(AVM) EVA Revision: 1.123 Version: 1123
(C) Copyright 2005 AVM Date: Nov 10 2005 Time: 12:04:41 (1) 2 0-1101
[FLASH:] MACRONIX Top-MirrorBit-Flash 4MB 32 Bytes WriteBuffer
[FLASH:](Eraseregion [0] 63 sectors a 64kB)
[FLASH:](Eraseregion [1] 8 sectors a 8kB)
[SYSTEM:] OHIO on 211MHz/125MHz
AVM_Ar7 >
[cpmac]<no link>
[cpmac]<found link>
.........done
start kernel
Launching kernel decompressor.
Kernel decompressor was successful ... launching kernel.
LINUX started...
Config serial console: ttyS0,38400
MDIX enabled.
prom_init: local_env_buffer 952 used (max 2048)
CPU revision is: 00018448
Primary instruction cache 16kb, linesize 16 bytes (4 ways)
Primary data cache 8kb, linesize 16 bytes (4 ways)
Number of TLB entries 16.
Linux version 2.4.17_mvl21-malta-mips_fp_le (mike@xubuntu) (gcc version 3.3.2) #1 Wed Sep 20 18:41:00 CEST 2006
Reset Status: SW reset 0
DEBUG: Bring MDIO out of reset.
Determined physical RAM map:
memory: 14000000 @ 00000000 (reserved)
memory: 00020000 @ 14000000 (ROM data)
memory: 00fe0000 @ 14020000 (usable)
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line:
calculating r4koff... 00102c00(1059840)
CPU frequency 211.97 MHz
Calibrating delay loop... 211.35 BogoMIPS
Freeing Adam2 reserved memory [0x14001000,0x0001f000]
Memory: 14644k/16384k available (1208k kernel code, 1740k reserved, 75k data, 44k init)
Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
Checking for 'wait' instruction... available.
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Disabling the Out Of Memory Killer
devfs: v1.7 (20011216) Richard Gooch ([email protected])
devfs: boot_options: 0x1
Squashfs 2.1-r2 (released 2004/12/15) (C) 2002-2004 Phillip Lougher
pty: 32 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with no serial options enabled
ttyS00 at 0xa8610e00 (irq = 15) is a 16550A
block: 64 slots per queue, batch=16
Universal TUN/TAP device driver 1.4 (C)1999-2001 Maxim Krasnyansky
resize flash to 0x400000 Bytes
avalanche flash device: 0x400000 at 0x10000000.
Amd/Fujitsu Extended Query Table v1.3 at 0x0040
Physically mapped flash:0: Swapping erase regions for broken CFI table.
number of CFI chips: 1
Looking for mtd device :mtd0:
NOTICE: empty mtd0 segment found, assume hidden root
Looking for mtd device :mtd1:
locking for hidden SquashFs image (0x90010000 - 0x903c0000)
hidden SquashFs image found at 0xb00a0000
add to memory config: hidden squashfs 0x900a0000-0x903c0000
NOTICE: create root segment mtd0, for hidden root
Found a mtd0 image (0xa0000), with size (0x320000).
Creating 1 MTD partitions on "Physically mapped flash:0":
0x000a0000-0x003c0000 : "mtd0"
Found a mtd1 image (0x10000), with size (0x3b0000).
0x00010000-0x003c0000 : "mtd1"
Looking for mtd device :mtd2:
Found a mtd2 image (0x0), with size (0x10000).
0x00000000-0x00010000 : "mtd2"
Looking for mtd device :mtd3:
Found a mtd3 image (0x3c0000), with size (0x20000).
0x003c0000-0x003e0000 : "mtd3"
Looking for mtd device :mtd4:
Found a mtd4 image (0x3e0000), with size (0x20000).
0x003e0000-0x00400000 : "mtd4"
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
mount on mtd3 and mtd4 (double buffering)
Adam2 environment variables API installed.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NET4: Ethernet Bridge 008 for NET4.0
Initializing the WAN Bridge.
Please set the MAC Address for the WAN Bridge.
Set the Environment variable 'wan_br_mac'.
MAC Address should be in the following format: xx.xx.xx.xx.xx.xx
Kernel panic: VFS: Unable to mount root fs on 1f:00
<0>Rebooting in 5 seconds..
