Massive data transfer = reboot ?
vasila
7 Mai 2008
Hello,
I'm using freetz version 54.04.63freetz-devel-2670M , and if i make a massive data transfer from a NTFS disk connected to the fritz USB to a NAS drive connected to ethernet LAN of the fritz, the box, after some time makes a reboot !!
The data transfer is made with a synchronization software (2BrightSparks SyncBack). The software is installed on a PC connected via wireless to the box.
In the PC i make Network drives (X: for the USB connected to fritz and Z: for NAS drive) and make the transfer.
It is possible to have a log of the system??
What can cause the problem?
Thanks in advance
Best regards
Ok..... I found a log of syslog.
Here it is:
Jan  1 00:01:09 fritz daemon.info chronyd[1251]: Linux kernel major=2 minor=6 patch=19
Jan  1 00:01:09 fritz daemon.info chronyd[1251]: calculated_freq_scale=0.99902439 freq_scale=0.99902439
Jan  1 00:01:09 fritz daemon.err chronyd[1251]: Could not open /dev/rtc, No such file or directory
Jan  1 00:01:09 fritz daemon.err chronyd[1251]: Real time clock not supported on this operating system
Jan  1 00:01:10 fritz daemon.info chronyd[1251]: System's initial offset : 279589573.618398 seconds slow of true (step)
Nov  9 23:47:24 fritz user.err telefon[1108]: set initial telefon time from linux time to 23:47 9.11 2008!
Nov  9 23:47:24 fritz daemon.warn chronyd[1251]: Could not send to 193.65.58.57 : Bad file descriptor
Nov  9 23:47:25 fritz user.err usermand[1030]: /var/flash/user.cfg: is empty
Nov  9 23:47:25 fritz user.err usermand[1030]: load_config(user): factory default loaded
Nov  9 23:47:25 fritz user.err ctlmgr[629]: ctlmgr: plugin_install()
Nov  9 23:47:25 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:47:25 fritz daemon.warn chronyd[1251]: Could not send to 193.65.58.57 : Bad file descriptor
Nov  9 23:47:26 fritz daemon.warn chronyd[1251]: Could not send to 193.65.58.57 : Bad file descriptor
Nov  9 23:47:27 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:47:39 fritz user.err ctlmgr[629]: ctlmgr: plugin_install()
Nov  9 23:47:39 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:47:41 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:48:05 fritz user.err ctlmgr[629]: ctlmgr: plugin_install()
Nov  9 23:48:05 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:48:07 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:48:55 fritz user.err ctlmgr[629]: ctlmgr: plugin_install()
Nov  9 23:48:55 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:48:59 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:49:07 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 189): Invalid or incomplete multibyte or wide character
Nov  9 23:49:07 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 968): Invalid or incomplete multibyte or wide character
Nov  9 23:49:07 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 3105): Invalid or incomplete multibyte or wide character
Nov  9 23:49:07 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 2493): Invalid or incomplete multibyte or wide character
Nov  9 23:50:12 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 6219): Invalid or incomplete multibyte or wide character
Nov  9 23:50:35 fritz user.err ctlmgr[629]: ctlmgr: plugin_install()
Nov  9 23:50:35 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:50:37 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:50:42 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 2223): Invalid or incomplete multibyte or wide character
Nov  9 23:50:42 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 2224): Invalid or incomplete multibyte or wide character
Nov  9 23:50:42 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 2225): Invalid or incomplete multibyte or wide character
Nov  9 23:50:42 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 2226): Invalid or incomplete multibyte or wide character
Nov  9 23:50:42 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 2227): Invalid or incomplete multibyte or wide character
Nov  9 23:50:50 fritz daemon.notice ntfs-3g[1085]: Skipping unrepresentable filename (inode 5955): Invalid or incomplete multibyte or wide character
Nov  9 23:53:49 fritz user.err ctlmgr[629]: ctlmgr: plugin_install()
Nov  9 23:53:49 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:53:51 fritz user.err ctlmgr[629]: ctlmgr: plugin_installer: plugin not found yet. further installation needed!
Nov  9 23:55:59 fritz user.info eventadd[1978]: EVENT(132): USB-Gerät 007 abgezogen
Nov  9 23:55:59 fritz daemon.notice ntfs-3g[1085]: ntfs_attr_pread_i: ntfs_pread failed: Input/output error
Nov  9 23:55:59 fritz daemon.notice ntfs-3g[1085]: Error reading $Mft record(s): Input/output error
Nov  9 23:55:59 fritz daemon.notice ntfs-3g[1085]: ntfs_mft_record_read failed: Input/output error
[B]Nov  9 23:55:59 fritz daemon.notice ntfs-3g[1085]: Unmounting /dev/sda1 (New Volume)
Nov  9 23:55:59 fritz user.info eventadd[1996]: EVENT(141): uStor01 entfernt[/B]
Nov  9 23:57:16 fritz user.err usermand[1030]: 0.0.0.0:2932: connect to 192.168.178.23:14013 failed - No route to host (148)
Nov  9 23:57:41 fritz user.err usermand[1030]: 0.0.0.0:4307: connect to 192.168.178.23:14013 failed - No route to host (148)
Nov  9 23:58:20 fritz user.err usermand[1030]: 0.0.0.0:3479: connect to 192.168.178.23:14013 failed - No route to host (148)
Nov  9 23:59:58 fritz user.err igdd[1012]: 0.0.0.0:2749: connect to 192.168.178.23:49001 failed - No route to host (148)
In bold you can find the error.... Seems to be an USB NTFS error.
Any help?
Thank you
Best Regards
You got it. Its a filesystem error, nothing to do with freetz. Stick your harddisk to your desktop-pc and fs-check the partion(s) on the drive.
Actually, it's an USB error and not an NTFS error.
The USB layer thinks that the device is disconnected, and therefor further access to the device fails.
I had similar problems with some USB devices.
Will the device be mounted after such error with another name? How has you enabled this debug log?
After the error the device is mounted with the same name since the box reboots.
This log is taken with SysLog installed with the freetz firmware.
Best Regards
