Hi
With 'make menuconfig' I see a number of warnings for my 7390-int due to source not available:
On the AVM ftp server I only see sources up to 06.01, and not the current 06.03
Few questions:
-Can the 06.01 source partially be used for some of the warnings I get?
-I get the same warnings with trunk-revision 11600 while this revision is using 84.06.01. 84.06.03 was introduced with trunk-revision 11663. Any reason for 11600 not using the available 06.01 source?
Within the menu I also get: Kernel modules (not available, no sources by AVM)
warning: (FREETZ_PACKAGE_NDAS) can NOT select FREETZ_MODULE_ndas_block because of unmet direct dependencies (FREETZ_REPLACE_MODULE_AVAILABLE)
warning: (FREETZ_PACKAGE_NDAS) can NOT select FREETZ_MODULE_ndas_core because of unmet direct dependencies (FREETZ_REPLACE_MODULE_AVAILABLE)
warning: (FREETZ_PACKAGE_NDAS) can NOT select FREETZ_MODULE_ndas_sal because of unmet direct dependencies (FREETZ_REPLACE_MODULE_AVAILABLE)
warning: (FREETZ_AUTOMOUNT_EXT4) can NOT select FREETZ_MODULE_ext4 because of unmet direct dependencies (FREETZ_REPLACE_MODULE_AVAILABLE && FREETZ_KERNEL_VERSION_2_6_28_MIN)directory `/home/freetz/freetz-trunk-11930/source/host-tools/kconfig-v3.11-rc3'
warning: (FREETZ_AUTOMOUNT_HFS) can NOT select FREETZ_MODULE_hfs because of unmet direct dependencies (FREETZ_REPLACE_MODULE_AVAILABLE)
warning: (FREETZ_AUTOMOUNT_REISER_FS) can NOT select FREETZ_MODULE_reiserfs because of unmet direct dependencies (FREETZ_REPLACE_MODULE_AVAILABLE)
Few questions:
