- Mitglied seit
- 16 Mai 2006
- Beiträge
- 7
- Punkte für Reaktionen
- 0
- Punkte
- 0
grüße aus spanien
ich hab hier mal ein DMESG ... vielleicht könnt ihr mir sagen was an dem system falsch ist ...
as1:~# dmesg
Linux version 2.6.16.9 (root@as1) (gcc-Version 3.3.5 (Debian 1:3.3.5-13)) #1 Fri Apr 21 13:03:56 CEST 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
BIOS-e820: 000000001fff0000 - 000000001fff3000 (ACPI NVS)
BIOS-e820: 000000001fff3000 - 0000000020000000 (ACPI data)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
511MB LOWMEM available.
On node 0 totalpages: 131056
DMA zone: 4096 pages, LIFO batch:0
DMA32 zone: 0 pages, LIFO batch:0
Normal zone: 126960 pages, LIFO batch:31
HighMem zone: 0 pages, LIFO batch:0
DMI 2.2 present.
ACPI: RSDP (v000 VIA694 ) @ 0x000f6590
ACPI: RSDT (v001 VIA694 AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x1fff3000
ACPI: FADT (v001 VIA694 AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x1fff3040
ACPI: DSDT (v001 VIA694 AWRDACPI 0x00001000 MSFT 0x0100000c) @ 0x00000000
ACPI: PM-Timer IO Port: 0x4008
Allocating PCI resources starting at 30000000 (gap: 20000000:dfff0000)
Built 1 zonelists
Kernel command line: auto BOOT_IMAGE=kernel_2.6.16 ro root=301
Local APIC disabled by BIOS -- you can enable it with "lapic"
mapped APIC to ffffd000 (01401000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 32768 bytes)
Detected 1050.311 MHz processor.
Using pmtmr for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 513060k/524224k available (1314k kernel code, 10640k reserved, 532k data, 216k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 2103.80 BogoMIPS (lpj=4207611)
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383f9ff c1c3f9ff 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383f9ff c1c3f9ff 00000000 00000000 00000000 00000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After all inits, caps: 0383f9ff c1c3f9ff 00000000 00000420 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: AMD Athlon(tm) stepping 02
Checking 'hlt' instruction... OK.
Checking for popad bug... OK.
ACPI: setting ELCR to 0200 (from 1a20)
checking if image is initramfs...it isn't (bad gzip magic numbers); looks like an initrd
Freeing initrd memory: 3456k freed
NET: Registered protocol family 16
EISA bus registered
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfb460, last bus=1
PCI: Using configuration type 1
ACPI: Subsystem revision 20060127
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 10 11 *12 14 15)
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Bridge: 0000:00:01.0
IO window: c000-cfff
MEM window: e4000000-e5ffffff
PREFETCH window: e6000000-e67fffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
mice: PS/2 mouse device common for all mice
EISA: Probing bus 0 at eisa.0
NET: Registered protocol family 2
IP route cache hash table entries: 8192 (order: 3, 32768 bytes)
TCP established hash table entries: 32768 (order: 5, 131072 bytes)
TCP bind hash table entries: 32768 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 32768 bind 32768)
TCP reno registered
TCP bic registered
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI Shortcut mode
ACPI wakeup devices:
SLPB PCI0 USB0 USB1 USB2 LAN0 UAR1 LPT1
ACPI: (supports S0 S1 S4 S5)
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 3456KiB [1 disk] into ram disk... done.
