BusyBox v1.00-pre3 (2005.09.22-07:43+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
HWRevision='94'
HWSubRevision='1.0.0'
ANNEX='B'
ANNEX_PTEST_FILE='ptest-results-0'
ANNEX_PTEST_HOST='192.168.178.20'
ANNEX_TEST='0'
OEM='1und1'
Language='de'
Country='049'
TZ='CET-1CEST,M3.5.0,M10.5.0'
CONFIG_AB_COUNT='3'
CONFIG_ANNEX='B'
CONFIG_ANSWER='n'
CONFIG_ASSIST='y'
CONFIG_ATA='n'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_AURA='n'
CONFIG_BLUETOOTH='n'
CONFIG_BLUETOOTH_CTP='n'
CONFIG_BUTTON='y'
CONFIG_CAPI='y'
CONFIG_CAPI_MIPS='n'
CONFIG_CAPI_UBIK='n'
CONFIG_CAPI_XILINX='y'
CONFIG_CDROM='n'
CONFIG_CDROM_FALLBACK='n'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_ENVIRONMENT_PATH='/proc/sys/dev/adam2'
CONFIG_ETH_COUNT='4'
CONFIG_FIRMWARE_URL='http://www.avm.de/fritzbox-firmware-update.php?hardware=94&
oem=1und1&language=de&country='
CONFIG_FON='y'
CONFIG_HOMEI2C='n'
CONFIG_HOSTNAME='fritz.fonwlan.box'
CONFIG_I2C='n'
CONFIG_INSTALL_TYPE='ar7_8MB_xilinx_4eth_3ab_isdn_nt_te_pots_wlan_usb_host_25762
CONFIG_JFFS2='n'
CONFIG_LED_NO_DSL_LED='y'
CONFIG_MEDIACLI='n'
CONFIG_MEDIASRV='n'
CONFIG_NAND='n'
CONFIG_NFS='n'
CONFIG_OEM_DEFAULT='avm'
CONFIG_PRODUKT='Fritz_Box_7170'
CONFIG_PRODUKT_NAME='FRITZ!Box Fon WLAN 7170 (UI)'
CONFIG_RAMSIZE='32'
CONFIG_ROMSIZE='8'
CONFIG_SERVICEPORTAL_URL='http://www.avm.de/fritzbox-service-portal.php?hardware
=94&oem=1und1&language=de&country='
CONFIG_STOREUSRCFG='y'
CONFIG_SUBVERSION=''
CONFIG_UBIK2='n'
CONFIG_USB='n'
CONFIG_USB_HOST_AVM='y'
CONFIG_USB_HOST_TI='n'
CONFIG_USB_PRINT_SERV='y'
CONFIG_USB_STORAGE='y'
CONFIG_USB_WLAN_AUTH='y'
CONFIG_VERSION='04.01'
CONFIG_VERSION_MAJOR='29'
CONFIG_VLYNQ0='3'
CONFIG_VLYNQ1='0'
CONFIG_VLYNQ_PARAMS='vlynq_reset_bit_0=17'
CONFIG_VPN='n'
CONFIG_WLAN='y'
CONFIG_WLAN_GREEN='n'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='y'
ermittle die aktuelle TTY
tty is "/dev/pts/0"
Console Ausgaben auf dieses Terminal umgelenkt
# pwd
