Hi ich habe folgenden fehler beim kompilieren von toolchain
make -C /home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6 all
make[1]: Entering directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6'
make[2]: Entering directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6'
make[3]: Entering directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/libiberty'
make[4]: Entering directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/libiberty/testsuite'
make[4]: Für das Ziel »all« ist nichts zu tun.
make[4]: Leaving directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/libiberty/testsuite'
make[3]: Leaving directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/libiberty'
make[3]: Entering directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/intl'
make[3]: Für das Ziel »all« ist nichts zu tun.
make[3]: Leaving directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/intl'
make[3]: Entering directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/bfd'
Making info in doc
make[4]: Entering directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/bfd/doc'
restore=: && backupdir=".am$$" && \
am__cwd=`pwd` && cd ../.././bfd/doc && \
rm -rf $backupdir && mkdir $backupdir && \
for f in ../.././bfd/doc/bfd.info ../.././bfd/doc/bfd.info-[0-9] ../.././bfd/doc/bfd.info-[0-9][0-9] ../.././bfd/doc/bfd.i[0-9] ../.././bfd/doc/bfd.i[0-9][0-9]; do \
if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
done; \
cd "$am__cwd"; \
if /home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/missing makeinfo --split-size=5000000 --split-size=5000000 -I ../.././bfd/doc \
-o ../.././bfd/doc/bfd.info ../.././bfd/doc/bfd.texinfo; \
then \
rc=0; \
cd ../.././bfd/doc; \
else \
rc=$?; \
$restore $backupdir/* `echo "./../.././bfd/doc/bfd.info" | sed 's|[^/]*$||'`; \
fi; \
rm -rf $backupdir; exit $rc
WARNING: `makeinfo' is missing on your system. You should only need it if
you modified a `.texi' or `.texinfo' file, or any other file
indirectly affecting the aspect of the manual. The spurious
call might also be the consequence of using a buggy `make' (AIX,
DU, IRIX). You might want to install the `Texinfo' package or
the `GNU make' package. Grab either from any GNU archive site.
make[4]: *** [../.././bfd/doc/bfd.info] Fehler 1
make[4]: Leaving directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/bfd/doc'
Making info in po
make[4]: Entering directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/bfd/po'
make[4]: Für das Ziel »info« ist nichts zu tun.
make[4]: Leaving directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/bfd/po'
make[4]: Entering directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/bfd'
make[4]: Für das Ziel »info-am« ist nichts zu tun.
make[4]: Leaving directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/bfd'
make[3]: *** [info-recursive] Fehler 1
make[3]: Leaving directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/bfd'
make[2]: *** [all-bfd] Fehler 2
make[2]: Leaving directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6'
make[1]: *** [all] Fehler 2
make[1]: Leaving directory `/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6'
make: *** [/home/dazclimax/Downloads/FritzBox/ds-0.2.9/source/toolchain/binutils-2.16.91.0.6/binutils/objdump] Fehler 2
Kann mir jemand sagen wie ich das lösen kann ?
Making info in doc
done; \
cd "$am__cwd"; \
then \
rc=0; \
else \
rc=$?; \
fi; \
Making info in po
