FB7320 nfsd - kernel replace - bootloop
Micha_Btz
13 Aug 2011
ich verwende den aktuellen freetz-devel git tree und baue damit firmware 6.03. Die Firmware läuft sehr stabil. Einzig den nfs server bekomm ich nicht zum laufen.
Bei verwenden ohne Kernel Replace Option steht folgende Meldung in dmesg
[   76.850000] [module-alloc-by-name] give 0x1000 bytes at 0x8141c000 to module 'exportfs' (0x340000 bytes left)
[   76.950000] [module-alloc-by-name] give 0x16000 bytes at 0x8141d000 to module 'nfsd' (0x32a000 bytes left)
[   76.950000] nfsd: Unknown symbol nlmsvc_unlock_all_by_ip
[   76.950000] nfsd: Unknown symbol svc_close_xprt
[   76.950000] nfsd: Unknown symbol xdr_decode_string_inplace
[   76.960000] nfsd: Unknown symbol auth_domain_find
[   76.960000] nfsd: Unknown symbol svc_recv
[   76.960000] nfsd: Unknown symbol nlmsvc_unlock_all_by_sb
[   76.960000] nfsd: Unknown symbol lockd_down
[   76.960000] nfsd: Unknown symbol lockd_up
[   76.960000] nfsd: Unknown symbol svc_reserve
[   76.960000] nfsd: Unknown symbol svc_max_payload
[   76.960000] nfsd: Unknown symbol svc_exit_thread
[   76.970000] nfsd: Unknown symbol rpc_pton
[   76.970000] nfsd: Unknown symbol xdr_encode_opaque
[   76.970000] nfsd: Unknown symbol svc_proc_register
[   76.970000] nfsd: Unknown symbol cache_purge
[   76.970000] nfsd: Unknown symbol nfsd_debug
[   76.970000] nfsd: Unknown symbol svc_create_xprt
[   76.970000] nfsd: Unknown symbol svc_xprt_put
[   76.980000] nfsd: Unknown symbol qword_add
[   76.980000] nfsd: Unknown symbol cache_unregister
[   76.980000] nfsd: Unknown symbol svc_set_num_threads
[   76.980000] nfsd: Unknown symbol svc_process
[   76.980000] nfsd: Unknown symbol unix_domain_find
[   76.980000] nfsd: Unknown symbol qword_addhex
[   76.980000] nfsd: Unknown symbol qword_get
[   76.980000] nfsd: Unknown symbol svc_create_pooled
[   76.980000] nfsd: Unknown symbol warn_slowpath_null
[   76.980000] nfsd: Unknown symbol auth_unix_forget_old
[   76.990000] nfsd: Unknown symbol sunrpc_cache_lookup
[   76.990000] nfsd: Unknown symbol svc_sock_names
[   76.990000] nfsd: Unknown symbol svc_destroy
[   76.990000] nfsd: Unknown symbol svcauth_unix_purge
[   76.990000] nfsd: Unknown symbol auth_unix_add_addr
[   76.990000] nfsd: Unknown symbol cache_check
[   76.990000] nfsd: Unknown symbol svc_xprt_names
[   76.990000] nfsd: Unknown symbol svc_set_client
[   77.000000] nfsd: Unknown symbol cache_register
[   77.000000] nfsd: Unknown symbol svc_seq_show
[   77.000000] nfsd: Unknown symbol cache_flush
[   77.000000] nfsd: Unknown symbol nlmsvc_ops
[   77.000000] nfsd: Unknown symbol svc_find_xprt
[   77.000000] nfsd: Unknown symbol svc_proc_unregister
[   77.000000] nfsd: Unknown symbol svc_addsock
[   77.000000] nfsd: Unknown symbol sunrpc_cache_pipe_upcall
[   77.010000] nfsd: Unknown symbol svc_print_addr
[   77.010000] nfsd: Unknown symbol svc_pool_stats_open
[   77.010000] nfsd: Unknown symbol auth_unix_lookup
[   77.010000] nfsd: Unknown symbol sunrpc_cache_update
[   77.010000] nfsd: Unknown symbol auth_domain_put
[   77.070000] nfsd: Unknown symbol nlmsvc_unlock_all_by_ip
[   77.080000] nfsd: Unknown symbol svc_close_xprt
[   77.080000] nfsd: Unknown symbol xdr_decode_string_inplace
[   77.080000] nfsd: Unknown symbol auth_domain_find
[   77.080000] nfsd: Unknown symbol svc_recv
[   77.080000] nfsd: Unknown symbol nlmsvc_unlock_all_by_sb
