S
SF1975
Guest
Product: FRITZ!WLAN Repeater 540E
Version: FRITZ!OS 6.20
Language: English, French, Italian, Spanish, Polish
Release date: 16.12.2014
New in FRITZ!OS 6.20
WLAN:
NEW: Start WPS for wireless LAN guest access/private hotspot in the fritz.powerline user interface
NEW: Wireless LAN schedule can now be entered conveniently on the tablet or smartphone
NEW: Wireless auto channel can be updated in the user interface
NEW: Detailed information on connected wireless devices (Rx/Tx data rate, RSSI value, wireless standard, etc.)
Home network:
NEW - Detailed informationen on FRITZ!Powerline devices in the home network overview (configuration, Update, connection status, MIMO)
System:
NEW: Option for automatically updating FRITZ!OS*
System/Security:
NEW: Information about recent user registrations on the FRITZ!Repeater interface
NEW: Supports HTTPS even when the fritz.powerline user interfaces are accessed locally
Improvements and Bug Fixes in FRITZ!OS 6.20
System
Improved stability and performance
Improvement: Optimized display of the user interface on Windows phone devices
Improved display in the Energy Monitor
Improvement: Display of number of wireless streams corrected
Improvement: Switch to encrypted mail sending via port 587 with fallback to port 25 if no other port is specified
Improvement: Revised e-mail configuration for push service
Improvement: Saving settings before updating with a FRITZ!OS file now with password
Improvement: Separate test mail for configuring each push service
WLAN:
Improved: Wireless LAN stability
Improvement: Display of wireless LAN registration data as QR code
Improvement: Printout of wireless LAN registration data separate for network and wireless guest access
Improvement: List of access points in wireless LAN environment sorted by reception field strength
Improvement: Stability and latency times improved for Repeater mode
Improvement: Ready for HotSpot2.0/Passpoint (requires provider service)
Improvement: More stable and robust
Change: MAC address filter now under WLAN/Security
Change: Push service customizes e-mail subject lines
Home network:
Improvement: Display of the IPv4 address range assigned to guests
Improvement: Revised check of host name and FRITZ!Box name
Improvement: Adopt parental controls from the FRITZ!Box*
System/Security:
Improvement: Supports new mail systems (STARTTLS) for push mail
* Automatic update: default configuration is "Notify me about new versions of FRITZ!OS and install necessary updates automatically (recommended)"
