[Problem] ICMP/PING flood protection of AVM Fritz!Box products
giovanni2011
18 Jun 2011
Hi all,
I'm an owner of two Fritz!Box 7170, and three Cisco 877 routers.
I currently deployed a small network consisting of five DSL of a local provider, and everything is quite fine except if I try to use a QoS-check (SLA) features of Cisco 877, checking my Fritz!Boxes, I have a lot of ICMP loss due to a sort of internal "ICMP traffic limiter" or "ICMP anti-flooding mechanism", ex:
CISCO#ping 1.2.3.4 repeat 20
Type escape sequence to abort.
Sending 20, 100-byte ICMP Echos to 10.5.1.48, timeout is 2 seconds:
Success rate is 75 percent (15/20), round-trip min/avg/max = 8/10/12 ms
where 1.2.3.4 is the public IP address of any of the Fritz!Box routers.
Does someone knows how disable the rate ICMP rate limiting (globally or only for a give address)? I can't find a solution by Googling or checking the great "wehavemorefun" site.
Thank you in advance,