[   77.080000] nfsd: Unknown symbol lockd_down
[   77.080000] nfsd: Unknown symbol lockd_up
[   77.080000] nfsd: Unknown symbol svc_reserve
[   77.090000] nfsd: Unknown symbol svc_max_payload
[   77.090000] nfsd: Unknown symbol svc_exit_thread
[   77.090000] nfsd: Unknown symbol rpc_pton
[   77.090000] nfsd: Unknown symbol xdr_encode_opaque
[   77.090000] nfsd: Unknown symbol svc_proc_register
[   77.090000] nfsd: Unknown symbol cache_purge
[   77.100000] nfsd: Unknown symbol nfsd_debug
[   77.100000] nfsd: Unknown symbol svc_create_xprt
[   77.100000] nfsd: Unknown symbol svc_xprt_put
[   77.100000] nfsd: Unknown symbol qword_add
[   77.100000] nfsd: Unknown symbol cache_unregister
[   77.100000] nfsd: Unknown symbol svc_set_num_threads
[   77.100000] nfsd: Unknown symbol svc_process
[   77.100000] nfsd: Unknown symbol unix_domain_find
[   77.100000] nfsd: Unknown symbol qword_addhex
[   77.110000] nfsd: Unknown symbol qword_get
[   77.110000] nfsd: Unknown symbol svc_create_pooled
[   77.110000] nfsd: Unknown symbol warn_slowpath_null
[   77.110000] nfsd: Unknown symbol auth_unix_forget_old
[   77.110000] nfsd: Unknown symbol sunrpc_cache_lookup
[   77.110000] nfsd: Unknown symbol svc_sock_names
[   77.110000] nfsd: Unknown symbol svc_destroy
[   77.110000] nfsd: Unknown symbol svcauth_unix_purge
[   77.110000] nfsd: Unknown symbol auth_unix_add_addr
[   77.120000] nfsd: Unknown symbol cache_check
[   77.120000] nfsd: Unknown symbol svc_xprt_names
[   77.120000] nfsd: Unknown symbol svc_set_client
[   77.120000] nfsd: Unknown symbol cache_register
[   77.120000] nfsd: Unknown symbol svc_seq_show
[   77.120000] nfsd: Unknown symbol cache_flush
[   77.120000] nfsd: Unknown symbol nlmsvc_ops
[   77.120000] nfsd: Unknown symbol svc_find_xprt
[   77.120000] nfsd: Unknown symbol svc_proc_unregister
[   77.130000] nfsd: Unknown symbol svc_addsock
[   77.130000] nfsd: Unknown symbol sunrpc_cache_pipe_upcall
[   77.130000] nfsd: Unknown symbol svc_print_addr
[   77.130000] nfsd: Unknown symbol svc_pool_stats_open
[   77.130000] nfsd: Unknown symbol auth_unix_lookup
[   77.130000] nfsd: Unknown symbol sunrpc_cache_update
[   77.130000] nfsd: Unknown symbol auth_domain_put
[   77.170000] [0]system-load 6  loadavg 2.40 0.78 0.27 - 99 tasks:16 % curr:rc.nfsd(0 %) max:mtdblockd(8 %, pid:86), readytorun: 1, pgfault 2346/s (max 5 avg 1.5)
[   77.420000] nfsd: Unknown symbol nlmsvc_unlock_all_by_ip
[   77.420000] nfsd: Unknown symbol svc_close_xprt
[   77.430000] nfsd: Unknown symbol xdr_decode_string_inplace
[   77.430000] nfsd: Unknown symbol auth_domain_find
[   77.430000] nfsd: Unknown symbol svc_recv
[   77.430000] nfsd: Unknown symbol nlmsvc_unlock_all_by_sb
[   77.430000] nfsd: Unknown symbol lockd_down
[   77.430000] nfsd: Unknown symbol lockd_up
[   77.430000] nfsd: Unknown symbol svc_reserve
[   77.440000] nfsd: Unknown symbol svc_max_payload
[   77.440000] nfsd: Unknown symbol svc_exit_thread
[   77.440000] nfsd: Unknown symbol rpc_pton
[   77.440000] nfsd: Unknown symbol xdr_encode_opaque
[   77.440000] nfsd: Unknown symbol svc_proc_register
[   77.440000] nfsd: Unknown symbol cache_purge
[   77.440000] nfsd: Unknown symbol nfsd_debug
[   77.440000] nfsd: Unknown symbol svc_create_xprt
[   77.450000] nfsd: Unknown symbol svc_xprt_put
[   77.450000] nfsd: Unknown symbol qword_add
[   77.450000] nfsd: Unknown symbol cache_unregister
