Hello, I have a 7050 annex B to annex A. After the patch it can get the signal, but the connection is not yet good enough. So I just wanted to change the electric components (resistors and capacitors) just to make it identical to an annex A native.
Here is the image of an annex B native:
And here the annex A native:
How you can see, the components in the annex A are much more. It's just cause the signal has to be normalized better.
The problem is that I don't know the exact value of those components, especially capacitors.
Can you suggest me those values?
