~/freetz-trunk$ diff -ru Config.in Config.in.OS6.2
--- Config.in 2014-01-03 17:37:05.944691186 +0100
+++ Config.in.OS6.2 2014-01-03 17:20:27.524735700 +0100
@@ -1942,7 +1942,8 @@
default "FRITZ.Box_Fon_WLAN_7320.100.05.22.image" if FREETZ_TYPE_7320_7330 && FREETZ_TYPE_FIRMWARE_05_2X
default "FRITZ.Box_Fon_WLAN_7320.100.05.51.image" if FREETZ_TYPE_7320_7330 && !FREETZ_TYPE_FIRMWARE_05_2X
default "FRITZ.Box_Fon_WLAN_7340.en-de-es-it-fr.99.05.22.image" if FREETZ_TYPE_7340_7390 && FREETZ_TYPE_FIRMWARE_05_2X
- default "FRITZ.Box_Fon_WLAN_7340.en-de-es-it-fr.99.05.51.image" if FREETZ_TYPE_7340_7390 && [COLOR="#FF0000"][B]![/B][/COLOR]FREETZ_TYPE_FIRMWARE_05_[COLOR="#FF0000"][B]2[/B][/COLOR]X
+ default "FRITZ.Box_Fon_WLAN_7340.en-de-es-it-fr.99.05.51.image" if FREETZ_TYPE_7340_7390 && FREETZ_TYPE_FIRMWARE_05_5X
+ [COLOR="#FF0000"][B]default "FRITZ.Box_Fon_WLAN_7340.en-de-es-it-fr.99.06.01.image" if FREETZ_TYPE_7340_7390 && FREETZ_TYPE_FIRMWARE_06_XX[/B][/COLOR]
default "FRITZ.Box_Fon_WLAN_7570_vDSL.en-de-fr.75.04.91.image" if FREETZ_TYPE_7570_7270
default "Sinus_W_500V.27.04.27.image" if FREETZ_TYPE_W500V_7150
default "fritz.box_fon_wlan_7141.40.04.37.image" if FREETZ_TYPE_W501V
Mind you, the build does throw this warning:
Code:installing and stripping modules fuse.ko ...................... 24.05 Kb generating modules.dep [COLOR="#B22222"][B]unresolved symbol mcfw_set_avm_pa_dev_info in file /lib/modules/2.6.28.10/kernel/drivers/dsld/kdsldmod.ko unresolved symbol cpmac_fusiv_if_rx2 in file /lib/modules/2.6.28.10/kernel/fusiv_src/kernel/drivers/ethdriver/ethdriver_lkm.ko unresolved symbol is_pid_wan in file /lib/modules/2.6.28.10/kernel/net/avm_pa/avm_pa_fusiv.ko WARNING: Unresolved symbols detected, not all AVM-features may work. No current sources by AVM? Error in kernel's .config?[/B][/COLOR] kernel modules installed: 82 entries in modules.dep and 82 .ko-files found. removing empty kernel module directories kernel/drivers/speedtest installing packages syslogd-cgi-0.2.3 ............ 3.13 Kb
Any idea's, let me know. In the mean time I'll hook up a ttl serial later to see if I can find more info myself.
[COLOR="#B22222"][B]WARNING: This kernel can only load 50 modules at the same time, try 'replace kernel'.[/B][/COLOR]
Box type
7340
AVM firmware version
05.51
Language
en
Kernel version
2.6.28.10 (gcc version 4.6.4 (GCC) )
Freetz version
freetz-devel-11512
Creation date
05.01.2014 12:40:07
SFPB schrieb:Hello cybermaus,
I have some questions for you.
How many files have to be replaced?This is visible if you read the header of wlan_product.cfg file where two chips are declared for the 7390.
Have you tested it lately?I think the 5GHz n+a may even work now, but I cannot test.
Regards,
SFPB
kernel modules installed: 81 entries in modules.dep and 81 .ko-files found.
