7390 1&1 HomeServer 50.000+ (Rukerneltool Warning)
Please first try to use the right branding and recovery. If the Fritz!Box is still in Bootloop while branding and flashing by recovery is correct, then you/we will think about broken DSL-Part or FON/ISDN-Part. Remember, that this Model is just "out-of-support" after a long distance since Marketing. You may have a look over the sticker at bottom and there the first 4 Characters of Serial ... converting to factory-building-date by this link e.g.
LG
Edit: I will say, that often weak Powersupplies or "pregnant" Capacities onboard may result in strange behavior after a distance of 5 years or more working 24h/365d.
Edit 2nd: As seen correct in #8 Hardwaresubrevision 3 and Bootloader as mentionend here ... may be one out of 2011 Serial Bxxx
Die FRITZ!Box wurde am 06.10.2010 hergestellt
Thank you,router now works
Does it means that it works only on this image?
with which image?
Please answer all questions that are asked
Sorry, but how to recognize, which image or recovery is working actually? One of @stoney `s mentioned freetz-images or a regular via recovery? Without technical faults, You can switch between avm (german Branding) and avme (International Branding) and associated images or recoveries.
LG
Edit: @stoney was faster but btw remember, that newer Firmware need some I-Net-Connection, to load WLAN-Plugin from AVM-Server working correctly after a recovery-action.
DSL-Part is working? Plugged to I-Net/ISP?
LG
@Micha0815 My deutch is really bad,but from translator i understood that I need to delete this component in the green
I'm really suprised about my "Deutch"? What Kind of Image you flashed from stoney ... Better he will response
LG
Edit: Sorry seen Your screenshots to late. Tell Us via screenshot "Internet" and on Bottom switch "Ansicht : Standard" to Experte.
Edit2: OS05.54 seems to be an international FW really old ~2013
I switched to expert and which side of fritz box i need screenshot?
Ok,thank you all,at new year i'll see router inside, Happy new year
I checked this image on other 7390 and usb doesn't work too,but I know that this fritzbox is working.Have someone other image with other DSL.
U have to build an other (own) freetz image (I have told it to you via 'Unterhaltung') it was only for check out what is broken with this old old FW 5.54.
What is your problem? I dont understand the hole thread.
Please anwser all questions at every time.
U have to connect the 7390 after recovery /flashing with rukernel with the internet. (DSL or LAN1-IP Client) to activate some things like WLAN.
Did you do that?
In the image i have spend are only 'teleohony-part' "deleted" nothing else
