Firmware 1.1.0.13
rsl
Aktives Mitglied
27 Mai 2004
Moin,
als erstes der Hinweis: bevor ihr die FW auf euer Telefon schiebt, Releasenotes lesen, auch das in rot geschriebene! http://grandstream.com/BETATEST/GXP2000_BT200/Release_Note_GXP2000_1.1.0.13.pdf
Der neue Teil ist schnell erzaehlt:
Build 1.1.0.13 5/16/2005
• Add Quick IP Calling mode
• Fixed GXP-2000 Speed Dial/Asterisk BLF pick up broken in 1.1.0.12
Und der Vollstaendigkeit halber alles was in 1.1.x released ist:
Build 1.1.0.12 5/15/2006
• Fixed GXP-2000 crashes when a very long DTMF string is dialed
• Fixed SIP NOTIFY to event REFER violating RFC 3515
• Fixed we do not affix To-tag for PRACK request
• Fixed we do not use new branch for PRACK request
• Fixed we do not include Contact header in 180
• Fixed we do use random port for RTP even if random port is set to yes
Build 1.1.0.11 4/28/2006
• Fixed the ping problem when the device is in router mode
• Enabled the broadcast drop mode (this should improve the switch performance for multicast
and broadcast)
• Fixed the 3-way conferencing issue when the re-invite to bring the 1st party out of hold status
gets challenged.
This is difficult to verify. Basically our 3-way conferencing can be broken into the following
steps:
o A invites B
o A re-invites B to put B on hold
o A invites C
o A re-invites B to put B out of hold status
If at step d) the proxy challenges the request with 401/407, we couldn’t complete the
conferencing
• Fixed the PPPoE TCP problem
• Added idle timers to fix more idle screen blackout cases
• Fixes for blank LCD or corrupted GUI issues
• A-Tick and DC filter changes
www.grandstream.com
Release Note for GXP-2000
• Fixed crash on incoming call when all channels are in use
• Fixed lost registration problem
• Fixed we will never switch DNS server even if primary DNS server failed to
respond and there is a secondary DNS server
• Changed for GXP-2000: once entering direct IP calling mode, the cursor focus is
in the text field instead of CANCEL button
• Reduce the GXP2000 handset earpiece audio level by 4.5 dB
• Fixed GXP-2000 crashes when using MISSED CALL GUI to dial out
• Added use of MUTE/DEL key during incoming call ringing state will reject call
using 486
• Added MUTE/DEL key will act as toggle key to turn DND on and off during idle
• Fixed GXP-2000 direct IP call cannot specify port.
Note that a new input method is specified here: you will use * to enter dots
(separator between octets) and use # to enter colon (separator for port). So you
can enter "10.10.12.135:5068" using "10*10*12*135#5068". This is probably
more intuitive
Note 2: Direct-IP calling feature is further cleaned out so that STUN mapped info
is not used when we detect direct IP calling destination is in local subnet (From
and Contact headers are also cleaned to use IP address only, not including the
configured SIP URI).
• Fixed AGC setup change
• Fixed RTPSend bug
• Fixed we do not use the previous SSRC, timestamp, and sequence number after
restoring a previously hold call
• Fixed static IP problem in 1.1.0.2
• Fixed we start sending RTP when restoring a call before we receive 200 OK Fixed
we do not clear out CallFwd settings when user configure to disable call features
• Added special factory workaround mode-when configured to use static IP
192.168.0.160 and no gateway IP is configured, provisioning is skipped
• Added support for Broadsoft Click-to-Answer feature using "talk" event
• Fixed GXP-2000 cannot make direct IP calls
• Fixed GXP-2000 factory MAC-Edit function cannot change last digit to A-F
• Fixed redial does not append the dial-plan prefix
• Fixed we will retry 5 times if only config server is configured and there is config
file
• More LCD fix for GXP-2000
• Fixed some crashes Issues
Viel Spass beim Testen, wie immer auf eigenes Risiko!
rsl
Läuft klasse.
Ich bin ja ein bisschen vorsichtig mit solchen Aussagen aber "Fixes for blank LCD or corrupted GUI issues" scheint auch bei den 8203- Kandidaten eine Besserung gebracht zu haben, zumindest soweit ich das nach 15 Stunden beurteilen kann.
rsl
und wo bekomme ich die Version 1.1.0.13?
RJR
Ist schon jemandem aufgefallen, dass das Klick-Problem bei den Selbstgemachten Klingeltönen mit diesem Release verschwunden ist? Bei mir knackt kein Klingelton mehr.
hast recht. kein knacken mehr....
is ja geil!
Allerdings habe ich auch mit dieser Version weiterhin unregelmäßig das leere Display :(
Betrachte das doch langsam als Privileg. Nachvollziehen mit welcher Kombination Updates usw. diese Macke bei dir verursacht wurde kann man doch sowieso kaum. Am Ende ist es wahrscheinlich ein Kontaktproblem.
rsl
habe mir jetzt auch die 1.1.0.13 draufgespielt(vorher 1.1.0.5) und in den
release_Notes folgendes gelesen:
Bitte jetzt nicht "killen" bin aber mit den Abkürzungen für Fachausdrücke nicht so bewandert, das kommt schon noch. Was bedeutet DND?
Thx.
Timm
Do Not Disturb - bitte nicht stören. Noch genauer: Schnauze halten Modus.
Aha, und was sagt mir das jetzt?
Das Telefon klingelt nicht mehr?
Oder wird direkt zum AB geschickt?
Trifft ein´s von beiden zu?
Thx
Timm
Japp.
also wenn Du nen Asterisk hast kannst ihn so einstellen dass er das macht. Bei mir ists so.
Übrigens:
Naja mit den alten Firmwares ging es ja ohne das Leere Display-Problem (Also mit den ganz alten FWs auf die man jetzt nicht mehr zurück-downgraden kann). Es scheint also kein Hardware-Problem zu sein.
Was mir diesbezüglich auch noch aufgefallen ist: Seit der 1.1.0.11 reagiert das Display ganz langsam - also Display-Änderungen "springen" nicht mehr um, sondern "blenden" quasi über - auch die Uhrzeit (also die Sekunden) blenden die Ziffern praktisch über statt dass sie sich einfach "zack" ersetzen. Ist das gewollt? Oder ist das ein Nebeneffekt der Versuche seitens Grandstreams, die Disp. Probs zu fixen?
Kann jemand folgendes Phänomen nachvollziehen: Wenn ich in Preferences->Ring Tone auf "Default Ringtone" navigiere und anschließend das Menü mit "Pfeil-Nach-Link" verlasse (3x) blinkt das Speaker-Symbol oben links.
Bevor ich von der 1.1.0.5 auf die 1.1.0.13 upgrade - gibts irgendwo die 1.1.0.5 zum download? Nur für den Fall der Fälle.
Hier http://www.ip-phone-forum.de/downloads.php?do=cat&id=38 finde ich sie nicht und bei Grandstream auch nicht.
Falls natürlich mit der 13 alles besser ist als mit der 5, mache ich mir keine Sorgen und flashe fröhlich :D
Anscheinend hat es die 1.1.0.5 nie gegeben - die ist in den Releasenotes nicht erwähnt :confused:
JackNeale