Sorry for reviving this long inactive thread, but I might be interested... I tried to google for differences in firmware between 7340 and 7490 for FritzOS 6.06, but I mostly get results for hardware differences (and flames between xs4all users...) .Edit: Anyone who read below, ignore it, PEBCAK.
I failed to notice that when you reselect FritzOS version, it automatically deselects alien, so I ended up not building a normal build. Doh!
Not that it matters, I am probably the only one interested in this alien.
Ah, I see.Well, I am not sure about all the software differences. Its mostly the same, as long as you are on the same version
In the past (v5.2 on 7340 and v5.5 on the 7390), I wanted the 7390 because of the sip trunking and fax send/receive that came in V5.5.
Indeed, fewer possibilities than I had hoped,Turns out sip trunking is a useless feature ( not a real trunk, just a wizard that creates multiple lines)
I remember the one time in my life I used a fax as yesterday. It was 8 years, 9 months and 21 days ago, and... Ah, yes I get your point ;-)and fax is now really dead (I still received some 4 years ago, which I why I thought wanted it 2 years ago just in case, but really, fax is now stone cold dead).
I actually run a 6.10 beta on my 7340, but it has problem keeping synchronisation on my vectored connection. XS4all advices downgrading to 6.06, but can't offer a way back to 6.10 in case it does not help. Do you know whether copying mtd3 and mtd4 as per http://www.wehavemorefun.de/fritzbox/Firmware-Wiederherstellung will give me a backup of this fritzOS 6.10 beta on my 7340?And AVMN did bring out V6.06 for 7340, so both features (though useless to me) are there.
Yes, I remember that bug in the news; and indeed, there seems to be no news on 7340 since that last release.For me, now the only reason I would want 7390 onto the 7340 is to have the latest fixes. But we cannot, because we are missing a V6 kernel source for 7340, and the V5 kernel source does not want to work with the V6.20 7390 OS.
The 7340 is not well maintained anymore. The only reason they came out with 6.06 is because someone discovered a severe security bug, and they had to do a new build for all models.
There is no way known to get a backup of the firmware. It is clearly stated in the link that MTD3/4 will save you the config of the fritzbox, not the firmware.Do you know whether copying mtd3 and mtd4 as per http://www.wehavemorefun.de/fritzbox/Firmware-Wiederherstellung will give me a backup of this fritzOS 6.10 beta on my 7340?
Sorry for taking this thread off-track. I silently hoped to find myself compelled to start using Freetz. It is not yet a top priority, I am giving 6.06 a chance at the moment.Well, if that your motivation: While it has been shown impossible to put 7390 onto 7340 without kernel source, I am 99% sure its possible to take the DSL firmware file from the 6.20 and put it into a 6.06 build of 7340.
I do not have time to do that for you, but if you are handy with building yourself, I am quite sure it would be doable.
I am better of than him; as long as there is a connection, it is speedy enough (while waiting for fiber...)On my VDSL line 6.06 works quite well, but I am only 200 meters from the street-cabinet (only annoyance is it does not activate fast latency)
But my brother on 4500 meters needed 6.20 on his 7360 to get VDSL to sync. We did have to convince the provider (also XS4ALL) to try it, and indeed at first it did not work, but after going to 6.20 he went from 4Mbps (ADSL2+) to 7Mbps (V-VDSL).
Come to think of it: Unless if you need 2 analog phones or still a incoming analog line, your best solution is probably to request XS4ALL to swap the router with a 7360. That one is still being updated by AVM and XS4ALL provides them.
Ah yes, thanks. I misiterpreted the sentence and read "and" for the comma:There is no way known to get a backup of the firmware. It is clearly stated in the link that MTD3/4 will save you the config of the fritzbox, not the firmware.
(wishfully) read as: "Dieses Backup und der ADAM2 Konfiguration kann euch und eure Box vor viel Arbeit retten"Empfehlung: Macht ein Backup! Dieses Backup, der ADAM2 Konfiguration kann euch und eure Box vor viel Arbeit retten. - telnet auf die Box - sichert mtd3 und mtd4
