rdp";
rules = "TCP 3389 0 0 0";
name = "profile_ssh";
rules = "TCP 0 0 22 0";
name = "profile_telnet";
rules = "TCP 0 0 23 0";
name = "IPTV";
rules = "UDP 1234 0 0 0";
