- Mitglied seit
- 20 Apr 2016
- Beiträge
- 1,169
- Punkte für Reaktionen
- 233
- Punkte
- 63
Ohne Erweiterung des Patch
mit Erweiterung des Patch
--- config/ui/patches.in 2023-11-04 13:42:27.844150219 +0100
+++ config/ui/patches.in 2023-11-08 08:44:00.807611000 +0100
@@ -1291,7 +1291,21 @@
default n
help
ipphone_from_outside does not trigger the message.
+config FREETZ_PATCH_SECURE_nau
+ bool "Caused by noAutoupdate_disabled"
+ depends on FREETZ_PATCH_SECURE && FREETZ_AVM_VERSION_07_8X_MIN
+ default y
+ help
+ noAutoupdate_disabled does not trigger the message.
+config FREETZ_PATCH_SECURE_nus
+ bool "Caused by noUpdateSearch_disabled"
+ default y
+ help
+ noUpdateSearch_disabled does not trigger the message.
config FREETZ_MODIFY_DSL_WARNING
bool "Patch DSL modified message"
depends on FREETZ_TYPE_DSL && FREETZ_AVM_VERSION_06_5X_MIN && !FREETZ_REMOVE_DSLD && !FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_PRIME
--- patches/scripts/194-patch_webmenu_secure.sh 2023-10-19 05:18:48.691298000 +0200
+++ patches/scripts/194-patch_webmenu_secure.sh 2023-11-08 08:16:46.451506000 +0100
@@ -8,6 +8,8 @@
[ ! -e ${FILESYSTEM_MOD_DIR}${file} ] && continue
[ "$FREETZ_PATCH_SECURE_2fa" == "y" ] && modsed 's/data[.]fritzos[.]twofactor_disabled/false/g' ${FILESYSTEM_MOD_DIR}${file}
[ "$FREETZ_PATCH_SECURE_sip" == "y" ] && modsed 's/data[.]fritzos[.]ipphone_from_outside/false/g' ${FILESYSTEM_MOD_DIR}${file}
+ [ "$FREETZ_PATCH_SECURE_nau" == "y" ] && modsed 's/data[.]fritzos[.]noAutoupdate/false/g' ${FILESYSTEM_MOD_DIR}${file}
+ [ "$FREETZ_PATCH_SECURE_nus" == "y" ] && modsed 's/data[.]fritzos[.]noUpdateSearch/false/g' ${FILESYSTEM_MOD_DIR}${file}
done
done
