S
SF1975
Guest
Product : FRITZ!Box WLAN 3270
Version : FRITZ!OS 5.51 (125.05.51)
Language : Italian
Annex : A
New Features :- MyFRITZ! now available as an app – and needing just one password - Multimedia and music, whenever and wherever
With this FRITZ!OS 5.51, AVM is enhancing its FRITZ!Box with higher speeds, greater convenience and a range of useful functions. Improvements to MyFRITZ! and NAS create new possibilities and really step up convenience.
Would you like to update your FRITZ!Box with the new functions?
All you need to do is use the update wizard to search for the new version of FRITZ!OS. Once the update is available, you’re only two clicks away from conveniently bringing your FRITZ!Box up to date. This means FRITZ!OS 5.51 has over 100 new functions and improvements for your FRITZ!Box, all of them completely free of charge.
With MyFRITZ!App, you can now keep an eye on your home network on the go. This means you can conveniently access your FRITZ!Box and FRITZ.NAS.
The popular, free-of-charge MyFRITZ! service – the cloud you can trust – is now even more convenient and easy to use, and just as secure as ever: with the new FRITZ!OS 5.51, all you need to access the services MyFRITZ! and fritz.box when on the go is to register once – meaning you can connect to your home FRITZ!Box in record time from your smartphone or office computer
FRITZ!OS 5.51 brings a media player to the FRITZ!Box. The player will conveniently play the music saved on your FRITZ!Box and/or other media servers. With a UPnP-enabled device, you can also define which songs are played on other UPnP-devices, for instance on the FRITZ!WLAN Repeater N/G or speakers with wireless capability.
Alternatively deploy your Android smartphone, or FRITZ!App Media, as a convenient way of managing your media library.
Download Firmware: >>>klick<<<new with version FRITZ!OS 5.51:
Internet
NEW: simplified setup of internet account data
NEW: Child protection now uses same design as home network
NEW: Child protection now disconnects active sessions when the surf time is used up
improved presentation of IPv6 functions
improved performance with activated child protection
prevents broadcasting IPv4 multicast with local scope to the internet
fixed problem with dynamic DNS-provider DNS4BIZ
DSL
NEW: interop improvements
NEW: DSL-spectrum graphic now displays max- and min-values
WLAN
NEW: new repeater function to improve the range of a WLAN network*
Warning: If you were using WDS: with this update WDS is changed. It is
not compatible to the older version of the repeater function any longer.
NEW: allows automatic transfer of night-settings to your FRITZ!WLAN Repeater
Home Network
NEW: display if a network device is connected via Repeater/Powerline
NEW: integrated network time server will provide time and date to all network devices
improved display of device-details
MyFRITZ!
NEW: MyFRITZ!-use can now login with the same account to MyFRITZ! and the FRITZ!Box
NEW: Improved MyFRITZ!-Start page for mobile devices, integrated Smart Home support
NEW: support for MyFRITZ! App (Android).
NEW: MyFRITZ!-access for simple worldwide access to Home Network devices via subdomain-name
NEW: When creating a new myfritz.net account from the FRITZ!Box web interface, the name of the FRITZ!Box will automatically be used on MyFRITZ!
Memory(NAS) and USB
NEW: separate shares and read-/write access for every FRITZ!Box user
NEW: USB-memory can now be disconnected separately
improved USB device handling
Media server
NEW: added support for FLAC & M4A
System
NEW: FRITZ!Box-user with different access rights for setup, telephone and storage
added new mailservers for push service setup
start page now also displays status of LAN-guestaccess and Smart Home
LAN-settings moved to Home Network
Mobile
NEW: Option to allow use of internet telephony over mobile internet connections
NEW: intelligent USB-3G dongle detection
Important details regarding this update:
Tip: to use the new functions of the FRITZ!Box web interface, please use a Webbrowser with HTML5-support (for example the current versions of Chrome, Firefox or Safari)
* For more information about the new WLAN repeater function, please visit http://www.avm.de/en/news/artikel/2013/new_repeater_function.html
Download Recover: >>>klick<<<
Erstellt mit ruKernelTool, V0.6.2.17 beta am 21.06.2013 20:28:49
Firmware = FRITZ.Box_WLAN_3270_v3_Edition_Italia.125.05.51.image
Firmware-Größe = 13352960
Firmware-Datum = 21.06.2013 20:24:12
Firmware-md5 = 0x4a4eb32e19b0e831ee69444711768161
Kernel.image = kernel_aus_FRITZ.Box_WLAN_3270_v3_Edition_Italia.125.05.51.image
Kernel-Größe = 12643123
Kernel-Datum = 21.06.2013 12:58:52
Kernel-md5 = 0xd3cb6a4897389fdf09446f4829309c4d
Altes Kernel-Format = Nein
Filesystem.image = filesystem.image
Filesystem-Größe = 0
Filesystem-Datum = 21.06.2013 12:58:52
Filesystem-md5 =
Gedacht für Box = Fritz_Box_HW197
Installtype = ur8_16MB_xilinx_4eth_isdn_nt_te_pots_wlan_usb_host_plus_italia_07954
Versionsinfo = 125.05.51
Checkpoint = r25680
Brandings = avme
firmware_version =
Annex = A
VDSL-Version =
ADSL-Version =
DECT-Version =
Freetz Packages =
