S
SF1975
Guest
Download Firmware: >>>klick<<<new with version FRITZ!OS 5.51:
telephony:
NEW: Search and scroll in the phone-book
NEW: answering machine now has it's own menu entry
NEW: Upload your own welcome message
NEW: timer for the answering machine
NEW: set the wakeup-message for the alarm
NEW: IP-telephones can be used over the internet (connect your smartphone to the FRITZ!Box and use it on the road)
Internet
NEW: simplified setup of internet account data
NEW: Child protection now uses same design as home network
NEW: Child protection now disconnects active sessions when the surf time is used up
improved presentation of IPv6 functions
improved performance with activated child protection
prevents broadcasting IPv4 multicast with local scope to the internet
fixed problem with dynamic DNS-provider DNS4BIZ
DSL
NEW: interop improvements
NEW: DSL-spectrum graphic now displays max- and min-values
NEW: DSL-line test can diagnose the physical DSL-connection
WLAN
NEW: new repeater function to improve the range of a WLAN network
Warning: If you were using WDS: with this update WDS is changed. It is
not compatible to the older version of the repeater function any longer.
NEW: allows automatic transfer of night-settings to your FRITZ!WLAN Repeater
DECT/FRITZ!Fon:
NEW: Mediaplayer for FRITZ!Fon and external players (uPNP-AV)
NEW: Support for Smart Home (FRITZ!DECT 200)
NEW: record personal memos in the answering machine
NEW: start-screen of the FRITZ!Fon MT-F can now be navigated *
NEW: setup of alarmsignal/Internetradio on the handset*
NEW: setup of favorites
fixed a problem, where key lock could not be deactivated on incoming call
Home Network
NEW: New Smart Home area in the Home Network menu
NEW: control of Smart Home devices via browser
NEW: Integration of the intelligent power plug FRITZ!DECT 200 in FRITZ!OS**
NEW: FRITZ!DECT 200 manual and automatic switching, from the Home Network or over the internet
NEW: FRITZ!DECT 200 measures the energy consumption of connected devices
NEW: FRITZ!DECT 200 all information and consumption details in a push-mail
NEW: display if a network device is connected via Repeater/Powerline
NEW: integrated network time server will provide time and date to all network devices
improved display of device-details
MyFRITZ!
NEW: MyFRITZ!-use can now login with the same account to MyFRITZ! and the FRITZ!Box
NEW: Improved MyFRITZ!-Start page for mobile devices, integrated Smart Home support
NEW: support for MyFRITZ! App (Android).
NEW: MyFRITZ!-access for simple worldwide access to Home Network devices via subdomain-name
NEW: When creating a new myfritz.net account from the FRITZ!Box web interface, the name of the FRITZ!Box will automatically be used on MyFRITZ!
Memory(NAS) and USB
NEW: separate shares and read-/write access for every FRITZ!Box user
NEW: USB-memory can now be disconnected separately
improved USB device handling
Media server
NEW: playback music for the Media server with FRITZ!Fon*
NEW: added support for FLAC & M4A
System
NEW: new start page, quicker access to voice messages and comfort functions
NEW: FRITZ!Box-user with different access rights for setup, telephone and storage
NEW: display new voice-messages on the bottom right of the start page
added new mailservers for push service setup
start page now also displays status of LAN-guestaccess and Smart Home
LAN-settings moved to Home Network
Mobile
NEW: Option to allow use of internet telephony over mobile internet connections
NEW: intelligent USB-3G dongle detection
Important details regarding this update:
Tip: to use the new functions of the FRITZ!Box web interface, please use a Webbrowser with HTML5-support (for example the current versions of Chrome, Firefox or Safari)
* To be able to use all new features of the FRITZ!Fon family, please also update the firmware of the FRITZ!Fon.
**To use this function, the intelligent power plug FRITZ!DECT 200 is required
Download Recover: >>>klick<<<