[   77.450000] nfsd: Unknown symbol svc_set_num_threads
[   77.450000] nfsd: Unknown symbol svc_process
[   77.450000] nfsd: Unknown symbol unix_domain_find
[   77.450000] nfsd: Unknown symbol qword_addhex
[   77.450000] nfsd: Unknown symbol qword_get
[   77.450000] nfsd: Unknown symbol svc_create_pooled
[   77.460000] nfsd: Unknown symbol warn_slowpath_null
[   77.460000] nfsd: Unknown symbol auth_unix_forget_old
[   77.460000] nfsd: Unknown symbol sunrpc_cache_lookup
[   77.460000] nfsd: Unknown symbol svc_sock_names
[   77.460000] nfsd: Unknown symbol svc_destroy
[   77.460000] nfsd: Unknown symbol svcauth_unix_purge
[   77.460000] nfsd: Unknown symbol auth_unix_add_addr
[   77.460000] nfsd: Unknown symbol cache_check
[   77.460000] nfsd: Unknown symbol svc_xprt_names
[   77.470000] nfsd: Unknown symbol svc_set_client
[   77.470000] nfsd: Unknown symbol cache_register
[   77.470000] nfsd: Unknown symbol svc_seq_show
[   77.470000] nfsd: Unknown symbol cache_flush
[   77.470000] nfsd: Unknown symbol nlmsvc_ops
[   77.470000] nfsd: Unknown symbol svc_find_xprt
[   77.470000] nfsd: Unknown symbol svc_proc_unregister
[   77.470000] nfsd: Unknown symbol svc_addsock
[   77.480000] nfsd: Unknown symbol sunrpc_cache_pipe_upcall
[   77.480000] nfsd: Unknown symbol svc_print_addr
[   77.480000] nfsd: Unknown symbol svc_pool_stats_open
[   77.480000] nfsd: Unknown symbol auth_unix_lookup
[   77.480000] nfsd: Unknown symbol sunrpc_cache_update
[   77.480000] nfsd: Unknown symbol auth_domain_put
[   80.990000] [module-alloc-by-name] give 0xb000 bytes at 0x81433000 to module 'ifxmips_ppa_hal_ar9_a5' (0x31f000 bytes left)
[   80.990000] [module-alloc-by-name] 0xb000 bytes used, 0xd1b4 bytes expected
[   81.040000] [module-alloc-by-name] give 0x12000 bytes at 0x8143e000 to module 'ifx_ppa_mini_sessions' (0x30d000 bytes left)
[   81.040000] [module-alloc-by-name] 0x12000 bytes used, 0x14bf4 bytes expected
[   81.060000] Register LANTIQ_PA @ AVM_PA
[   81.060000] [avm_pa_multiplexer_register_instance]
[   81.060000] 	add:0x8143f8a0 (ifx_ppa_mini_sessions + 0x18a0)   [ifx_ppa_mini_sessions]
[   81.060000] 	remove:0x81440fa8 (ifx_ppa_mini_sessions + 0x2fa8)   [ifx_ppa_mini_sessions]
[   81.060000] [ifx_ppa_mini_session_init]
[   81.060000] [ifx_ppa_mini_session_init] avm_pa sessionh_lookup table
[   81.060000] max_lan_entries       160
[   81.060000] max_wan_entries       160
[   81.060000] max_mc_entries        64
[   81.060000] max_bridging_entries  2048
[   81.060000] max_ipv6_addr_entries 128
[   81.060000] max_fw_queue          0
[   81.060000] max_6rd_entries       4
[   81.060000] AVM - Lantiq-PPA: minimalist and slim Session Management: --- init successful
[   81.060000] Session-Table Size: 256 * 192 byte = 48 kb
[   83.630000] mpoa_setup vcc=82d0b400, mpoa_type=0, mpoa_mode=1
[   83.630000]
[   83.630000] mpoa_setup_conn conn=0, mpoa_type=0, mpoa_mode=1
[   83.630000]
[   83.630000] mpoa_setup vcc=82d0bc00, mpoa_type=0, mpoa_mode=1
[   83.630000]
[   83.630000] mpoa_setup_conn conn=1, mpoa_type=0, mpoa_mode=1
[   83.630000]
[   83.690000] kdsld: VPN: no vpn connections configured
[   84.890000] kdsld: voip: set_snd_ipaddr: 188.106.25.189
[   85.420000] kdsld: internet: set_snd_ipaddr: 94.222.40.52
[   93.000000] nfsd: Unknown symbol nlmsvc_unlock_all_by_ip
[   93.000000] nfsd: Unknown symbol svc_close_xprt
[   93.000000] nfsd: Unknown symbol xdr_decode_string_inplace
