10:09:45.988388 IP (tos 0x60, ttl 64, id 210, offset 0, flags [none], proto UDP (17), length 715) 172.17.3.168.49157 > 172.30.35.10.sip: [no cksum] SIP, length: 687
REGISTER sip:172.30.35.10 SIP/2.0
Via: SIP/2.0/UDP 172.17.3.168:5060;branch=z9hG4bK013a190a
From: <sip:[email protected]>;tag=0017e06a401900130c21e47e-4e3b82fa
To: <sip:[email protected]>
Call-ID: [email protected]
Max-Forwards: 70
Date: Mon, 14 Dec 2015 09:09:44 GMT
CSeq: 109 REGISTER
User-Agent: Cisco-CP7961G/8.5.3
Contact: <sip:[email protected]:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-0017e06a4019>";+u.sip!model.ccm.cisco.com="30018"
Supported: (null),X-cisco-xsi-7.0.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:14 Name=SEP0017E06A4019 Load=SIP41.8-5-4S Last=cm-closed-tcp"
Expires: 3600
10:09:46.028707 IP (tos 0x60, ttl 61, id 43341, offset 0, flags [none], proto UDP (17), length 581) 172.30.35.10.sip > 172.17.3.168.49157: [udp sum ok] SIP, length: 553
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 172.17.3.168:5060;branch=z9hG4bK013a190a;received=172.17.3.168;rport=49157
To: <sip:[email protected]>;tag=as7c5be1f9
CSeq: 109 REGISTER
Server: Asterisk PBX 11.6-cert11
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="mobydick", nonce="703a9409"
Content-Length: 0
10:09:47.913753 IP (tos 0x60, ttl 64, id 211, offset 0, flags [none], proto UDP (17), length 612) 172.17.3.168.49157 > 172.30.35.10.sip: [no cksum] SIP, length: 584
Via: SIP/2.0/UDP 172.17.3.168:5060;branch=z9hG4bK66dc7c0e
From: <sip:[email protected]>;tag=0017e06a40190012faf29dea-d976b15e
Max-Forwards: 70
CSeq: 109 REGISTER
Content-Length: 0
Expires: 3600
10:09:47.954105 IP (tos 0x60, ttl 61, id 43453, offset 0, flags [none], proto UDP (17), length 581) 172.30.35.10.sip > 172.17.3.168.49157: [udp sum ok] SIP, length: 553
Via: SIP/2.0/UDP 172.17.3.168:5060;branch=z9hG4bK66dc7c0e;received=172.17.3.168;rport=49157
To: <sip:[email protected]>;tag=as53f9e599
CSeq: 109 REGISTER
WWW-Authenticate: Digest algorithm=MD5, realm="mobydick", nonce="2fbde157"
Content-Length: 0
10:09:47.973552 IP (tos 0x60, ttl 64, id 212, offset 0, flags [none], proto UDP (17), length 715) 172.17.3.168.49157 > 172.30.35.10.sip: [no cksum] SIP, length: 687
Max-Forwards: 70
CSeq: 109 REGISTER
Content-Length: 0
Expires: 3600
10:09:48.013814 IP (tos 0x60, ttl 61, id 43461, offset 0, flags [none], proto UDP (17), length 581) 172.30.35.10.sip > 172.17.3.168.49157: [udp sum ok] SIP, length: 553
CSeq: 109 REGISTER
Content-Length: 0