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 216k freed
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:11.1
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:00:11.1[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
PCI: Via IRQ fixup for 0000:00:11.1, from 255 to 11
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8233a (rev 00) IDE UDMA133 controller on pci0000:00:11.1
ide0: BM-DMA at 0xd800-0xd807, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xd808-0xd80f, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
hda: ST340015A, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: _NEC NR-7500A, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(33)
hda: cache flushes supported
hda: hda1 hda2 < hda5 hda6 >
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Adding 1381548k swap on /dev/hda5. Priority:-1 extents:1 across:1381548k
EXT3 FS on hda1, internal journal
Real Time Clock Driver v1.12ac
hdc: ATAPI 32X CD-ROM CD-R/RW drive, 2048kB Cache, DMA
Uniform CD-ROM driver Revision: 3.20
device-mapper: 4.5.0-ioctl (2005-10-04) initialised: [email protected]
EXT3 FS on hda6, internal journal
8139too Fast Ethernet driver 0.9.27
ACPI: PCI Interrupt 0000:00:0d.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
eth0: RealTek RTL8139 at 0xd400, 00:13:49:0b:70:38, IRQ 11
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected VIA KT266/KY266x/KT333 chipset
agpgart: AGP aperture is 64M @ 0xe0000000
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
eth0: no IPv6 routers present
CAPI Subsystem Rev 1.1.2.8
capifs: Rev 1.1.2.3
capi20: Rev 1.1.2.7: started up with major 68 (middleware+capifs)
Modular ISDN Stack core $Revision: 1.34 $
mISDNd: kernel daemon started
mISDNd: test event done
ISDN L1 driver version 1.16
ISDN L2 driver version 1.25
mISDN: DSS1 Rev. 1.35
mISDN_dsp: Audio DSP Rev. 1.16 (debug=0x0) EchoCancellor MG2
mISDN_dsp: DSP clocks every 64 samples. This equals 2 jiffies.
mISDN Capi 2.0 driver file version 1.19
HFC card ddf47040 dch ddf4709c bch1 ddf4721c bch2 ddf4739c
mISDN: HFC-PCI driver Rev. 1.45
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 5
PCI: setting IRQ 5 as level-triggered
ACPI: PCI Interrupt 0000:00:0b.0[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
mISDN: HFC-PCI card manufacturer: CCD/Billion/Asuscom card name: 2BD0
HFC-PCI: defined at mem 0xe08e8000 fifo 0xdd538000(0x1d538000) IRQ 5 HZ 250
reset_hfcpci: entered
HFC_PCI: resetting HFC ChipId(30)
HFC-PCI status(4) before reset
HFC-PCI status(2) after reset
HFC-PCI status(4) after 5us
init_card: entered
inithfcpci: entered
l1_manager prim f1482 not handled
HFC PCI: IRQ 5 count 37
HFC card dd85e840 dch dd85e89c bch1 dd85ea1c bch2 dd85eb9c
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 12
PCI: setting IRQ 12 as level-triggered
ACPI: PCI Interrupt 0000:00:14.0[A] -> Link [LNKD] -> GSI 12 (level, low) -> IRQ 12
HFC-PCI: defined at mem 0xe09d0000 fifo 0xdd668000(0x1d668000) IRQ 12 HZ 250
HFC-PCI status(4) after reset
init_card: entered
inithfcpci: entered
HFC PCI: IRQ 12 count 36
HFC card dd85e040 dch dd85e09c bch1 dd85e21c bch2 dd85e39c
HFC-PCI: No more PCI cards found
HFC 2 cards installed
mISDN dss1 fromup without proc pr=10180 dinfo(0)
Badness in __kfree_skb at net/core/skbuff.c:335
[<c01f2596>] __kfree_skb+0x83/0xd1
[<e0a6f112>] hfcpci_interrupt+0x5ed/0x766 [hfcpci]
[<c0110f22>] do_page_fault+0x180/0x4c7
[<c012c36f>] handle_IRQ_event+0x20/0x4c
[<c012c3ee>] __do_IRQ+0x53/0x91
[<c0104d45>] do_IRQ+0x19/0x24
[<c01038ee>] common_interrupt+0x1a/0x20
[<c01557f5>] d_callback+0x25/0x29
[<c0121e12>] __rcu_process_callbacks+0x7a/0x90
[<c0101047>] default_idle+0x2b/0x53
[<c01010c5>] cpu_idle+0x42/0x57
[<c02d0623>] start_kernel+0x176/0x178
[<c0144b06>] file_free_rcu+0xf/0x15
tei lapd 1 assign req failed
tei lapd 2 assign req failed