[   93.010000] nfsd: Unknown symbol auth_domain_find
[   93.010000] nfsd: Unknown symbol svc_recv
[   93.010000] nfsd: Unknown symbol nlmsvc_unlock_all_by_sb
[   93.010000] nfsd: Unknown symbol lockd_down
[   93.010000] nfsd: Unknown symbol lockd_up
[   93.010000] nfsd: Unknown symbol svc_reserve
[   93.010000] nfsd: Unknown symbol svc_max_payload
[   93.010000] nfsd: Unknown symbol svc_exit_thread
[   93.020000] nfsd: Unknown symbol rpc_pton
[   93.020000] nfsd: Unknown symbol xdr_encode_opaque
[   93.020000] nfsd: Unknown symbol svc_proc_register
[   93.020000] nfsd: Unknown symbol cache_purge
[   93.020000] nfsd: Unknown symbol nfsd_debug
[   93.020000] nfsd: Unknown symbol svc_create_xprt
[   93.020000] nfsd: Unknown symbol svc_xprt_put
[   93.030000] nfsd: Unknown symbol qword_add
[   93.030000] nfsd: Unknown symbol cache_unregister
[   93.030000] nfsd: Unknown symbol svc_set_num_threads
[   93.030000] nfsd: Unknown symbol svc_process
[   93.030000] nfsd: Unknown symbol unix_domain_find
[   93.030000] nfsd: Unknown symbol qword_addhex
[   93.030000] nfsd: Unknown symbol qword_get
[   93.030000] nfsd: Unknown symbol svc_create_pooled
[   93.030000] nfsd: Unknown symbol warn_slowpath_null
[   93.040000] nfsd: Unknown symbol auth_unix_forget_old
[   93.040000] nfsd: Unknown symbol sunrpc_cache_lookup
[   93.040000] nfsd: Unknown symbol svc_sock_names
[   93.040000] nfsd: Unknown symbol svc_destroy
[   93.040000] nfsd: Unknown symbol svcauth_unix_purge
[   93.040000] nfsd: Unknown symbol auth_unix_add_addr
[   93.040000] nfsd: Unknown symbol cache_check
[   93.050000] nfsd: Unknown symbol svc_xprt_names
[   93.050000] nfsd: Unknown symbol svc_set_client
[   93.050000] nfsd: Unknown symbol cache_register
[   93.050000] nfsd: Unknown symbol svc_seq_show
[   93.050000] nfsd: Unknown symbol cache_flush
[   93.050000] nfsd: Unknown symbol nlmsvc_ops
[   93.050000] nfsd: Unknown symbol svc_find_xprt
[   93.050000] nfsd: Unknown symbol svc_proc_unregister
[   93.060000] nfsd: Unknown symbol svc_addsock
[   93.060000] nfsd: Unknown symbol sunrpc_cache_pipe_upcall
[   93.060000] nfsd: Unknown symbol svc_print_addr
[   93.060000] nfsd: Unknown symbol svc_pool_stats_open
[   93.060000] nfsd: Unknown symbol auth_unix_lookup
[   93.060000] nfsd: Unknown symbol sunrpc_cache_update
[   93.070000] nfsd: Unknown symbol auth_domain_put
[  105.250000] [0]system-load 3  loadavg 1.82 0.76 0.28 - 104 tasks:25 % curr:sh(0 %) max:fetchmail(4 %, pid:2716), readytorun: 1, pgfault 1589/s (max 2 avg 1.0)
[  145.130000] [dma_device_write] auto open tx_chan_no:3
[  145.270000] [ieee80211_ioctl_setmlme] non sta mode, skip to set bssid
[  146.120000] [0]system-load 1  loadavg 1.42 0.78 0.30 - 102 tasks:6 % curr:autbtex(0 %) max:mtdblockd(1 %, pid:86), readytorun: 4, pgfault 18/s (max 3 avg 1.0)
Nach einigem suchen, wird dazu wohl die Kernel Replace Option benötigt. Wenn ich jedoch eine Firmware mit Kernel Replace baue, startet die Box immer wieder neu.
Ich kann mich weder im Browser anmelden, noch bekomm ich über telnet, ssh einen Zugriff. Irgendwas geht da schief, ich hab aber keine Ahnung wie ich prüfen kann was.
Jemand ne Idee dazu,?
Micha
würde es mir was bringen 2 images zu vergleichen? also eines mit kernel replace und eines ohne?
worauf müsste ich achten?
mit freetz-devel-12075 läuft der NFS Server jetzt wie gewünscht. Danke!
